STC单片机读取DHT11在1602上面显示乱码
 楼主| 尼古拉斯JT 发表于 2019-11-23 10:24 | 显示全部楼层 |阅读模式
编译后10K
#include <reg52.h>
#include <stdio.h>
#include <intrins.h>
#define uchar unsigned char
#define uint  unsigned int
#define DataPort P0
bit ReadTempFlag;
bit ReadRHFlag;
bit ReadVFlag;
sbit RS = P2^4;
sbit RW = P2^5;
sbit EN = P2^6;
sbit DQ=P3^3;
sbit DHT=P3^6;
char dat_t[4],dat_v[4],dat_s[4];
bit ReadTmpFlag,ReadRHFlag,OVERFLOWFLAG;
void Delay_Us(unsigned char t)
while(--t);
void Delay_Ms(unsigned char t)
while(t--)
     Delay_Us(245);
         Delay_Us(245);
bit Init_DS18B20(void)
bit dat=0;
DQ = 1;
Delay_Us(5);
DQ = 0;
Delay_Us(200);
Delay_Us(200);
DQ = 1;
Delay_Us(50);
dat=DQ;
Delay_Us(25);
return dat;
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
  DQ = 0;
  dat>>=1;
  DQ = 1;
  if(DQ)
   dat|=0x80;
  Delay_Us(25);
return(dat);
void WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=8; i>0; i--)
  DQ = 0;
  DQ = dat&0x01;
  Delay_Us(25);
  DQ = 1;
  dat>>=1;
Delay_Us(25);
unsigned int ReadTemperature(void)
unsigned char a=0;
unsigned int b=0;
unsigned int t=0;
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0x44);
Delay_Ms(10);
Init_DS18B20();
WriteOneChar(0xCC);
WriteOneChar(0xBE);
a=ReadOneChar();
b=ReadOneChar();
b<<=8;
t=a+b;
return(t);
void DHT_Start()
        DHT = 1;
        Delay_Us(2);
        DHT = 0;
        Delay_Ms(30);
        DHT = 1;
        Delay_Us(30);
uchar DHT_rec_byte()
   uchar i,dat=0;
  for(i=0;i<8;i++)
      while(!DHT);
          Delay_Us(8);
      dat<<=1;
      if(DHT==1)
         dat+=1;
      while(DHT);
    return dat;
void DHT_receive()
        uchar R_H,R_L,T_H,T_L,RH,RL,TH,TL,revise;
        DHT_Start();
        if(DHT == 0)
                while(DHT == 0);
                Delay_Us(40);
                R_H = DHT_rec_byte();                        //?????8?
                R_L = DHT_rec_byte();                        //?????8?
                T_H = DHT_rec_byte();                        //?????8?
                revise = DHT_rec_byte();
                Delay_Us(25);                                //??
                if((R_H+R_L+T_H+T_L)==revise)                        //??
                        RH = R_H;
                        RL = R_L;
                        TH = T_H;
                        TL = T_L;
                dat_s[0] = 0x30 + (RH/10);
                dat_s[1] = 0x30 + (RH%10);
                dat_s[2] = 0x30 + (TH/10);
                dat_s[3] = 0x30 + (TH%10);
bit LCD_Check_Busy(void)
DataPort= 0xFF;
RS=0;
RW=1;
EN=0;
_nop_();
EN=1;
return (bit)(DataPort & 0x80);
void LCD_Write_Com(unsigned char com)
Delay_Ms(5);
RS=0;
RW=0;
EN=1;
DataPort= com;
_nop_();
EN=0;
void LCD_Write_Data(unsigned char dt)
Delay_Ms(5);
RS=1;
RW=0;
EN=1;
DataPort= dt;
_nop_();
EN=0;
void LCD_Clear(void)
LCD_Write_Com(0x01);
Delay_Ms(5);
void LCD_Write_String(uchar ad,uchar *s)
        LCD_Write_Com(ad);
        while (*s)
         LCD_Write_Data( *s);
         s ++;
void LCD_Write_Char(uchar ad,uchar Data)
        LCD_Write_Com(ad);
         LCD_Write_Data( Data);
void LCD_Init(void)
   LCD_Write_Com(0x38);    /*ÏÔʾģʽÉèÖÃ*/
   Delay_Ms(5);
   Delay_Ms(5);
   Delay_Ms(5);
   LCD_Write_Com(0x08);    /*ÏÔʾ¹Ø±Õ*/
   LCD_Write_Com(0x01);    /*ÏÔʾÇåÆÁ*/
   LCD_Write_Com(0x06);    /*ÏÔʾ¹â±êÒÆ¶¯ÉèÖÃ*/
   Delay_Ms(5);
   LCD_Write_Com(0x0C);    /*ÏÔʾ¿ª¼°¹â±êÉèÖÃ*/
void Init_Timer1(void)
TMOD |= 0x10;
EA=1;
ET1=1;
TR1=1;
void Init_Timer0(void)
        TMOD= 0x10|0x04;
        EA = 1;
        ET0=1;
        TR0 = 1;
void main()
        int Tmp,v;
        float Temp;
        LCD_Init();
        Delay_Ms(20);
        LCD_Clear();
        Init_Timer1();
        while(1)
                if(ReadTmpFlag == 1)
                        ReadTmpFlag = 0;
                        Tmp = ReadTemperature();
                        Temp=(float)Tmp*0.0625;
                        sprintf(dat_t,"%2.0f",Temp);
                        LCD_Write_String(0x80,dat_t);
            LCD_Write_Char(0x82,0xDF);
                        LCD_Write_Char(0x83,'C');
                if(ReadRHFlag ==1)
                                Init_Timer0();
                        ReadRHFlag = 0;
                        if((dat_s[2]==dat_t[0])&&(dat_s[3]==dat_t[1]))
                                LCD_Write_Char(0xC0,dat_s[0]);
                                LCD_Write_Char(0xC1,dat_s[1]);
                                LCD_Write_Char(0xC2,'%');
                        else
                                LCD_Write_String(0x86,"Error");
                                LCD_Write_Char(0x8b,dat_s[0]);
                                LCD_Write_Char(0x8c,dat_s[1]);
                                LCD_Write_Char(0x8e,'2');
                                LCD_Write_Char(0x8f,'3');
                if(ReadVFlag==1)
                        ReadVFlag = 0;
                        v = v*5;                        //1s
                        sprintf(dat_v,"%2.0f",dat_v);
                        LCD_Write_String(0xC5,dat_v);
                        LCD_Write_String(0xCA,"m/s");
                        TR0=1;
                        ET0=1;
void Timer0() interrupt 1
        OVERFLOWFLAG;
        TH0 = 0;
        TL0 = 0;
void Timer1() interrupt 3
        static uint counter;
        counter++;
        TH0 = (65536-10000)/256;
        TL0 = (65536-10000)%256;
        if(counter == 10)
                ReadTmpFlag = 1;
        if(counter == 50)
                ReadRHFlag =1;
        if(counter == 200)//2000ms=2s
                ET0 =1;
                TR0 = 1;
                ReadVFlag =1;
                TH0 = 0x00;
                TL0 = 0x00;
        if(counter == 220)
                counter =0;
                TR0=0;
                ET0=0;
airwill 发表于 2019-11-26 21:47 | 显示全部楼层
估计是时序问题的可能性大,  先检查一下吧
ZHMSGE 发表于 2019-11-27 16:28 | 显示全部楼层
自己慢慢调试,估计没人帮得了你
