用混杂设备实现的Mini6410 LED驱动程序:
 楼主| caoqing1314 发表于 2011-11-25 21:18 | 显示全部楼层 |阅读模式
#include <linux/miscdevice.h>
#include <linux/delay.h>
#include <asm/irq.h>
#include <mach/hardware.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/init.h>
#include <linux/mm.h>
#include <linux/fs.h>
#include <linux/types.h>
#include <linux/moduleparam.h>
#include <linux/slab.h>
#include <linux/errno.h>
#include <linux/ioctl.h>
#include <linux/cdev.h>
#include <linux/string.h>
#include <linux/list.h>
#include <linux/pci.h>
#include <asm/uaccess.h>
#include <asm/atomic.h>
#include <asm/unistd.h>
#include <mach/map.h>
#include <mach/regs-clock.h>
#include <mach/regs-gpio.h>
#include <plat/gpio-cfg.h>
#include <mach/gpio-bank-e.h>
#include <mach/gpio-bank-k.h>
#define DEVICE_NAME "leds"
static long sbc2440_leds_ioctl(struct file *filp, unsigned int cmd, unsigned long arg)
    switch(cmd) {
        unsigned tmp;
    case 0:
    case 1:
        if (arg > 4) {
            return -EINVAL;
        tmp = readl(S3C64XX_GPKDAT);
        tmp &= ~(1 << (4 + arg));
        tmp |= ( (!cmd) << (4 + arg) );
        writel(tmp, S3C64XX_GPKDAT);
        //printk (DEVICE_NAME": %d %d\n", arg, cmd);
        return 0;
    default:
        return -EINVAL;
static struct file_operations dev_fops = {
    .owner          = THIS_MODULE,
    .unlocked_ioctl = sbc2440_leds_ioctl,
static struct miscdevice misc = {
    .minor = MISC_DYNAMIC_MINOR,
    .name = DEVICE_NAME,
    .fops = &dev_fops,
static int __init dev_init(void)
    int ret;
        unsigned tmp;
        tmp = readl(S3C64XX_GPKCON);
        tmp = (tmp & ~(0xffffU<<16))|(0x1111U<<16);
        writel(tmp, S3C64XX_GPKCON);
        tmp |= (0xF << 4);
    ret = misc_register(&misc);
    printk (DEVICE_NAME"\tinitialized\n");
    return ret;
static void __exit dev_exit(void)
    misc_deregister(&misc);
module_init(dev_init);
module_exit(dev_exit);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("muge0913");
