[MSP430] 用G2553的三线SPI通信,没有有门控信号EN???
 楼主| niubohuaii 发表于 2019-12-12 20:39 | 显示全部楼层 |阅读模式
一般的SPI三线通信不是需要有门控信号EN吗·········看手册G2553的三线是主线,从线和时钟线,这怎么搞
是使用MISO代替 门控信号EN  吗,如果是 我看SPI方面的寄存器也没有特别说明啊····????????向大佬们指教
dirtwillfly 发表于 2019-12-12 21:56 | 显示全部楼层
msp430g系列上叫UCxSTE,记得P1.5和P1.4分别是UCA0和UCB0做spi功能时的从设备使能
 楼主| niubohuaii 发表于 2019-12-13 09:40 | 显示全部楼层
If data is written into UCxTXBUF while the master is held inactive by UCxSTE, it will be transmitted as
soon as UCxSTE transitions to the master-active state. If an active transfer is aborted by UCxSTE
transitioning to the master-inactive state, the data must be re-written into UCxTXBUF to be transferred
when UCxSTE transitions back to the master-active state. The UCxSTE input signal is not used in 3-pin master mode.
这是手册上的原话,最后一句说3线不用UCxCTE,难道我理解的不对吗·····
一路向北lm 发表于 2019-12-13 09:52 | 显示全部楼层
没有 EN 就是直接使能了啊
dirtwillfly 发表于 2019-12-13 13:01 | 显示全部楼层
If data is written into UCxTXBUF while the master is held inactive by UCxSTE, it will be transmitt ...
你的理解没错。msp430的三线制不使用UCxCTE,从设备的使能引脚直接接到相应的电平就可以了。
好的,谢谢  发表于 2019-12-13 15:36
 楼主| niubohuaii 发表于 2019-12-13 15:36 | 显示全部楼层
没有 EN 就是直接使能了啊
谢谢
