- // TI File $Revision: /Final ok version for SH's EVM board/ (Jack's remark: This is Dale's code, better than me)
- // FILE: ADS8556-6ch.c
- // TITLE: Test ADS8556 for total 6 channels.
- // DESCRIPTION:
- #include "DSP28x_Project.h"
- #define BUF_6CH 6
- #define BUF_Times 48
- #define Result_total 288
- #pragma DATA_SECTION(ADS8556_Result,"DMARAML6");
- #pragma DATA_SECTION(ADS8556_Buf,"ZONE6DATA");
- volatile Uint16 ADS8556_Result[Result_total];
- volatile Uint16 ADS8556_Buf[BUF_6CH];
- volatile Uint16 *ADCDest;
- volatile Uint16 *ADCSource;
- volatile Uint16 m;
- volatile Uint16 INT_Flag; // INT finish flag
- void Gpio_setup1(void);
- void init_zone6(void);
- void delay_loop(void);
- void delay_short(void);
- interrupt void xint1_isr(void);
- void main(void)
- Uint16 i;
- Uint16 j;
- // Step 1. Initialize System Control:
- // PLL, WatchDog, enable Peripheral Clocks
- // This example function is found in the DSP2833x_SysCtrl.c file.
- InitSysCtrl();
- // Step 2. Clear all interrupts and initialize PIE vector table:
- // Disable CPU interrupts
- DINT;
- // Initialize PIE control registers to their default state.
- // The default state is all PIE interrupts disabled and flags
- // are cleared.
- // This function is found in the DSP2833x_PieCtrl.c file.
- InitPieCtrl();
- // Disable CPU interrupts and clear all CPU interrupt flags:
- IER = 0x0000;
- IFR = 0x0000;
- // Initialize the PIE vector table with pointers to the shell Interrupt
- // Service Routines (ISR).
- // This will populate the entire table, even if the interrupt
- // is not used in this example. This is useful for debug purposes.
- // The shell ISR routines are found in DSP2833x_DefaultIsr.c.
- // This function is found in DSP2833x_PieVect.c.
- InitPieVectTable();
- // Interrupts that are used in this example are re-mapped to
- // ISR functions found within this file.
- EALLOW; // This is needed to write to EALLOW protected registers
- PieVectTable.XINT1 = &xint1_isr; // For ADS8556
- EDIS; // This is needed to disable write to EALLOW protected registers
- // Step 3. Initialize all the Device Peripherals:
- // This function is found in DSP2833x_InitPeripherals.c
- // InitPeripherals(); // Not required for this example
- // Step 4. User specific code:
- Gpio_setup1(); // For ADS8556
- // Initalize XINTF Zone
- init_zone6(); // For ADS8556
- //// InitXintf(); // Not required for this program
- // Initialize Tables
- for (i=0; i<BUF_6CH; i++)
- ADS8556_Buf[i] = i;
- for (j=0; j<Result_total; j++)
- ADS8556_Result[j] = j;
- // Enable Xint1 and XINT2 in the PIE: Group 1 interrupt 4 & 5
- PieCtrlRegs.PIECTRL.bit.ENPIE = 1;
- PieCtrlRegs.PIEIER1.bit.INTx4 = 1;
- // PieCtrlRegs.PIEIER1.bit.INTx5 = 1;
- IER |= M_INT1;
- EINT;
- // F28335's GPIO12(for ADS8556) is interrupt input for XINT1
- EALLOW;
- GpioCtrlRegs.GPAMUX1.bit.GPIO12 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO12 = 0;
- GpioCtrlRegs.GPAQSEL1.bit.GPIO12=0;
- GpioCtrlRegs.GPACTRL.bit.QUALPRD1=0xFF;
- EDIS;
- EALLOW;
- GpioIntRegs.GPIOXINT1SEL.bit.GPIOSEL = 12;
- EDIS;
- XIntruptRegs.XINT1CR.bit.POLARITY = 0;
- XIntruptRegs.XINT1CR.bit.ENABLE = 1;
- // Step 5. Configure and main loop
- INT_Flag = 0;
- ADCDest = &ADS8556_Result[0];
- ADCSource = &ADS8556_Buf[0];
- GpioDataRegs.GPASET.bit.GPIO7 = 1;
- delay_loop();
- GpioDataRegs.GPACLEAR.bit.GPIO7 = 1;
- for(;;)
- for(m=0; m<BUF_Times; m++)
- GpioDataRegs.GPASET.bit.GPIO13 = 1; // Load output latch
- delay_short();
- while(INT_Flag == 0) { }
- INT_Flag = 0;
- delay_short();
- //Just sit and loop forever (optional):
- // for(;;);
- // Step 6. Insert all local Interrupt Service Routines (ISRs) and functions here:
- // If local ISRs are used, reassign vector addresses in vector table as shown in Step
- unsigned char n;
- for (n=0; n<BUF_6CH; n++)
- *ADCDest++ = *ADCSource++;
- ADCDest= &ADS8556_Result[ m * 6];
- INT_Flag = 1;
- GpioDataRegs.GPACLEAR.bit.GPIO13 = 1; // Load output latch
- PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
- unsigned char j;
- unsigned char k;
- for( j = 100; j > 0; j--)
- for( k = 200; k > 0; k--);
- EALLOW;
- GpioCtrlRegs.GPAPUD.bit.GPIO15 = 0;
- GpioDataRegs.GPACLEAR.bit.GPIO15 = 1;
- GpioCtrlRegs.GPAMUX1.bit.GPIO15 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO15 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO14 = 0;
- GpioDataRegs.GPASET.bit.GPIO14 = 1;
- GpioCtrlRegs.GPAMUX1.bit.GPIO14 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO14 = 1;
- GpioCtrlRegs.GPBPUD.bit.GPIO48 = 0;
- GpioDataRegs.GPBCLEAR.bit.GPIO48 = 1;
- GpioCtrlRegs.GPBMUX2.bit.GPIO48 = 0;
- GpioCtrlRegs.GPBDIR.bit.GPIO48 = 1;
- GpioCtrlRegs.GPBPUD.bit.GPIO49 = 0;
- GpioDataRegs.GPBSET.bit.GPIO49 = 1;
- GpioCtrlRegs.GPBMUX2.bit.GPIO49 = 0;
- GpioCtrlRegs.GPBDIR.bit.GPIO49 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO7 = 0;
- GpioCtrlRegs.GPAMUX1.bit.GPIO7 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO7 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO5 = 0;
- GpioDataRegs.GPASET.bit.GPIO5 = 1;
- GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO5 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO6 = 0;
- GpioDataRegs.GPASET.bit.GPIO6 = 1;
- GpioCtrlRegs.GPAMUX1.bit.GPIO6 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO6 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO16 = 0;
- GpioDataRegs.GPACLEAR.bit.GPIO16 = 1;
- GpioCtrlRegs.GPAMUX2.bit.GPIO16 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO16 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO17 = 0;
- GpioDataRegs.GPACLEAR.bit.GPIO17 = 1;
- GpioCtrlRegs.GPAMUX2.bit.GPIO17 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO17 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO18 = 0;
- GpioDataRegs.GPACLEAR.bit.GPIO18 = 1;
- GpioCtrlRegs.GPAMUX2.bit.GPIO18 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO18 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO19 = 0;
- GpioDataRegs.GPASET.bit.GPIO19 = 1;
- GpioCtrlRegs.GPAMUX2.bit.GPIO19 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO19 = 1;
- GpioCtrlRegs.GPAPUD.bit.GPIO13 = 0;
- GpioCtrlRegs.GPAMUX1.bit.GPIO13 = 0;
- GpioCtrlRegs.GPADIR.bit.GPIO13 = 1;
- // Make sure the XINTF clock is enabled
- SysCtrlRegs.PCLKCR3.bit.XINTFENCLK = 1;
- // Configure the GPIO for XINTF with a 16-bit data bus
- // This function is in DSP2833x_Xintf.c
- InitXintf16Gpio();
- EALLOW;
- // All Zones---------------------------------
- // Timing for all zones based on XTIMCLK = 1/2 SYSCLKOUT
- XintfRegs.XINTCNF2.bit.XTIMCLK = 1; // 0 XTIMCLK = SYSCLKOUT
- // Buffer up to 3 writes
- XintfRegs.XINTCNF2.bit.WRBUFF = 3;
- // XCLKOUT is enabled
- XintfRegs.XINTCNF2.bit.CLKOFF = 0;
- // XCLKOUT = XTIMCLK/2
- XintfRegs.XINTCNF2.bit.CLKMODE = 1; // 0 XCLKOUT = XTIMCLK
- // Zone 6------------------------------------
- // When using ready, ACTIVE must be 1 or greater
- // Lead must always be 1 or greater
- // Zone write timing
- XintfRegs.XTIMING6.bit.XWRLEAD = 3;
- XintfRegs.XTIMING6.bit.XWRACTIVE = 7;
- XintfRegs.XTIMING6.bit.XWRTRAIL = 7;
- // Zone read timing
- XintfRegs.XTIMING6.bit.XRDLEAD = 3; //1
- XintfRegs.XTIMING6.bit.XRDACTIVE = 7; //3
- XintfRegs.XTIMING6.bit.XRDTRAIL = 3; //0
- // double all Zone read/write lead/active/trail timing
- XintfRegs.XTIMING6.bit.X2TIMING = 1; // 0 - don't
- // Zone will not sample XREADY signal
- XintfRegs.XTIMING6.bit.USEREADY = 0;
- XintfRegs.XTIMING6.bit.READYMODE = 0;
- // 1,1 = x16 data bus
- // 0,1 = x32 data bus
- // other values are reserved
- XintfRegs.XTIMING6.bit.XSIZE = 3;
- EDIS;
- //Force a pipeline flush to ensure that the write to
- //the last register configured occurs before returning.
- asm(" RPT #7 || NOP");
- unsigned char j;
- unsigned char k;
- for( j = 10; j > 0; j--)
- for( k = 225; k > 0; k--);
- // No more.
复制代码
