void KeyDriver(void)
static u8 i=0;
if(flag_40ms)
flag_40ms=0;
Set_KeyReturnValue = Set_ReadKeyStatus();
Query_KeyReturnValue = Query_ReadKeyStatus();
Both_KeyReturnValue = Both_ReadKeyStatus();
switch(Query_KeyReturnValue)
case 0:break;
case 1:
Query_KeyReturnValue = 0;
if(WarnPriority == 0)//按键声响
BzWarnTime(180);
if(setIndex == 0)//SET按键未按下时,轮询显示
if(++cnt_location>tire_num)
cnt_location = 1;//位置
if(setIndex == 1)//低压阈值设置
ThresholdParam.low_press_value++;
if(ThresholdParam.low_press_value > 70)//考斯特低压50-70bar,海狮20-35
ThresholdParam.low_press_value = 50;//测试1-2bar
FlashWriteByte(THRESOLD_ADDR_BASE + 1,ThresholdParam.low_press_value);
if(setIndex == 2)//高压阈值设置
ThresholdParam.high_press_value++;
if(ThresholdParam.high_press_value > 120)//考斯特高压100-120bar,海狮40-60
ThresholdParam.high_press_value = 100;//测试3-4bar,考斯特110
FlashWriteByte(THRESOLD_ADDR_BASE + 0,ThresholdParam.high_press_value);
if(setIndex == 3)
++i;
i%=4;
tire_num=tire_num_x[i];
FlashWriteByte(THRESOLD_ADDR_BASE + 3,tire_num);
if(setIndex > 3)//轮胎换位----待调试
if(++sensorNum2 > tire_num)
sensorNum2 = 1;
break;
case 2:
BzWarnTime(1000);
break;
default:break;
switch(Set_KeyReturnValue)
case 0:break;
case 1:
Set_KeyReturnValue = 0;
BzWarnTime(180);
if(setIndex)
setIndex++;
if(setIndex > 3+tire_num)
setIndex = 0;
WheelLocationChange(sensorNum1,sensorNum2);
if(setIndex > 3)
if(setIndex == 4)
cnt_location = 1;//胎位显示
sensorNum1 = SearchIDSerial(cnt_location);//传感器号
sensorNum2 = sensorNum1;
else
cnt_location++;
if(sensorNum2 != sensorNum1)
break;
case 2:
BzWarnTime(1000);
if(setIndex == 0)
setIndex = 1;//进入低压设置
ThresholdParam.high_press_value = FlashReadByte(THRESOLD_ADDR_BASE + 0);//高压阈值
ThresholdParam.low_press_value = FlashReadByte(THRESOLD_ADDR_BASE + 1);//低压阈值
break;
default:break;
switch(Both_KeyReturnValue)
case 0:break;
case 1:
Both_KeyReturnValue = 0;
BzWarnTime(180);
break;
case 2:
BzWarnTime(1000);
SysReset();
break;
default:break;
/*中断处理函数*/
void interrupt isrfuction(void)
static int16u Sys_Counter = 0,count=0,cnt1=0;
int8u i ;
Watchdog_Reset();
if(TMR0IF && TMR0IE)
TMR0IF = 0;
TMR0 = 100;//156 即定时时间为20ms
//Set_KeyReturnValue = Set_ReadKeyStatus();
//Query_KeyReturnValue = Query_ReadKeyStatus();
//Both_KeyReturnValue = Both_ReadKeyStatus();
if(BZen)
if(++warncnt >= WaringTime)
warncnt = 0;
BZen = 0;
WarnPriority = 0;
if( 0x00 == warncnt%25)
Bz_Flag ^= 0x01;
if (++Sys_Counter >= 60000) //每20分钟重置.计数器
Sys_Counter = 0x0000;
if(0x00 == Sys_Counter%2)//40ms
flag_40ms=1;
if(setIndex > 2)
if(0x00 == Sys_Counter % 25)
LcdSharkflag = !LcdSharkflag;
if(0x00 == Sys_Counter%400)//8s
if(setIndex == 0)
if(++cnt_location>tire_num)//按键选择胎位数
cnt_location = 1;
if (0x00==Sys_Counter%3000)
{//每1min
SETBIT(Time_Flag1,TF1_1min_bit);//置位1分钟标志
if (0x00==Sys_Counter%6000)
SETBIT(Time_Flag1,TF1_2min_bit);
if(0X00 == Sys_Counter % 15000) //15000
{//(5m)
for(i = 0;i <tire_num;i++)//将Tire_num_x改为tire_num
if((LockInf[i].Flag_reveive_first == 1)&&(LockInf[i].LockStatus != 0x55))//有接收到数据后开始判断
Start_Time_Num[i]++;
if(Start_Time_Num[i] >=3)//30分钟6,测试1
if(First_30min_Flag[i])//第二次,30分钟后
SETBIT(LockInf[i].sys_time_learn,Second_30min_Bit);//第二个周期结束
Start_Time_Num[i]=0;
else//第一次
SETBIT(LockInf[i].sys_time_learn,First_30min_Bit);//第一个周期结束
if(TESTBIT(LockInf[i].sys_time_learn,First_30min_Bit))//第一个周期结束
First_30min_Flag[i]=1;//30分钟置一
else
First_30min_Flag[i]=0;
if( IOCBF0 && IOCIE )
if( INTF && INTE )
INTF=0;
TDA523x_int=1;
u8 Set_ReadKeyStatus(void)
static KeyStatus SetState = Set_NoKeyDownStatus;
static u16 TimeCount = 0;
u8 KeyReturnSet = 0; //返回值状态一定不能为静态变量,确保每次进入中断时清零
switch(SetState)
/*没有按键按下*/
case Set_NoKeyDownStatus:
if(!KEYSET && KEYQUERY) //如果按键被按下时,等待进入确认状态。KeyDown = 0 代表按键按下,=1代表按键弹起
SetState = Set_KeySureDownStatus ;
break;
/*按键确认(按键消抖)*/
case Set_KeySureDownStatus:
//KeyReturnSet = 1;
SetState = Set_OnceKeyDownStatus ;
TimeCount = 0;
else
SetState = Set_NoKeyDownStatus ;
break;
/*等待按键释放*/
case Set_OnceKeyDownStatus:
if(KEYSET && KEYQUERY)//按键弹起
KeyReturnSet = 1;
//TimeCount = 0;
else //5.28改
if(++TimeCount >= (LONGSETKEYTIME/INTERRUPTTIME))//计满Xs后进入长按状态
SetState = Set_LongKeyDownStatus;
KeyReturnSet = 2;
TimeCount = 0;
break;
case Set_LongKeyDownStatus:
break;
default:break;
return KeyReturnSet;
/*此程序放置于中断程序中(中断时间20ms)*/
u8 Query_ReadKeyStatus(void)
static KeyStatus QueryState = Query_NoKeyDownStatus;
u8 KeyReturnQuery = 0;//返回值状态一定不能为静态变量,确保每次进入中断时清零
switch(QueryState)
/*没有按键按下*/
case Query_NoKeyDownStatus:
if(!KEYQUERY && KEYSET) //如果按键被按下时,等待进入确认状态。KeyDown = 0 代表按键按下,=1代表按键弹起
QueryState = Query_KeySureDownStatus ;
break;
/*按键确认(按键消抖)*/
case Query_KeySureDownStatus:
QueryState = Query_OnceKeyDownStatus ;
TimeCount = 0;
else
QueryState = Query_NoKeyDownStatus ;
break;
/*等待按键释放*/
case Query_OnceKeyDownStatus:
if(KEYQUERY && KEYSET)//按键弹起
KeyReturnQuery = 1;
//TimeCount = 0;
else
QueryState = Query_LongKeyDownStatus;
KeyReturnQuery = 2;
TimeCount = 0;
break;
case Query_LongKeyDownStatus:
break;
default:break;
return KeyReturnQuery;
u8 Both_ReadKeyStatus(void)
static KeyStatus BothState = Both_NoKeyDownStatus;
u8 KeyReturnBoth = 0;//返回值状态一定不能为静态变量,确保每次进入中断时清零
switch(BothState)
/*没有按键按下*/
case Both_NoKeyDownStatus:
if((!KEYQUERY)&&(!KEYSET)) //如果按键被按下时,等待进入确认状态。KeyDown = 0 代表按键按下,=1代表按键弹起
BothState = Both_KeySureDownStatus ;
break;
/*按键确认(按键消抖)*/
case Both_KeySureDownStatus:
BothState = Both_OnceKeyDownStatus ;
TimeCount = 0;
else
BothState = Both_NoKeyDownStatus ;
break;
/*等待按键释放*/
case Both_OnceKeyDownStatus:
if(KEYQUERY || KEYSET)//按键弹起
KeyReturnBoth = 1;
//TimeCount = 0;
else
BothState = Both_LongKeyDownStatus;
KeyReturnBoth = 2;
TimeCount = 0;
break;
case Both_LongKeyDownStatus:
break;
default:break;
return KeyReturnBoth;
