[MM32软件] 【MM32 eMiniBoard测评报告】+ MAX7219
 楼主| Cjy_JDxy 发表于 2020-4-20 19:18 | 显示全部楼层 |阅读模式
今晚搞了一下MAX7219.
DIN:PC13
LOAD:PC14
CLK:PC15
3.jpg 代码:
#include "delay.h"
#include "sys.h"
#include "led.h"
#define uchar unsigned char
#define uint unsigned int
#define CLK_0           GPIO_ResetBits(GPIOC,GPIO_Pin_15)
#define CLK_1           GPIO_SetBits(GPIOC,GPIO_Pin_15)
#define LOAD_0          GPIO_ResetBits(GPIOC,GPIO_Pin_14)
#define LOAD_1          GPIO_SetBits(GPIOC,GPIO_Pin_14)
#define DIN_0           GPIO_ResetBits(GPIOC,GPIO_Pin_13)
#define DIN_1           GPIO_SetBits(GPIOC,GPIO_Pin_13)
#define NoOp   0x00           //??????
#define Digit0 0x01           // ???1???
#define Digit1 0x02           // ???2???
#define Digit2 0x03           // ???3???
#define Digit3 0x04           // ???4???
#define Digit4 0x05           // ???5???
#define Digit5 0x06           // ???6???
#define Digit6 0x07           // ???7???
#define Digit7 0x08           // ???8???
#define DecodeMode 0x09       // ???????
#define Intensity 0x0a        // ?????
#define ScanLimit 0x0b        // ???????
#define ShutDown 0x0c         // ????????
#define DisplayTest 0x0f      // ???????
#define ShutdownMode 0x00     // ?????
#define NormalOperation 0x01  // ??????
#define ScanDigit 0x07        // ??????,??8????
#define DecodeDigit 0xff      // ????,8???BCD?
#define IntensityGrade 0x0a   // ??????
#define TestMode 0x01         // ??????
#define TextEnd 0x00          // ??????,????????
* Function implementation - global ('extern') and local ('static')
uchar DisBuffer[8]={0,0,0,0,0,0,0,0};    // ?????
//******************??t??**************************************
void delay(uint t)
       uint i;
       while(t--)
              /* ??12M??,???1ms */
              for (i=0;i<125;i++)
//*************?MAX7219????(8?)********************
void SendChar (uchar ch)
    uchar i,temp;
    delay(1);
    for (i=0;i<8;i++)
         temp=ch&0x80;
         ch=ch<<1;
         if(temp)
            DIN_1;
            CLK_0;
            CLK_1;
         else
            DIN_0;
            CLK_0;
            CLK_1;
//**************?MAX7219???(16?)*****************************
void WriteWord (uchar addr,uchar num)
    LOAD_0;
    delay(1);
    SendChar(addr);
    delay(1);
    SendChar(num);
    delay(1);
    LOAD_1;                            // ????????
//*********************** MAX7219??? ******************
void InitDisplay (void)
    WriteWord (ScanLimit,ScanDigit);         // ??????
    WriteWord (DecodeMode,DecodeDigit);      // ??????
    WriteWord (Intensity,IntensityGrade);    // ????
    WriteWord (ShutDown,NormalOperation);    // ?????????
**º¯ÊýÐÅÏ¢ £ºmain(void)
**¹¦ÄÜÃèÊö £º
**ÊäÈë²ÎÊý £ºÎÞ
**Êä³ö²ÎÊý £ºÎÞ
int main(void)
    delay_init();
    LED_Init();
                InitDisplay (); // MAX7219???
    WriteWord(DisplayTest,TestMode);  // ??????,????LED
    delay(1500);                      // ???1.5s
    WriteWord (DisplayTest,TextEnd);  // ????????
    WriteWord (Digit0,0);
    WriteWord (Digit1,1);
    WriteWord (Digit2,2);
    WriteWord (Digit3,3);
    while(1)              //ÎÞÏÞÑ­»·
        LED1_TOGGLE();
        LED2_TOGGLE();
        LED3_TOGGLE();
        LED4_TOGGLE();
        delay_ms(300);
效果图:
工程:
MAX7219.rar (321.15 KB, 下载次数: 2)
gaoyang9992006 发表于 2020-4-21 23:04 | 显示全部楼层
7219不错,从前我也特备喜欢用。
个人签名:绿水本无忧因风皱面,青山原不老为雪白头。
553
