一, 打开文件(可以随文下载放置在文档中打开)。(如下图1所示)
图1
二,调整虚拟器件,另存工程文件。(如下图2,3所示)
图2
图3
三,点击Source Code标签。(如下图4所示)
图4
四,编辑main.c, wwdg.c,wwdg.h, key.c,key.h, led.c,led.h 代码如Proteus8.9 仿真STM32407ZGT6系列001(如下图5所示)
图5
五,Main.c 代码:
#include "stm32f4xx_conf.h"
#include "sys.h"
#include "delay.h"
#include "usart.h"
#include "led.h"
#include "key.h"
#include "wwdg.h"
int main (void)
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
delay_init(168); //初始化延时函数
uart_init(115200); //串口初始化
LED_Init(); //初始化LED端口
LED0=1; //先点亮灯
LED1=1; //先点亮灯
delay_ms(300);
LED0=0; //先点亮灯
LED1=0; //先点亮灯
delay_ms(300);
WWDG_Init(0x7F,0X5F,WWDG_Prescaler_8); //计数器值为7f,窗口寄存器为5f,分频数为8
while(1)
if(SET==KEY0){
//LED0=~LED0; //先点亮灯
WWDG_IRQHandler();
LED1=~LED1; //先点亮灯
delay_ms(500);
LED1=~LED1; //先点亮灯
delay_ms(500);
wwdg.c代码:
#include "wwdg.h"
#include "led.h"
#include "delay.h"
u8 WWDG_CNT=0X7F;
void WWDG_Init(u8 tr,u8 wr,u32 fprer)
NVIC_InitTypeDefNVIC_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG,ENABLE);
WWDG_CNT=tr&WWDG_CNT;
WWDG_SetPrescaler(fprer);
WWDG_SetWindowValue(wr);
WWDG_SetCounter(WWDG_CNT);
WWDG_Enable(WWDG_CNT);
NVIC_InitStructure.NVIC_IRQChannel=WWDG_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x02;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=0x03;
NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
NVIC_Init(&NVIC_InitStructure);
WWDG_ClearFlag();
WWDG_EnableIT();
void WWDG_IRQHandler(void)
LED0=~LED0;
delay_ms(500);
WWDG_ClearFlag();
LED1=~LED1;
wwdg.h代码:
#ifndef _WWDG_H
#define _WWDG_H
#include "sys.h"
void WWDG_Init(u8 tr,u8 wr,u32 fprer);
void WWDG_IRQHandler(void);
#endif
led.c代码:
#include "led.h"
void LED_Init(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);//使能GPIOB时钟
//GPIOF9,F10初始化设置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6| GPIO_Pin_8;//LED对应引脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化
led.h代码:
#ifndef __LED_H
#define __LED_H
#include "sys.h"
//LED端口定义
#define LED0 PBout(6) // LED0
#define LED1 PBout(8) // LED1
void LED_Init(void);//初始化
#endif
key.c代码:
#include "key.h"
#include "delay.h"
void KEY_Init(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);//使能GPIOB时钟
GPIO_InitStructure.GPIO_Pin= GPIO_Pin_3; //KEY0 对应引脚
GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN;//普通输入模式
GPIO_InitStructure.GPIO_Speed= GPIO_Speed_100MHz;//100M
GPIO_InitStructure.GPIO_PuPd= GPIO_PuPd_DOWN ;//下拉
GPIO_Init(GPIOB,&GPIO_InitStructure);//初始化GPIOE4
key.h代码:
#ifndef __KEY_H
#define __KEY_H
#include "sys.h"
#define KEY0 PBin(3) //PB3
void KEY_Init(void); //IO初始化
#endif
六,点击构建工程按钮,编译工程。(如下图6所示)
图6
七,点击窗口左下方仿真按钮,可见黄灯点亮仿真,按下按钮,进行喂狗,开始跳闪仿真。 (如下图7,8,9所示)
图7
图8
图9
八,选择release,点击构建工程按钮,编译工程生成Hex文件。(如下图10所示)
图10
九, 系列的001-003虚拟仿真与开发板对应已证明:虚拟仿真程序对于开发板有效,之后不再➕上下载到开发板的介绍。
需要进一步了解,请加入QQ群:976235464
