BMP085是一款可测量气温、气压的I2C器件,它具有体积小、易于使用的特点。
BH1750与MCU的连接关系为: SCL——PA7 SDA——PA8
为使 BMP085有效工作,所作的相关定义语句如下: #define SCL_Set() GPIO_SetPinBits(GPIO_PA7) // PA7 #define SCL_Clr() GPIO_ResetPinBits(GPIO_PA7)
#define SDA_Set() GPIO_SetPinBits(GPIO_PA8) // PA8 #define SDA_Clr() GPIO_ResetPinBits(GPIO_PA8) #define IIC_SDA_IN GPIO_GetPinValue(GPIO_PA8)
#define IIC_INPUT_MODE_SET() GPIO_SetDir(GPIO_PA8, 0) #define IIC_OUTPUT_MODE_SET() GPIO_SetDir(GPIO_PA8, 1)
使 BMP085工作的辅助函数有: - void BMP085_Start(void)
- IIC_OUTPUT_MODE_SET();
- SDA_Set();
- SCL_Set();
- udelay(5);
- SDA_Clr();
- udelay(5);
- SCL_Clr();
- void BMP085_Stop(void)
- SDA_Clr();
- SCL_Clr();
- udelay(5);
- SCL_Set();
- udelay(5);
- SDA_Set();
- udelay(5);
读取气温的函数为: - long bmp085ReadTemp(void)
- BMP085_Start();
- BMP085_Send_Byte(BMP085_SlaveAddress);
- while(BMP085_Wait_Ack()){}
- BMP085_Send_Byte(0xF4);
- BMP085_Send_Byte(0x2E);
- BMP085_Stop();
- mdelay(10);
- return (long) Multiple_read(0xF6);
读取气压的函数为: - long bmp085ReadPressure(void)
- long pressure = 0;
- BMP085_Start();
- BMP085_Send_Byte(0x34);
- BMP085_Stop();
- mdelay(10);
- pressure = Multiple_read(0xF6);
- pressure &= 0x0000FFFF;
- return pressure;
BMP085的初始化函数为: - void Init_BMP085()
- ac1 = Multiple_read(0xAA);
- ac2 = Multiple_read(0xAC);
- ac3 = Multiple_read(0xAE);
- ac4 = Multiple_read(0xB0);
- ac5 = Multiple_read(0xB2);
- ac6 = Multiple_read(0xB4);
- b1 = Multiple_read(0xB6);
- b2 = Multiple_read(0xB8);
- mb = Multiple_read(0xBA);
- mc = Multiple_read(0xBC);
- md = Multiple_read(0xBE);
BMP085数值转换函数为: - void bmp085Convert()
- unsigned int ut;
- unsigned long up;
- long x1, x2, b5, b6, x3, b3, p;
- unsigned long b4, b7;
- ut = bmp085ReadTemp();
- up = bmp085ReadPressure();
- x1 = (((long)ut - (long)ac6)*(long)ac5) >> 15;
- x2 = ((long) mc << 11) / (x1 + md);
- b5 = x1 + x2;
- temperature = ((b5 + 8) >> 4);
- b6 = b5 - 4000;
- x1 = (b2 * (b6 * b6)>>12)>>11;
- x2 = (ac2 * b6)>>11;
- x3 = x1 + x2;
- b3 = (((((long)ac1)*4 + x3)<<OSS) + 2)>>2;
- x1 = (ac3 * b6)>>13;
- x2 = (b1 * ((b6 * b6)>>12))>>16;
- x3 = ((x1 + x2) + 2)>>2;
- b4 = (ac4 * (unsigned long)(x3 + 32768))>>15;
- b7 = ((unsigned long)(up - b3) * (50000>>OSS));
- if (b7 < 0x80000000)
- p = (b7<<1)/b4;
- else
- p = (b7/b4)<<1;
- x1 = (p>>8) * (p>>8);
- x1 = (x1 * 3038)>>16;
- x2 = (-7357 * p)>>16;
- pressure = p+((x1 + x2 + 3791)>>4);
实现图示效果的主函数为: - int main(void)
- InitDebug();
- InitDelay();
- OLED_Init();
- OLED_Clear();
- OLED_ShowString(0,0,"AC8711 TEST",16);
- OLED_ShowString(0,2,"BMP085",16);
- OLED_ShowString(0,4,"t= C",16);
- OLED_ShowString(0,6,"p= KPa",16);
- BMP085_Init();
- Init_BMP085();
- while(1)
- bmp085Convert();
- printf("temperature: %d C\r\n", temperature/10);
- printf("pressure: %d KPa\r\n", pressure/100);
- OLED_ShowNum(24,4,temperature/10,3,16);
- OLED_ShowNum(24,6,pressure/100,5,16);
- mdelay(1000);
BMP085测量效果
