求大神赐教,为什么我用USART2的DMA方式接收不到外部一模块发送来的数据,USART2应该怎样与外部模块的串口线相连啊。
下面是我对USART2的配置,求大神指点哪里出错了,还是我的硬件连接错了:
void USART2_Config(void)
USART_InitTypeDef USART_InitStructure;
GPIO_PinRemapConfig(GPIO_Remap_USART2, ENABLE);
/* config USART2 clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
/* USART2 GPIO config */
/* Configure USART2 Tx (PA.02) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure USART2 Rx (PA.03) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USART2 mode config */
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No ;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART2, &USART_InitStructure);
USART_Cmd(USART2, ENABLE);
* @brief USART2 TX DMA 配置
* @param 无
* @retval 无
void USART2_DMA_Config(void)
DMA_InitTypeDef DMA_InitStructure;
/*开启DMA时钟*/
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
//NVIC_Config();
/*设置DMA源:串口数据寄存器地址*/
DMA_InitStructure.DMA_PeripheralBaseAddr = USART2_DR_Base;
/*内存地址(要传输的变量的指针)*/
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SendBuff;
//DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC;
/*方向:从外设到内存*/
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
/*传输大小DMA_BufferSize=SENDBUFF_SIZE*/
DMA_InitStructure.DMA_BufferSize = SENDBUFF_SIZE;
//DMA_InitStructure.DMA_BufferSize = 1;
/*外设地址不增*/
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
/*内存地址不变*/
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
/*外设数据单位*/
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
/*内存数据单位 8bit*/
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
//DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //半字
// DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
/*DMA模式:不断循环*/
// DMA_InitStructure.DMA_Mode = DMA_Mode_Normal ;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
/*优先级:中*/
DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;
/*禁止内存到内存的传输 */
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
/*配置DMA1的6通道*/
DMA_Init(DMA1_Channel6, &DMA_InitStructure);
/*使能DMA*/
DMA_Cmd (DMA1_Channel6,ENABLE);
// DMA_ITConfig(DMA1_Channel6,DMA_IT_TC,ENABLE); //配置DMA发送完成后产生中断
