问几个问题,在 SPI模块 章节的
 楼主| 白闻不如怡见 发表于 2018-7-4 14:02 | 显示全部楼层 |阅读模式
一,
#define countof(a)      (sizeof(a) / sizeof(*(a)))
#define  BufferSize (countof(Tx_Buffer)-1)
其中 “ -1 ”是什么意思? 是不是因为 “  ”
二,
在 SPI_FLASH_Init() 函数中
void SPI_FLASH_Init(void)
  SPI_InitTypeDef  SPI_InitStructure;
  /* Enable SPI1 and GPIO clocks */
  /*!< SPI_FLASH_SPI_CS_GPIO, SPI_FLASH_SPI_MOSI_GPIO,
       SPI_FLASH_SPI_MISO_GPIO, SPI_FLASH_SPI_DETECT_GPIO
       and SPI_FLASH_SPI_SCK_GPIO Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOD, ENABLE); // ??????????????
  /*!< SPI_FLASH_SPI Periph clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  /*!< Configure SPI_FLASH_SPI pins: SCK */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  /*!< Configure SPI_FLASH_SPI pins: MISO */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  /*!< Configure SPI_FLASH_SPI pins: MOSI */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  /*!< Configure SPI_FLASH_SPI_CS_PIN pin: SPI_FLASH Card CS pin */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  /* Deselect the FLASH: Chip Select high */
  SPI_FLASH_CS_HIGH();
  /* SPI1 configuration */
  // W25X16: data input on the DIO pin is sampled on the rising edge of the CLK.
  // Data on the DO and DIO pins are clocked out on the falling edge of CLK.
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI1, &SPI_InitStructure);
  /* Enable SPI1  */
  SPI_Cmd(SPI1, ENABLE);
其中为什么要使能GPIOD ? 我看没有用到GPIOD啊。
三,
在main() 函数中:
int main(void)
        /* 配置串口1为:115200 8-N-1 */
        USART1_Config();
        printf("
这是一个2M串行flash(W25X16)实验
        /* 2M串行flash W25X16初始化 */
        SPI_FLASH_Init();
        /* Get SPI Flash Device ID */
        DeviceID = SPI_FLASH_ReadDeviceID();
        Delay( 200 );
        /* Get SPI Flash ID */
        FlashID = SPI_FLASH_ReadID();
        printf("
FlashID is 0x%X,  Manufacturer Device ID is 0x%X
", FlashID, DeviceID);
        /* Check the SPI Flash ID */
        if (FlashID == sFLASH_ID)  /* #define  sFLASH_ID  0xEF3015 */
                printf("
检测到华邦串行flash W25X16 !
                /* Erase SPI FLASH Sector to write on */
                SPI_FLASH_SectorErase(FLASH_SectorToErase);
                /* 将发送缓冲区的数据写到flash中 */
                SPI_FLASH_BufferWrite(Tx_Buffer, FLASH_WriteAddress, BufferSize);
                printf("
写入的数据为:%s
        ", Tx_Buffer);
                /* 将刚刚写入的数据读出来放到接收缓冲区中 */
                SPI_FLASH_BufferRead(Rx_Buffer, FLASH_ReadAddress, BufferSize);
                printf("
读出的数据为:%s
", Tx_Buffer); // ??????????????
                /* 检查写入的数据与读出的数据是否相等 */
                TransferStatus1 = Buffercmp(Tx_Buffer, Rx_Buffer, BufferSize);
                if( PASSED == TransferStatus1 )
                        printf("
2M串行flash(W25X16)测试成功!
                else
                        printf("
2M串行flash(W25X16)测试失败!
        }// if (FlashID == sFLASH_ID)
        else
                printf("
获取不到 W25X16 ID!
        SPI_Flash_PowerDown();
        while(1);
我感觉应该把“ Tx_Buffer ”换成“ Rx_Buffer ”吧。
