关于HAL库串口结构体疑问
 楼主| Spikess 发表于 2018-7-27 20:24 | 显示全部楼层 |阅读模式
typedef struct
  USART_TypeDef            *Instance;        /*!< UART registers base address        */
  UART_InitTypeDef         Init;             /*!< UART communication parameters      */
  UART_AdvFeatureInitTypeDef AdvancedInit;   /*!< UART Advanced Features initialization parameters */
  uint8_t                  *pTxBuffPtr;      /*!< Pointer to UART Tx transfer Buffer */
  uint16_t                 TxXferSize;       /*!< UART Tx Transfer size              */
  uint16_t                 TxXferCount;      /*!< UART Tx Transfer Counter           */
  uint8_t                  *pRxBuffPtr;      /*!< Pointer to UART Rx transfer Buffer */
  uint16_t                 RxXferSize;       /*!< UART Rx Transfer size              */
  uint16_t                 RxXferCount;      /*!< UART Rx Transfer Counter           */
  uint16_t                 Mask;             /*!< UART Rx RDR register mask          */
  DMA_HandleTypeDef        *hdmatx;          /*!< UART Tx DMA Handle parameters      */
  DMA_HandleTypeDef        *hdmarx;          /*!< UART Rx DMA Handle parameters      */
  HAL_LockTypeDef          Lock;             /*!< Locking object                     */
  __IO HAL_UART_StateTypeDef    gState;      /*!< UART state information related to global Handle management
                                                  and also related to Tx operations.
                                                  This parameter can be a value of @ref HAL_UART_StateTypeDef */
  __IO HAL_UART_StateTypeDef    RxState;     /*!< UART state information related to Rx operations.
  __IO uint32_t             ErrorCode;       /*!< UART Error code                    */
}UART_HandleTypeDef;
请问UART_HandleTypeDef结构体中RxXferSize和RxXferCount有什么区别呢?在HAL_UART_Receive_IT函数里把两个值都赋一样的值??
    huart->pRxBuffPtr = pData;
    huart->RxXferSize = Size;
    huart->RxXferCount = Size;
