[RISC-V MCU 应用开发] 【RISC-V MCU CH32V103测评】 环境配置与第一个工程1
 楼主| 昱枫 发表于 2020-10-30 23:03 | 显示全部楼层 |阅读模式
新建开发环境相关这个就不做说明,具体参考这个
https://bbs.21ic.com/icview-3037572-1-1.html
CH32V103 架构
板卡简介
硬件电路  烧录接口与串口
建立完成工程,就自动有一个ADC采用实时串口输出Demo
主函数
  1. #include "debug.h"
  2. /* Global Variable */
  3. u16 TxBuf[1024];
  4. /*******************************************************************************
  5. * Function Name  : ADC_Function_Init
  6. * Description    : Initializes ADC collection.
  7. * Input          : None
  8. * Return         : None
  9. *******************************************************************************/
  10. void ADC_Function_Init(void)
  11. {
  12.         ADC_InitTypeDef ADC_InitStructure;
  13.         GPIO_InitTypeDef GPIO_InitStructure;
  14.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );
  15.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE );
  16.         RCC_ADCCLKConfig(RCC_PCLK2_Div8);
  17.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  18.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  19.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  20.         ADC_DeInit(ADC1);
  21.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  22.         ADC_InitStructure.ADC_ScanConvMode = DISABLE;
  23.         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  24.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
  25.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  26.         ADC_InitStructure.ADC_NbrOfChannel = 1;
  27.         ADC_Init(ADC1, &ADC_InitStructure);
  28.         ADC_DMACmd(ADC1, ENABLE);
  29.         ADC_Cmd(ADC1, ENABLE);
  30.         ADC_ResetCalibration(ADC1);
  31.         while(ADC_GetResetCalibrationStatus(ADC1));
  32.         ADC_StartCalibration(ADC1);
  33.         while(ADC_GetCalibrationStatus(ADC1));
  34. }
  35. /*******************************************************************************
  36. * Function Name  : Get_ADC_Val
  37. * Description    : Returns ADCx conversion result data.
  38. * Input          : ch: ADC channel.
  39. *                    ADC_Channel_0: ADC Channel0 selected.
  40. *                    ADC_Channel_1: ADC Channel1 selected.
  41. *                    ADC_Channel_2: ADC Channel2 selected.
  42. *                    ADC_Channel_3: ADC Channel3 selected.
  43. *                    ADC_Channel_4: ADC Channel4 selected.
  44. *                    ADC_Channel_5: ADC Channel5 selected.
  45. *                    ADC_Channel_6: ADC Channel6 selected.
  46. *                    ADC_Channel_7: ADC Channel7 selected.
  47. *                    ADC_Channel_8: ADC Channel8 selected.
  48. *                    ADC_Channel_9: ADC Channel9 selected.
  49. *                    ADC_Channel_10: ADC Channel10 selected.
  50. *                    ADC_Channel_11: ADC Channel11 selected.
  51. *                    ADC_Channel_12: ADC Channel12 selected.
  52. *                    ADC_Channel_13: ADC Channel13 selected.
  53. *                    ADC_Channel_14: ADC Channel14 selected.
  54. *                    ADC_Channel_15: ADC Channel15 selected.
  55. *                    ADC_Channel_16: ADC Channel16 selected.
  56. *                    ADC_Channel_17: ADC Channel17 selected.
  57. * Return         : val: The Data conversion value.
  58. *******************************************************************************/
  59. u16 Get_ADC_Val(u8 ch)
  60. {
  61.         u16 val;
  62.         ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );
  63.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  64.         while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));
  65.         val = ADC_GetConversionValue(ADC1);
  66.         return val;
  67. }
  68. /*******************************************************************************
  69. * Function Name  : DMA_Tx_Init
  70. * Description    : Initializes the DMAy Channelx configuration.
  71. * Input          : DMA_CHx:
  72. *                    x can be 1 to 7.
  73. *                  ppadr: Peripheral base address.
  74. *                  memadr: Memory base address.
  75. *                  bufsize: DMA channel buffer size.
  76. * Return         : None
  77. *******************************************************************************/
  78. void DMA_Tx_Init( DMA_Channel_TypeDef* DMA_CHx, u32 ppadr, u32 memadr, u16 bufsize)
  79. {
  80.         DMA_InitTypeDef DMA_InitStructure;
  81.         RCC_AHBPeriphClockCmd( RCC_AHBPeriph_DMA1, ENABLE );
  82.         DMA_DeInit(DMA_CHx);
  83.         DMA_InitStructure.DMA_PeripheralBaseAddr = ppadr;
  84.         DMA_InitStructure.DMA_MemoryBaseAddr = memadr;
  85.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  86.         DMA_InitStructure.DMA_BufferSize = bufsize;
  87.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  88.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  89.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  90.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  91.         DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  92.         DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  93.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  94.         DMA_Init( DMA_CHx, &DMA_InitStructure );
  95. }
  96. /*******************************************************************************
  97. * Function Name  : main
  98. * Description    : Main program.
  99. * Input          : None
  100. * Return         : None
  101. *******************************************************************************/
  102. int main(void)
  103. {
  104.         u16 i;
  105.         Delay_Init();
  106.         USART_Printf_Init(115200);
  107.         printf("SystemClk:%d\r\n",SystemCoreClock);
  108.     ADC_Function_Init();
  109.         DMA_Tx_Init( DMA1_Channel1, (u32)&ADC1->RDATAR, (u32)TxBuf, 1024 );
  110.         DMA_Cmd( DMA1_Channel1, ENABLE );
  111.         ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_239Cycles5 );
  112.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  113.     Delay_Ms(50);
  114.         ADC_SoftwareStartConvCmd(ADC1, DISABLE);
  115.         for(i=0; i<1024; i++)
  116.         {
  117.                 printf( "%04d\r\n", TxBuf[i] );
  118.                 Delay_Ms(10);
  119.         }
  120.         while(1);
  121. }
接线图
烧录
输出效果
CH32V103电路图说明以及相关应用Demo 例子程序
CH32V103数据手册
游客,如果您要查看本帖隐藏内容请回复
lovexulu 发表于 2020-11-1 11:12 | 显示全部楼层
学习学习
