IC Reliability verification Tests,IC Testing Lab
 楼主| lisz21c0831 发表于 2020-12-4 15:16 | 显示全部楼层 |阅读模式
High Temperature Operating Life(HTOL)
JESD22-A108;
Test conditions:
For devices containing NVM, endurance preconditioning must be performed before HTOL per Q100-005.
Grade 0: +150Ta for 1000 hours.
Grade 1: +125Ta for 1000 hours.
Grade 2: +105Ta for 1000 hours.
Grade 3: +  85Ta for 1000 hours.
Vcc (max) at which dc and ac parametric are guaranteed. Thermal shut-down shall not occur during this test.
TEST before and after HTOL at room, hot, and cold temperature.
Highly Accelerated Temperature and Humidity Stress Test(HAST)
JESD22-A110;
Test conditions:
Plastic Packaged Parts
Grade 0: +175for 1000 hours or +150for 2000 hours.
Grade 1: +150for 1000 hours or +175for   500 hours.
Grades 2 to 3: +125for 1000 hours or +150for   500 hours.
Ceramic Packaged Parts
    +250for 10 hours or +200for 72 hours.
TEST before and after HTSL at room and hot temperature.
* NOTE: Data from Test B3 (EDR) can be substituted for Test A6 (HTSL) if package and grade level requirements are met.
High Temperature Storage Life(HTSL)
JESD22-A103 ;
Test conditions:
Grade 2 to 3: +125for 1000 hours or +150for   500 hours.
Guangzhou GRG Metrology & Test Co., Ltd. (stock abbreviation: GRGTEST, stock code: 002967) was established in 1964 and registered in the SME Board on November 8, 2019.
GRGTEST has established a service support network with nationwide coverage. It has established 23 measurement and testing bases and more than 50 branches and subsidiaries in China, with a total laboratory area of more than 160,000 square meters and more than 15,000 sets of high-end equipment and instruments from home and abroad. The National Public Service Platform Integrating Measurement, Testing and Certification Technology can quickly respond to the requirements of customers and provide them with convenient and localized professional services.
IC Test Business consulting:
Michael Lee
TEL:+86 13808840060 ;
E-mail:lisz@grgtest.com
