[技术问答] hc32f072用 jlink下载hex文件失败,pc值错误
 楼主| cpl_1 发表于 2020-12-31 23:28 | 显示全部楼层 |阅读模式
hc32f072,用 jlink下载hex文件失败,pc值错误:
ERROR: PC of target system has unexpected value after programming sector. (PC = 0xFFFFFFFE)!
请问这大概是什么原因呢?谢谢!
下面是J-Flash 输出的调试信息:
- Connected successfully
Erasing chip ...
- 256 sectors, 1 range, 0x8000000 - 0x801FFFF
- Start of determining flash info (Bank 0 @ 0x08000000)
- End of determining flash info
- Flash bank info:
- 256 * 512 bytes @ 0x08000000
- Start of preparing flash programming
- End of preparing flash programming
- Start of determining dirty areas in flash cache
- End of determining dirty areas
- CPU speed could not be measured.
- Start of erasing chip
- End of erasing chip
- Start of restoring
- End of restoring
- Erase operation completed successfully - Completed after 0.195 sec
Programming target (20052 bytes, 1 range) ...
- Checking if selected data fits into selected flash sectors.
- Flash bank info:
- Start of flash programming
- Programming range 0x08000000 - 0x08004FFF (040 Sectors, 20 KB)
- ERROR: PC of target system has unexpected value after programming sector. (PC = 0xFFFFFFFE)!
---------------------------------------------------------------------- Registers -------------------------------------------------------------------------------------
        PC   = FFFFFFFE
Current:    R0   = 0000001E,    R1   = 000000E1,    R2   = 40002000,    R3   = 08000000
        R4   = 000000A0,    R5   = 40000F80,    R6   = 40020000,    R7   = 00000000
- End of flash programming
- ERROR: Program failed
- ERROR: Failed to program target
Disconnecting ...
- Disconnected
