具体配置参数有多种:- typedef enum
- GPIO_MODE_IN_FL_NO_IT = (uint8_t)0x00, /*!< Input floating, no external interrupt */
- GPIO_MODE_IN_PU_NO_IT = (uint8_t)0x40, /*!< Input pull-up, no external interrupt */
- GPIO_MODE_IN_FL_IT = (uint8_t)0x20, /*!< Input floating, external interrupt */
- GPIO_MODE_IN_PU_IT = (uint8_t)0x60, /*!< Input pull-up, external interrupt */
- GPIO_MODE_OUT_OD_LOW_FAST = (uint8_t)0xA0, /*!< Output open-drain, low level, 10MHz */
- GPIO_MODE_OUT_PP_LOW_FAST = (uint8_t)0xE0, /*!< Output push-pull, low level, 10MHz */
- GPIO_MODE_OUT_OD_LOW_SLOW = (uint8_t)0x80, /*!< Output open-drain, low level, 2MHz */
- GPIO_MODE_OUT_PP_LOW_SLOW = (uint8_t)0xC0, /*!< Output push-pull, low level, 2MHz */
- GPIO_MODE_OUT_OD_HIZ_FAST = (uint8_t)0xB0, /*!< Output open-drain, high-impedance level,10MHz */
- GPIO_MODE_OUT_PP_HIGH_FAST = (uint8_t)0xF0, /*!< Output push-pull, high level, 10MHz */
- GPIO_MODE_OUT_OD_HIZ_SLOW = (uint8_t)0x90, /*!< Output open-drain, high-impedance level, 2MHz */
- GPIO_MODE_OUT_PP_HIGH_SLOW = (uint8_t)0xD0 /*!< Output push-pull, high level, 2MHz */
- }GPIO_Mode_TypeDef;
