[应用相关] AT32F403A HID mouse sample code
 楼主| muyichuan2012 发表于 2021-1-25 19:42 | 显示全部楼层 |阅读模式
1. 鼠标自动移动
2. 增加 remote wakeup
增加PA0控制是否要移动鼠标功能。
接上PC 之后鼠标会自动移动
PC进入休眠之后可以通过按键PA0 使能Remotewakeup功能
#include "usb_lib.h"
#include "hw_config.h"
#include "usb_pwr.h"
#include "at32_board.h"
/** @addtogroup AT32F413_StdPeriph_Examples
/** @addtogroup USB_Mouse
void Mouse_send(uint8_t operation)
  uint8_t Mouse_Buffer[4] = {0, 0, 0, 0};
  int8_t X = 0, Y = 0,MouseButton=0;
  switch (operation)
    case LEFT:
      X -= CURSOR_STEP;
      break;
    case RIGHT:
      X += CURSOR_STEP;
      break;
    case UP:
      Y -= CURSOR_STEP;
      break;
    case DOWN:
      Y += CURSOR_STEP;
          break;
    default:
      return;
  Mouse_Buffer[0] = MouseButton;
  Mouse_Buffer[1] = X;
  Mouse_Buffer[2] = Y;
  Joystick_Send(Mouse_Buffer[0], Mouse_Buffer[1], Mouse_Buffer[2], Mouse_Buffer[3]);
  * @brief  Main program
  * @param  None
  * @retval None
int main(void)
    BUTTON_Type Button_Press;
    u8 keysta = 0, i;
    static uint8_t s_flag = 0;
    /*AT START F4xx board initialize
    * Include LED, Button
    AT32_Board_Init();
    /*USB GPIO configure*/
    AT32_USB_GPIO_init();
    /*Enable USB Interrut*/
           USB_Interrupts_Config();
    /*Set USB Clock, USB Clock must 48MHz*/
    Set_USBClock();
    /*if use USB SRAM_Size = 768 Byte, default is 512 Byte*/
    //Set_USB768ByteMode();
    /* USB protocol and register initialize*/
           USB_Init();
//    while(!(GPIOA->IPTDT & 1));
    while(1)
       if ( AT32_BUTTON_Press() == BUTTON_WAKEUP )
//         Delay_ms(100);
         if ( s_flag )
           s_flag = 0;
         else
           s_flag = 1;
       if ( bDeviceState == CONFIGURED && s_flag)
            for (i = 1; i <= 10; i++)
                Mouse_send(LEFT);
                Delay_ms(20);
                Mouse_send(UP);
                Delay_ms(20);
                Mouse_send(RIGHT);
                Delay_ms(20);
                Mouse_send(UP);
                Delay_ms(20);
                Mouse_send(RIGHT);
                Delay_ms(20);
                Mouse_send(DOWN);
                Delay_ms(20);
                Mouse_send(LEFT);
                Delay_ms(20);
                Mouse_send(DOWN);
                Delay_ms(20);
        }else if ( bDeviceState == SUSPENDED)
            if (AT32_BUTTON_Press() == BUTTON_WAKEUP && ((pInformation->Current_Feature & 0x20) != 0))
                Resume(RESUME_INTERNAL);
#if 0
        Button_Press = AT32_BUTTON_Press();
        switch (Button_Press)
            case BUTTON_WAKEUP:
                Joystick_Send(2, 0, 0, 0); /*send mouse right button*/
                keysta = 1;
                break;
            default:
                break;
        if ( keysta != 0 )
            Delay_ms(30);
            keysta=0;
            Joystick_Send(0,0,0,0);       /*release the button*/
        Delay_ms(40);
        AT32_LEDn_Toggle(LED4);
#endif
Mouse_test.zip
44.24 KB, 下载次数: 33
