[STM8] STM8AF6226 Pin/RST持续输出7Khz方波,程序不受控
 楼主| huangchui 发表于 2021-5-9 22:16 | 显示全部楼层 |阅读模式
1.STM8AF6226用STVP擦空后RST Pin一直未高电平;
2.但是用IAR编译以下程序后,程序一直没有运行,最简单的程序,连配置个GPIO反转都无法实现
llljh 发表于 2021-5-9 22:18 | 显示全部楼层
用STVP下载
 楼主| huangchui 发表于 2021-5-9 22:20 | 显示全部楼层
下载过,现象一样!
dengdc 发表于 2021-5-9 22:22 | 显示全部楼层
程序没有配置对
xxrs 发表于 2021-5-9 22:25 | 显示全部楼层
芯片没有复位
yszong 发表于 2021-5-9 22:26 | 显示全部楼层
嗯,压根就没有进入到Main函数
 楼主| huangchui 发表于 2021-5-9 22:28 | 显示全部楼层
但是通过通断VCC电源的办法,用示波器探头钩住RST Pin测量,大部分时间是RST Pin一直输出一个7Khz左右的方波信号,也会出现几次高电平的情况。
 楼主| huangchui 发表于 2021-5-9 22:34 | 显示全部楼层
但是当出现高电平的时候,去测量已经配置的PB0,PB1 电平,依然是长期为低电平
wuhany 发表于 2021-5-9 22:36 | 显示全部楼层
没有按程序跑动
 楼主| huangchui 发表于 2021-5-9 22:39 | 显示全部楼层
最小系统,把板子上面的其他电路都拿掉了,直接3.3V供电,VCAP有放电容,复位是0.1uF,10K电阻。
  * @file    Project/main.c
  * @author  MCD Application Team
  * @version V2.2.0
  * @date    30-September-2014
  * @brief   Main program body
  * @attention
  * <h2><center>© COPYRIGHT 2014 STMicroelectronics</center></h2>
  * Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
  * You may not use this file except in compliance with the License.
  * You may obtain a copy of the License at:
  *        http://www.st.com/software_license_agreement_liberty_v2
  * Unless required by applicable law or agreed to in writing, software
  * distributed under the License is distributed on an "AS IS" BASIS,
  * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  * See the License for the specific language governing permissions and
  * limitations under the License.
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
#define LED_GPIO_PORT  (GPIOB)
#define LED_GPIO_PINS  (GPIO_PIN_0 | GPIO_PIN_1 )
void Delay(uint16_t nCount)
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
void main(void)
  /* Initialize I/Os in Output Mode */
  GPIO_Init(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS, GPIO_MODE_OUT_PP_LOW_FAST);
  while (1)
    /* Toggles LEDs */
    GPIO_WriteReverse(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS);
    Delay(0xFFFF);
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
午夜粪车 发表于 2021-5-9 22:41 | 显示全部楼层
建议用STVP讲默认的optionbyte 重新烧一遍试试看。
chuxh 发表于 2021-5-9 22:44 | 显示全部楼层
另外VCAP电容要保证1uf以上
 楼主| huangchui 发表于 2021-5-9 22:48 | 显示全部楼层
新建STM8AF6226  STVP工程的optionbyte 是全0; 烧录了,现象一样;
llljh 发表于 2021-5-9 22:50 | 显示全部楼层
VCAP并了3个1UF的电容,现象依然一样;
renyaq 发表于 2021-5-9 22:53 | 显示全部楼层
RST输出方波信号?不应该是输入端口么
 楼主| huangchui 发表于 2021-5-9 22:55 | 显示全部楼层
对,一直是方波,不管拿掉有没有拿掉外围的0.1uF电容和10K电阻。。。。。
对,一直是方波,不管拿掉有没有拿掉WW的0.1uF电容和10K电阻。。。。。
 楼主| huangchui 发表于 2021-5-9 23:01 | 显示全部楼层
唉,还是没有什么结果,算了,多谢大家啦
renzheshengui 发表于 2021-6-3 10:20 | 显示全部楼层
能读到擦完之后都是什么内容吗
wakayi 发表于 2021-6-3 10:22 | 显示全部楼层
方波的占空比发生变化吗
