- //#define BLINKER_ESP_SMARTCONFIG
- #define BLINKER_WIFI/////////////////// wifi
- #define BLINKER_MIOT_LIGHT ////////////小爱
- #include <Blinker.h>
- char auth[] = "授权码";//////////手机下载 blinker app 复制的key
- char ssid[] = "wifi账号";/////wifi ssid
- char pswd[] = "WiFi密码";///wifi 密码
- int openState = 0; ///默认为单色模式
- // Download Adafruit_NeoPixel library here:
- // https://github.com/adafruit/Adafruit_NeoPixel
- #include <Adafruit_NeoPixel.h>
- #define PIN 3 ////开发板的引脚编号 接WS2812 data VCC--VCC GND-GND DATA/DI(DATA INPUT)--17 具体看产品说明
- #define NUMPIXELS 24 ////开发板灯灯珠数量 位
- Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
- #define BUTTON_1 "ButtonKey" ///////////////【APP内用来控制呼吸灯开关】app中添加 开关按键 数据键名ButtonKey 一致即可 注意大小写
- #define RGB_1 "RGBKey" ///////////////【APP内用来控制颜色及亮度】app中添加调色盘 数据键名RGBKey 一致即可
- BlinkerRGB WS2812(RGB_1);
- BlinkerButton Button1(BUTTON_1);
- uint8_t colorR, colorG, colorB, colorW;
- bool wsState;
- uint8_t wsMode = BLINKER_CMD_MIOT_DAY;
- void pixelShow()
- pixels.setBrightness(colorW);
- for (int i = 0; i < NUMPIXELS; i++) {
- pixels.setPixelColor(i, colorR, colorG, colorB);
- pixels.show();
- void ws2812_callback(uint8_t r_value, uint8_t g_value, uint8_t b_value, uint8_t bright_value)
- digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
- openState = 0;
- Button1.print("off");
- BLINKER_LOG("R value: ", r_value);
- BLINKER_LOG("G value: ", g_value);
- BLINKER_LOG("B value: ", b_value);
- BLINKER_LOG("Rrightness value: ", bright_value);
- colorR = r_value;
- colorG = g_value;
- colorB = b_value;
- colorW = bright_value;
- pixelShow();
- void button1_callback(const String & state)
- BLINKER_LOG("get button state: ", state);
- if (state == BLINKER_CMD_ON) {
- BLINKER_LOG("Toggle on!");
- Button1.print("on");
- openState = 1;
- else if (state == BLINKER_CMD_OFF) {
- BLINKER_LOG("Toggle off!");
- openState = 0;
- uint32_t getColor()
- uint32_t color = colorR << 16 | colorG << 8 | colorB;
- return color;
- void miotPowerState(const String & state)
- BLINKER_LOG("need set power state: ", state);
- digitalWrite(LED_BUILTIN, HIGH);
- BlinkerMIOT.powerState("on");
- BlinkerMIOT.print();
- wsState =true;
- if (colorW==0) colorW =255;
- BlinkerMIOT.powerState("off");
- wsState = false;
- if (colorW >0) colorW = 0;
- pixelShow();
- ///////////////////////////////////////////////////////呼吸灯
- uint32_t Wheel(byte WheelPos) {
- WheelPos = 255 - WheelPos;
- if (WheelPos < 85) {
- return pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
- if (WheelPos < 170) {
- WheelPos -= 85;
- return pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
- WheelPos -= 170;
- return pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
- void rainbow(uint8_t wait) {
- uint16_t i, j;
- for (j = 0; j < 256; j++) {
- for (i = 0; i < pixels.numPixels(); i++) {
- //time_show();
- // dhtShow();
- pixels.setPixelColor(i, Wheel((i + j) & 255));
- pixels.show();
- delay(wait);
- void miotColor(int32_t color)
- BLINKER_LOG("need set color: ", color);
- colorR = color >> 16 & 0xFF;
- colorG = color >> 8 & 0xFF;
- colorB = color & 0xFF;
- BLINKER_LOG("colorR: ", colorR, ", colorG: ", colorG, ", colorB: ", colorB);
- pixelShow();
- BlinkerMIOT.color(color);
- void miotMode(uint8_t mode)
- BLINKER_LOG("need set mode: ", mode);
- if (mode == BLINKER_CMD_MIOT_DAY) {
- //日光模式 小爱同学的语音命令 模式中文名称参考 https://www.diandeng.tech/doc/xiaoai
- else if (mode == BLINKER_CMD_MIOT_NIGHT) {
- // Your mode function
- else if (mode == BLINKER_CMD_MIOT_COLOR) {
- openState = 0;
- else if (mode == BLINKER_CMD_MIOT_WARMTH) {
- else if (mode == BLINKER_CMD_MIOT_TV) {
- else if (mode == BLINKER_CMD_MIOT_READING) {
- else if (mode == BLINKER_CMD_MIOT_COMPUTER) {
- // 电脑模式
- openState = 1;
- wsMode = mode;
- BlinkerMIOT.mode(mode);
- void miotBright(const String & bright)
- BLINKER_LOG("need set brightness: ", bright);
- colorW = bright.toInt();
- BLINKER_LOG("now set brightness: ", colorW);
- pixelShow();
- BlinkerMIOT.brightness(colorW);
- void miotColoTemp(int32_t colorTemp)
- BLINKER_LOG("need set colorTemperature: ", colorTemp);
- BlinkerMIOT.colorTemp(colorTemp);
- void miotQuery(int32_t queryCode)
- BLINKER_LOG("MIOT Query codes: ", queryCode);
- switch (queryCode)
- case BLINKER_CMD_QUERY_ALL_NUMBER :
- BLINKER_LOG("MIOT Query All");
- BlinkerMIOT.powerState(wsState ? "on" : "off");
- BlinkerMIOT.color(0);
- BlinkerMIOT.mode(0);
- BlinkerMIOT.colorTemp(1000);
- BlinkerMIOT.brightness(1);
- break;
- case BLINKER_CMD_QUERY_POWERSTATE_NUMBER :
- BLINKER_LOG("MIOT Query Power State");
- break;
- case BLINKER_CMD_QUERY_COLOR_NUMBER :
- BLINKER_LOG("MIOT Query Color");
- break;
- case BLINKER_CMD_QUERY_MODE_NUMBER :
- BLINKER_LOG("MIOT Query Mode");
- break;
- case BLINKER_CMD_QUERY_COLORTEMP_NUMBER :
- BLINKER_LOG("MIOT Query ColorTemperature");
- break;
- case BLINKER_CMD_QUERY_BRIGHTNESS_NUMBER :
- BLINKER_LOG("MIOT Query Brightness");
- break;
- default :
- break;
- void dataRead(const String & data)
- BLINKER_LOG("Blinker readString: ", data);
- Blinker.vibrate();
- uint32_t BlinkerTime = millis();
- Blinker.print("millis", BlinkerTime);
- void setup()
- Serial.begin(115200);
- BLINKER_DEBUG.stream(Serial);
- BLINKER_DEBUG.debugAll();
- // Blinker.begin(auth); //必须有这句,配置网络必备
- pinMode(LED_BUILTIN, OUTPUT);
- digitalWrite(LED_BUILTIN, LOW);
- Blinker.begin(auth, ssid, pswd);
- Blinker.attachData(dataRead);
- BlinkerMIOT.attachPowerState(miotPowerState);
- BlinkerMIOT.attachColor(miotColor);
- BlinkerMIOT.attachMode(miotMode);
- BlinkerMIOT.attachBrightness(miotBright);
- BlinkerMIOT.attachColorTemperature(miotColoTemp);
- BlinkerMIOT.attachQuery(miotQuery);
- pinMode(14, OUTPUT);
- digitalWrite(14, HIGH);
- pinMode(15, OUTPUT);
- digitalWrite(15, HIGH);
- colorR = 255;
- colorG = 255;
- colorB = 255;
- colorW = 0;
- wsState = true;
- pixels.begin();
- WS2812.attach(ws2812_callback);
- Button1.attach(button1_callback);
- pixelShow();
- void loop()
- Blinker.run();
- if (openState == 0)
- pixelShow();
- //Button1.print("off");
- else if (openState == 1)
- rainbow(15);/////////15呼吸灯的频率
- //Button1.print("on");
将上面的代码直接覆盖源代码,修改这几个参数便可
修改引脚和WS2812的灯珠数量。
注意WiFi必须是2.4G频段,5G频段不可使用。修改完成后上传代码到ESP8266。
此时打开“点灯-blinker”APP,
可以看到有自己的设备,点进去可以看到设备状态,是否在线,如果一切顺利,此时应该能看到设备处于在线状态
那么现在我们就要将这个设备添加进小爱同学。
打开米家APP,在我的>其他平台设备>添加>点灯科技,绑定账号后就会将我们之前的设备添加到米家,就可以通过小爱同学进行控制了。
到此就完成啦,当然这里面还有很多瑕疵,后面会追加使用天猫精灵控制,而且使用手机配网,而不是写在固件中。时间问题,今天到此为止,后期开发敬请期待。
