[个人承接] 龙迅主要物料介绍
 楼主| Clara01 发表于 2021-7-20 17:55 | 显示全部楼层 |阅读模式
01. LT6911GX
1)HDMI 2.1  Receiver
     *compliant with HDMI 2.1 specification.
     *support 8K@30Hz,8K@60Hz with DSC.
     *support HDR
2) Single/Dual/Quad-port MIPI DSI/CSITransmitter.
      *Side-by-side 3D support
      *support CSI D-option 8 Lane output
3)Miscellaneous
       * Zoom scaling up and down.
       * Support Rotation(Max 1080P)
4) Package:BGA169(9*9)
02.LT6911C
1)HDMI 1.4 Receiver
   *Compliant with HDMI 1.4,up to 4K@30.
   *Support HDCP 1.4
2)MIPI CSI/DSI Transmitter
   *1/2/4 configurable ports
    *80Mb/s-1.5Gb/s per data lane.
    *Side-by-Side 3D support.
3)Voltage:3.3V&1.2V
4)Package: QFN64(7.5*7.5)
03.LT8619C
•SupportHDMI 1.4/Dual Mode DP input.
•Supportresolution up to 4K.
•SupportDDRoutput.
•Voltage:3.3V&1.8V
•Package:QFN76(9*9)
04.LT9721
*Single-Port MIPI receiver up to 1080P@60Hz for RGB format and 4K@30 Hz for YUV420 format.
*HDMI 1.4 receiver up to 4K*2K@30Hz forRGB format and 4K@30 Hz for YUV420 format.
*DP 1.2 Transmitter up to 4K*2K@60.
*USB Type-C output interface.
*Voltage: 3.3V&1.8V
*Package:QFN64(7.5*7.5)
05.LT8711UX
1)USB Type-C
  *Compliant with DP Alt Mode 1.0,PD2.0,Type-C 1.2,HDMI 1.4b Alt Mode 1.0.
  *Daul CCcontrollers.
2)DP Receiver
   *Compliant with DP 1.2 HDCP 1.3.
3)HDMI Transmitter
   *Compliant with HDMI 2.0/1.4,DVI 1.0,HDMI 2.2/1.4
   *6G bps
   *4K@60Hz
4)Voltage:3.3V&1.2V
5)Package:QFN88(10*10)
06.LT8711HE
1)USB Type-C
  *Compliant with USB Power Deliver specification R2.0,V1.0.
2)DP 1.2 Receiver
  *1.62/2.7/5.4 Gbps perdata lane.
3)HDMI 2.0 Transmitter
  *Data rate up to 6Gbps.
  *Support 4K@60Hz.
4)HDMI 2.0 Transmitter.
  *Date rate up to 6Gbps.
  *Support 4K@60.
  *USB billboard module and USB2.0 switch integrated.
5)Voltage:3.3V&1.2V
6)Package(7.5*7.5)
07.LT7911D
1)TYPE-C/DP 1.2 Receiver
   *Compliantwith DP 1.2 for 1.62Gb/s,2.7Gb/s,5.4Gb/s,up to 4K@60Hz.
2)MIPI CSI/DSI Transmitter.
    *Side-by-side 3D support.
3)Voltage:3.3V&1.2V
4)Package:QFN64(7.5*7.5)
08.LT8918
*Support 24-bit RGB and BT656/BT1120input.
*Resolution up to 1080P@60Hz
*Voltage:1.8V
09.LT8911EX/LT8911EXB
1)LT8911EX
  *Support single/Dual LVDS input.
   *Maximum 1.2Gb/s per data lane.
   *Support 6-bit or 8-bit input color depth.
2)LT8911EXB
   *Support single port MIPI CSI/DSI input.
   *Clock lane and 1-4 configurable data lanes.
   *80Mb/s-2.0Gb/s per data lane.
   *Support 16/18/24/30/36 bit RGB format.
3)Voltage: 1.8V
4)Package:QFN48 (9*9)/QFN64(6*6)
10.LT8912B
*Compliant with HDMI 1.4.
*Support MIPI DSI Non-Burst Mode(continueMode).
*Video Scaler on LVDS path.
*Single to dual outputs.
*Voltage:1.8V
11.LT9211
1)MIPI/LVDSinput mux and output split supported.
2)MIPI/LVDS bypass Single Level shift forFPGA.
3)Up to 1080P@60Hz.
4)Voltage:3.3V&1.8V
5)Package:QFN64(7.5*7.5)
12、联系我们
深圳市新龙鹏科技有限公司
公司地址:深圳市宝安区中粮商务公园2栋1102,1103,1103A,1107室
电话:0755-33673997
传真:0755-33673910
E-Mail:BU1(多媒体)chris.tang@szdragon.com
     BU2(存储类)cherry.liu@szdragon.com
     BU3(电源及模拟类)alice.zhou@szdragon.com
     BU4(网通、物联网)chris.tang@szdragon.com
      新龙鹏公司**以客户为中心,积极面对未来,不断创新进取,以雄厚的专业实力,优良的服务品质,致力于成为国内一流的芯片供应商,专业的电子产品设计企业。诚愿与各界朋友紧密合作,携手发展,共创美好未来
 楼主| Clara01 发表于 2021-7-21 15:22 | 显示全部楼层
欢迎关注深圳新龙鹏科技微信公众号和官网,了解详细资讯、最新动态以及联系方式;
imbean 发表于 2021-7-21 16:58 | 显示全部楼层
国产芯片想用起来真心不容易  要点资料还得签NDA  关键还是不完整的资料 人为制造困难
 楼主| Clara01 发表于 2021-7-22 09:41 | 显示全部楼层
国产芯片想用起来真心不容易  要点资料还得签NDA  关键还是不完整的资料 人为制造困难  ...
给龙迅点赞,加油吧奥利给
