[开发工具] MCC代码配置器无法加载.....有大佬遇到这样的问题吗?
 楼主| sujinfu 发表于 2021-11-15 09:16 | 显示全部楼层 |阅读模式
新建项目无法加载MCC,原来的项目可以加载
09:10:42.371  SEVERE: Invalid configuration file.
javax.xml.stream.XMLStreamException: ParseError at [row,col]:[1,1]
Message: Premature end of file.
        at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.next(XMLStreamReaderImpl.java:604)
        at com.sun.xml.internal.stream.XMLEventReaderImpl.nextEvent(XMLEventReaderImpl.java:83)
        at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:110)
        at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:122)
        at org.simpleframework.xml.stream.StreamReader.next(StreamReader.java:94)
        at org.simpleframework.xml.stream.NodeReader.readElement(NodeReader.java:111)
        at org.simpleframework.xml.stream.NodeReader.readRoot(NodeReader.java:85)
        at org.simpleframework.xml.stream.NodeBuilder.read(NodeBuilder.java:84)
        at org.simpleframework.xml.stream.NodeBuilder.read(NodeBuilder.java:58)
        at org.simpleframework.xml.core.Persister.read(Persister.java:543)
        at org.simpleframework.xml.core.Persister.read(Persister.java:444)
[catch] at com.microchip.mcc.host.services.project.ConfigurationContainer.fromFile(ConfigurationContainer.java:51)
        at com.microchip.mcc.host.services.project.AHostProjectService.loadFromFile(AHostProjectService.java:109)
        at com.microchip.mcc.host.services.project.AHostProjectService.loadConfig(AHostProjectService.java:72)
        at com.microchip.mcc.plugin.Controller.loadConfiguration(Controller.java:106)
        at com.microchip.mcc.plugin.Controller.open(Controller.java:97)
        at com.microchip.mcc.plugin.Controller.openClosePlugin(Controller.java:184)
        at com.microchip.mcc.plugin.view.toolbar.ToolbarMccIcon.lambda$performAction$2(ToolbarMccIcon.java:110)
        at com.sun.javafx.application.PlatformImpl.lambda$null$5(PlatformImpl.java:295)
        at java.security.AccessController.doPrivileged(Native Method)
        at com.sun.javafx.application.PlatformImpl.lambda$runLater$6(PlatformImpl.java:294)
        at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:95)
        at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
        at com.sun.glass.ui.win.WinApplication.lambda$null$3(WinApplication.java:177)
        at java.lang.Thread.run(Thread.java:748)
