[全新] ZCC6601替代SN6501/SN6505
 楼主| SWdianzi 发表于 2021-11-29 15:46 | 显示全部楼层 |阅读模式
FEATURES
Push-Pull Driver for Small Transformers
Wide range 3 V - 12 V Supply
High Primary-side Current Drive:
– 5 V Supply: 600 mA (max)
– 3.3 V Supply: 300 mA (max)
Low Ripple on Rectified Output Permits Small
Output Capacitors
Soft start and Current limit
Thermal shutdown
Small 5-pin SOT23 Package
APPLICATIONS
solated Interface Power Supply for CAN, RS-
485, RS-422, RS-232, SPI, I2C, Low-Power LAN
Industrial Automation
Process Control
Medical Equipment
DESCRIPTION
The ZCC6601 is a monolithic oscillator/power-driver, specifically designed for small form factor, isolated power
supplies in isolated interface applications. It drives a low-profile, center-tapped transformer primary from a 3V
to12 V DC power supply. The secondary can be wound to provide any isolated voltage based on transformer
turns ratio.
The ZCC6601 consists of an oscillator followed by a gate drive circuit that provides the complementary output
signals to drive the ground referenced N-channel power switches. The internal logic ensures break-before-make
action between the two switches.
The ZCC6601 is available in a small SOT23-5 package, and is specified for operation at temperatures from –40°C
to 125°C.
