[DemoCode下载] [M471] ADC in Power Noise Environment
 楼主| 奔跑的牛 发表于 2022-1-13 14:08 | 显示全部楼层 |阅读模式
AD, dc, se, vi
  • Application: This sample code uses M471 ADC averaging mode to get stable ADC conversion data in a power noise environment.
  • BSP Version: M471 Series BSP CMSIS V3.00.000
  • Hardware: NuMaker-M471KI V1.1
The ADC applications need stable power source for analog circuit, but the power source is from mains supply in home appliance. You may get a noise in voltage source from mains supply like 60 Hz ripple waveform. The noise will make the ADC conversion result unstable. This sample code uses M471 averaging mode to average the ADC data. The noise error also will be averaged by M471 averaging mode so the ADC can get a stable data with less noise error.
You can download the sample code at https://www.nuvoton.com/resource-downlo ... 0927160701
认证:新唐科技
简介:新唐科技晶圆代工(源自于华邦电子六英寸晶圆厂)座落于台湾新竹科学园区内,月产能为45,000片,自1992年起,拥有超过20年晶圆代工服务经验,于2008年自华邦电子分割后,完全专注于晶圆代工。新唐晶圆代工厂目前提供0.35微米以上工艺,包括一般逻辑(Generic Logic)、混合信号(Mixed Signal)、高压(High Voltage)、超高压(Ultra High Voltage)、电源管理(Power Management)、Mask ROM (Flat Cell)、嵌入式记忆体(embedded Logic Non-Volatile Memory)与客制化工艺(如:IGBT, MOSFET, TVS, BioChip, Pressure Sensor, and Light Sensor)等。
257
