[应用相关] IIC的模拟哪里有错
 楼主| shashaa 发表于 2022-1-13 21:33 | 显示全部楼层 |阅读模式
#include<msp430x14x.h>
#define uchar unsigned char
#define uint unsigned int
#define SDA_1  P3OUT|=BIT1 // P3.1为SDA
#define SDA_0  P3OUT&=~BIT1
#define SCL_1 P3OUT |= BIT0 //P3.0为SCL
#define SCL_0 P3OUT &= ~BIT0
#define DIR_IN P3DIR &= ~BIT1
#define DIR_OUT P3DIR |= BIT1
#define SDA_IN ((P3IN >> 1) & 0x01)
#define dis_data  P5OUT  //数码管输出
#define TIME 5
#define SlaveAddress   0xA6
uchar seg_bcd[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e}; //数码管
void delay_nms(unsigned int k)//延时k毫秒
   unsigned int i,j;
   for(i=0;i<k;i++)
       for(j=0;j<121;j++)
void Delay(unsigned int n)    //延时
    unsigned int i;
    for(i = 0;i < n;i++)
void BH1750_Start()         //起始信号
     DIR_OUT;
     SDA_1;
    delay_nms(5);
     SCL_1;
     Delay(TIME);
     SDA_0;
     Delay(TIME);
     SCL_0;
void BH1750_Stop()        //结束信号
     DIR_OUT;
     SDA_0;
     Delay(TIME);
     SCL_1;
     Delay(TIME);
     SDA_1;                    }
void BH1750_SendACK()       //发送Ack
     SCL_0;
     DIR_OUT;
     SDA_0;
     Delay(TIME);
     SCL_1;
     Delay(TIME);
     SCL_0;
void BH1750_RecvACK()         //接受ACK
{   SCL_1;
    Delay(TIME);
     DIR_IN;
     while(SDA_IN);
     DIR_OUT;
     SCL_0;
     Delay(TIME);
void BH1750_SendByte(uchar dat)     //发送一个字节
{   DIR_OUT;
     unsigned int i;
     for(i = 0;i < 8;i++)
     SCL_0;
     Delay(TIME);
     if((dat >> 7) & 0x01) SDA_1;
     else SDA_0;
    Delay(TIME);
     SCL_1;
     Delay(TIME);
     dat <<= 1; //数据左移一位,进入下一轮送数
     Delay(TIME);
uchar BH1750_RecvByte()         //接受一个字节
     uchar i;
     uchar dat = 0;
     uchar datbit=0;
     SCL_0;
     Delay(TIME);
     SDA_1;
     DIR_IN;
     for (i=0; i<8; i++)
         SCL_1;
        Delay(TIME);
        datbit = SDA_IN;
         Delay(TIME);
         dat = ((dat << 1) | datbit);
         SCL_0;
        Delay(TIME);
     return dat;
void Single_Write_BH1750(uchar REG_Address)  //写入
     BH1750_Start();
     BH1750_SendByte(SlaveAddress);
     BH1750_SendByte(REG_Address);
   // BH1750_SendByte(REG_data);
     BH1750_Stop();
void main()
{ uchar tmp;
   float temp;
   int t;
   WDTCTL = WDTPW + WDTHOLD;
   P5DIR |= 0Xff;
   P4DIR |= 0x01;
   P5OUT |= 0x00;
   delay_nms(200);
   Single_Write_BH1750(0x01);
   Single_Write_BH1750(0x10);
  while(1)
    { Single_Write_BH1750(0x01);
      delay_nms(180);
      tmp=BH1750_RecvByte();
      temp=(float)tmp;
      t=temp/100;
      dis_data=seg_bcd[t];
qiangweii 发表于 2022-1-13 21:34 | 显示全部楼层
BH1750FVI这个东西真的不了解。看看有没有了解的人。
litengg 发表于 2022-1-13 21:39 | 显示全部楼层
不要简单的贴代码。很少有人会有耐心看既不知道原理图又不知道具体应用的代码
androidbus 发表于 2022-1-13 21:40 | 显示全部楼层
硬件连接有没有问题?检查下BH1750FVI外围电路正常否。
feiqi1 发表于 2022-1-13 21:54 | 显示全部楼层
IIC通信的地址波特率设置正确否?
xia00 发表于 2022-1-13 21:59 | 显示全部楼层
用示波器抓图看看波形。
hfdy01 发表于 2022-1-13 22:00 | 显示全部楼层
在此类写数据后没有检查应答信号,在写数据后必须检查应答信号
CallReceiver 发表于 2022-1-13 22:04 | 显示全部楼层
有可能是你io电平有问题的,加个上啦电阻之类的。
boy1990 发表于 2022-1-13 22:05 | 显示全部楼层
看iic最好还是 用示波器或者逻辑分析仪
sourceInsight 发表于 2022-1-13 22:13 | 显示全部楼层
我觉得可以上逻辑分析仪看看那!
bbapple 发表于 2022-1-13 22:14 | 显示全部楼层
光强度检测话应该主要是用到AD采集的吧,直接采集传感器书吃的电压或者电流信号的吧。
handleMessage 发表于 2022-1-13 22:46 | 显示全部楼层
IIC通信关键要看时序和波特率。
zhouhuanの 发表于 2022-1-13 22:47 | 显示全部楼层
IIC出问题通常都是时序,用示波器查看一下
wanglaojii 发表于 2022-1-13 22:51 | 显示全部楼层
这个注意时钟信号的设计。
laozhongyi 发表于 2022-1-13 22:55 | 显示全部楼层
怎么写的地址还不一样呢。
Edisons 发表于 2022-1-13 22:58 | 显示全部楼层
这个芯片没用过,具体怎么配置还真不知道呢。
_gege 发表于 2022-1-13 22:59 | 显示全部楼层
可能还是你的时序问题,请看看drier的说明吧
Mozarts 发表于 2022-1-13 23:03 | 显示全部楼层
读LCD的数据有个读数据的指令就是RS=1
Listate 发表于 2022-1-13 23:05 | 显示全部楼层
通常是写命令、写数据用的比较多一些。
kiwis66 发表于 2022-1-17 09:19 | 显示全部楼层
这个都是通用的吧,稍微改改,调整下时序
