LIN的自动波特率问题
 楼主| shitou45823258 发表于 2022-3-21 09:57 | 显示全部楼层 |阅读模式
大神们好!按照PIC16F18系列自动波特率的时序,在LIN_RX_IDLE里面,ABD使能,在LIN_RX_SYNC里面,读一次RC1REG将RCIF置0,波特率自动填充SP1BRG里面。现在在LIN_RX_SYNC里面,SPIBRG的值读出是对的,但是程序跳到LIN_RX_PID里面,读出PID报错,数据为0。请大神们指点,谢谢!case LIN_RX_IDLE:
            if(EUSART1_is_rx_ready() > 0){
                //Start Timer
                LIN_startTimer(READ_TIMEOUT);
                LIN_rxInProgress = true;
                LIN_rxState = LIN_RX_BREAK;
                BAUD1CONbits.ABDEN = 1;//set auto baud detection
            break;
case LIN_RX_BREAK:
                if(LIN_breakCheck() == true){  //Read Break
                    LIN_rxState = LIN_RX_SYNC;
                } else {
                    LIN_rxState = LIN_RX_ERROR;
            break;
case LIN_RX_SYNC:
                while (BAUDCONbits.ABDEN == 1)
                   if (BAUDCONbits.ABDOVF == 1)
                       BAUDCONbits.ABDEN  = 0;    // abort auto baud
                       BAUDCONbits.ABDOVF = 0;    // start auto baud
                       BAUDCONbits.ABDEN  = 1;    // restart auto baud
                index = EUSART1_Read();
                RC1REG_DATA=RC1REG;
                if((SP1BRGL+(SP1BRGH<<8))>0)
                    LIN_rxState = LIN_RX_PID;
                }else
         break;
