[PCB] IPQ8072/IPQ8074 WiFi 6E Card 4x4 2.4G & 5G 802.11ax -wallys
1403|0
 楼主| wirelesswifi6 发表于 2022-5-7 14:30 | 显示全部楼层 |阅读模式
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 802.11ac TX Beamforming
■ Support 802.11ac/802.11ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Operating Temperature Range
    -20 to +70
    ºC
    Storage Temperature Range
    -40 to +90
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Storage Humidity Range
    0 to +90 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
    CPU Frequency
    Derived from Qualcomm Atheros AP.HK09
    System Memory
    1x 512MB, DDR4 2400MHz 16-bit interface
    Frequency Range
    2.412~2.472GHz,
    5.150~5.825GHz
    MiniPCIe Slot
    1x MiniPCIe Slot with PCIe 3.0
    Modulation Techniques
    OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
    Environmental Temperature
    Operating: -20ºC to 70ºC,
    Storage: -40ºC to 90ºC
    Flash
    NOR Flash: 8 MB
    NAND Flash: 256MB
    Wireless
    On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
    On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain
    8x U.FL Connectors
    Reset Buttons
    1x S/W Reset Button
    DC Jack Input
    1x DC Jack Connector: 12V
    Interface
    4x 1Gbps Ethernet Port,
    2x 2.5Gbps Ethernet Port
    2x USB 3.0 Port
    1x JTAG 20 Pin Connector
    1x Serial Port 4 Pin Connector
    LED
    2x RGB LED Indicators
    Power Consumption
    TBD
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
