楼猪我给你抄本书吧。
7-3 Transposing a Bit Matrix
The transpose of a matrix A is a matrix whose columns are the rows of A and whose rows are the columns of A.
Here we consider the problem of computing the transpose of a bit matrix whose elements are single bits that are
packed eight per byte, with rows and columns beginning on byte boundaries. This seemingly simple transformation is
surprisingly costly in instructions executed.
On most machines it would be very slow to load and store individual bits, mainly due to the code that would be
required to extract and (worse yet) to store individual bits. A better method is to partition the matrix into 8x8
submatrices, load each 8x8 submatrix into registers, compute the transpose of the submatrix in registers, and then
store the 8x8 result in the appropriate place in the target matrix. This section first discusses the problem of computing
the transpose of the 8x8 submatrix.
It doesn't matter whether the matrix is stored in row-major or column-major order; computing the transpose consists
of the same operations in either event. Assuming for discussion that it's in row-major order, an 8x8 submatrix is
loaded into eight registers with eight load byte instructions, addressing a column of the source matrix. That is, the
addresses referenced by the load byte instructions are separated by multiples of the source matrix width in bytes.
After the transpose of the 8x8 submatrix is computed, it is stored in a column of the target matrix—that is, it is stored
with eight store byte instructions into locations separated by multiples of the width of the target matrix in bytes (which
is different from the width of the source matrix if the matrices are not square). Thus, we are given eight 8-bit
quantities right-justified in registers a0, a1, …, a7, and we wish to compute eight 8-bit quantities right-justified in
registers b0, b1, …, b7, for use in the store byte instructions. This is illustrated below, where each digit and letter
represents a single bit. Notice that we consider the main diagonal to run from bit 7 of byte 0 to bit 0 of byte 7. Some
readers with a little-endian background may be accustomed to thinking of the main diagonal as running from bit 0 of
byte 0 to bit 7 of byte 7.- a0 = 0123 4567 b0 = 08go wEMU a1 = 89ab cdef b1 = 19hp xFNV a2 =
- ghij klmn b2 = 2aiq yGOW a3 = opqr stuv ==> b3 = 3bjr zHPX a4 = wxyz
- ABCD b4 = 4cks AIQY a5 = EFGH IJKL b5 = 5dlt BJRZ a6 = MNOP
- QRST b6 = 6emu CKS$ a7 = UVWX YZ$. b7 = 7fnv DLT.
The straightforward code for this problem is to select and place each result bit individually, as follows. The
multiplications and divisions represent left and right shifts, respectively.- b0 = (a0 & 128) | (a1 & 128)/2 | (a2 & 128)/4 | (a3 & 128)/8 | (a4 & 128)/16 | (a5 & 128)/32 | (a6 & 128)/64 | (a7 )/128;
- b1 = (a0 & 64)*2 | (a1 & 64) | (a2 & 64)/2 | (a3 & 64)/4 | (a4 & 64)/8 | (a5 & 64)/16 | (a6 & 64)/32 | (a7 & 64)/64;
- b2 = (a0 & 32)*4 | (a1 & 32)*2 | (a2 & 32) | (a3 & 32)/2 | (a4 & 32)/4 | (a5 & 32)/8 | (a6 & 32)/16 | (a7 & 32)/32;
- b3 = (a0 & 16)*8 | (a1 & 16)*4 | (a2 & 16)*2 | (a3 & 16) | (a4 & 16)/2 | (a5 & 16)/4 | (a6 & 16)/8 | (a7 & 16)/16;
- b4 = (a0 & 8)*16 | (a1 & 8)*8 | (a2 & 8)*4 | (a3 & 8)*2 | (a4 & 8) | (a5 & 8)/2 | (a6 & 8)/4 | (a7 & 8)/8;
- b5 = (a0 & 4)*32 | (a1 & 4)*16 | (a2 & 4)*8 | (a3 & 4)*4 | (a4 & 4)*2 | (a5 & 4) | (a6 & 4)/2 | (a7 & 4)/4;
- b6 = (a0 & 2)*64 | (a1 & 2)*32 | (a2 & 2)*16 | (a3 & 2)*8 | (a4 & 2)*4 | (a5 & 2)*2 | (a6 & 2) | (a7 & 2)/2;
- b7 = (a0 )*128| (a1 & 1)*64 | (a2 & 1)*32 | (a3 & 1)*16| (a4 & 1)*8 | (a5 & 1)*4 | (a6 & 1)*2 | (a7 & 1);
This executes in 174 instructions on most machines (62 and's, 56 shift's, and 56 or's). The or's can of course be
add's. On PowerPC it can be done, perhaps surprisingly, in 63 instructions (seven move register's and 56 rotate left
word immediate then mask insert's). We are not counting the load byte and store byte instructions, nor their
addressing code.
Although there does not seem to be a really great algorithm for this problem, the method to be described beats the
straightforward method by more than a factor of 2 on a basic RISC machine.
First, treat the 8x8-bit matrix as 16 2x2-bit matrices, and transpose each of the 16 2x2-bit matrices. Second, treat
the matrix as four 2x2 submatrices whose elements are 2x2-bit matrices and transpose each of the four 2x2
submatrices. Finally, treat the matrix as a 2x2 matrix whose elements are 4x4-bit matrices, and transpose the 2x2
matrix. These transformations are illustrated below.
- 0123 4567 082a 4c6e 08go 4cks 08go wEMU 89ab cdef 193b 5d7f 19hp
- 5dlt 19hp xFNV ghij klmn goiq ksmu 2aiq 6emu 2aiq yGOW opqr stuv
- hpjr ltnv 3bjr 7fnv 3bjr zHPX ==> ==> ==> wxyz
- ABCD wEyG AICK wEMU AIQY 4cks AIQY EFGH IJKL xFzH BJDL xFNV
- BJRZ 5dlt BJRZ MNOP QRST MUOW QYS$ yGOW CKS$ 6emu CKS$ UVWX YZ$. NVPX RZT. zHPX DLT. 7fnv DLT.
Rather than carrying out these steps on the eight individual bytes in eight registers, a net improvement results from first
packing the bytes four to a register, performing the bit-swaps on the two registers, and then unpacking. A complete
procedure is shown in Figure 7-2. Parameter A is the address of the first byte of an 8x8 submatrix of the source
matrix, which is of size 8mx8n bits. Similarly, parameter B is the address of the first byte of an 8x8 submatrix in the
target matrix, which is of size 8nx8m bits. That is, the full source matrix is 8mxn bytes, and the full target matrix is
8nxm bytes.
Figure 7-2 Transposing an 8x8-bit matrix.
- void transpose8(unsigned char A[8], int m, int n, unsigned char B[8]) {
- unsigned x, y, t; // Load the array and pack it into x and y.
- x = (A[0]<<24) | (A[m]<<16) | (A[2*m]<<8) | A[3*m];
- y = (A[4*m]<<24) | (A[5*m]<<16) | (A[6*m]<<8) | A[7*m];
- t = (x ^ (x >> 7)) & 0x00AA00AA; x = x ^ t ^ (t << 7);
- t = (y ^ (y >> 7)) & 0x00AA00AA; y = y ^ t ^ (t << 7);
- t = (x ^ (x >>14)) & 0x0000CCCC; x = x ^ t ^ (t <<14);
- t = (y ^ (y >>14)) & 0x0000CCCC; y = y ^ t ^ (t <<14);
- t = (x & 0xF0F0F0F0) | ((y >> 4) & 0x0F0F0F0F);
- y = ((x << 4) & 0xF0F0F0F0) | (y & 0x0F0F0F0F); x = t;
- B[0]=x>>24; B[n]=x>>16;B[2*n]=x>>8; B[3*n]=x; B[4*n]=y>>24; B[5*n]=y>>16; B[6*n]=y>>8; B[7*n]=y; }
The line
is quite cryptic, for sure. It is swapping bits 1 and 8 (counting from the right), 3 and 10, 5 and 12, and so on, in word
x, while not moving bits 0, 2, 4, and so on. The swaps are done with the exclusive or method of bit swapping,
described on page 40. Word x, before and after the first round of swaps, is
0123 4567 89ab cdef ghij klmn opqr stuv 082a 4c6e 193b 5d7f goiq ksmu hpjr ltnv
To get a realistic comparison of these methods, the naive method described on page 109 was filled out into a
complete program similar to that of Figure 7-2. Both were compiled with the GNU C compiler to a target machine
that is very similar to the basic RISC. The resulting number of instructions, counting all load's, store's , addressing
code, prologs, and epilogs, is 219 for the naive code and 101 for Figure 7-2. (The prologs and epilogs were null,
except for a return branch instruction.) A version of the code of Figure 7-2 adapted to a 64-bit basic RISC (in which
x and y would be held in the same register) would be about 85 instructions.
The algorithm of Figure 7-2 runs from fine to coarse granularity, based on the lengths of the groups of bits that are
swapped. The method can also be run from coarse to fine granularity. To do this, first treat the 8x8-bit matrix as a
2x2 matrix whose elements are 4x4-bit matrices, and transpose the 2x2 matrix. Then treat each the four 4x4
submatrices as a 2x2 matrix whose elements are 2x2-bit matrices, and transpose each of the four 2x2 submatrices,
