[PIC®/AVR®/dsPIC®产品] 怎么个情况MCC启动不了啊
 楼主| xuanhuanzi 发表于 2022-6-23 09:43 | 显示全部楼层 |阅读模式
AC, IDE, PA, ID
一直没反应,是不是版本太老了?怎么升级,需要先升级MPALB X IDE 吗
 楼主| xuanhuanzi 发表于 2022-6-23 10:03 | 显示全部楼层
 楼主| xuanhuanzi 发表于 2022-6-23 10:04 | 显示全部楼层
一直转圈圈,,,,
 楼主| xuanhuanzi 发表于 2022-6-23 10:06 | 显示全部楼层
搞不定了。
lcczg 发表于 2022-6-24 14:53 | 显示全部楼层
联网了没?联网试试。
 楼主| xuanhuanzi 发表于 2022-7-14 15:58 | 显示全部楼层
联网了没?联网试试。
这个软件使用还要联网才行?联网了啊,不然怎么发帖。
lcczg 发表于 2022-7-14 17:28 | 显示全部楼层
不联网会出现另外的错误提示。你看下MPLAB 下面的MCC Log窗口输出内容。我用MPLABX 5.5可以打开Content,得到如下输出
17:21:47.675    INFO: Load event: LOADING
17:21:47.694    INFO: Fetching list of available libraries.
17:21:48.140    INFO: Download Complete: C:\Users\a41438\.mcc\mcc_libraries.xml
17:21:48.249 WARNING: There is no current core runner.
17:21:48.250    INFO: Device Changed. NewDevice = PIC18F45K42 OldDevice = PIC18F25Q10
17:21:48.267    INFO: MCC core services initializing.
17:21:48.307    INFO: Loaded content manager @ /C:/Users/a41438/.mcc/cores/5.3.3/content-manager/content-manager-ui.jar
17:21:48.308    INFO: Starting content manager.
17:21:48.340    INFO: Total time to fetch supported devices for Harmony: 5.273ms
17:21:48.341    INFO: Start MCC
17:21:48.341    INFO: Core Event: CoreLoadEvent
17:21:48.345    INFO: Core v5.3.3 loaded.
17:21:48.345    INFO: Project event: UNINITIALIZED
17:21:48.415    INFO: Connecting to content manager.
17:21:48.428    INFO: Content manager connection time: 13ms.
17:21:48.498    INFO: Total time to fetch supported devices for Classic: 161.312ms
17:21:49.949    INFO: Total time to fetch catalogs for Classic: 1612.515ms
17:21:49.964    INFO: Total time to fetch remote manifests for Classic: 1626.971ms
17:21:50.039    INFO: Time to find all classic libraries in C:\Users\a41438\.mcc\libraries: 90.477ms
17:21:50.046    INFO: Total time to fetch local manifests for Classic: 1708.879ms
17:21:52.284    INFO: Total time to fetch catalogs for Melody: 3949.471ms
17:21:52.293    INFO: Melody local content - getting installed Classic content: 8.221ms
17:21:52.380    INFO: Melody local content - getting installed Melody content: 94.971ms
17:21:52.390    INFO: Total time to fetch local manifests for Melody: 4056.208ms
17:21:55.501    INFO: Total time to fetch supported devices for Melody: 7166.804ms
17:21:55.956    INFO: Total time to fetch remote manifests for Melody: 7622.002ms
17:22:09.405    INFO: Total time to fetch catalogs for Harmony: 21070.537ms
你比较下看看? 另外试过其他电脑吗?
huquanz711 发表于 2022-7-15 07:43 来自手机 | 显示全部楼层
重新安装一下
 楼主| xuanhuanzi 发表于 2022-8-23 18:01 | 显示全部楼层
不联网会出现另外的错误提示。你看下MPLAB 下面的MCC Log窗口输出内容。我用MPLABX 5.5可以打开Content, ...
这个软件不是很好用。
loveyond 发表于 2022-11-11 16:19 | 显示全部楼层
反正我捣鼓了2天才勉强能用。感觉比cube差了2年
hu9jj 发表于 2022-11-11 19:30 | 显示全部楼层
IDE升级到V6.05才行。
[url=home.php?mod=space&uid=3392152]@退出当前登录[/url] :下载安装一个独立运行的MCC程序试试。  发表于 2022-11-16 16:18
我升级到V6.05以后,还是不行,怎么回事啊,大佬?  发表于 2022-11-16 10:01
 楼主| xuanhuanzi 发表于 2022-11-14 14:57 | 显示全部楼层
IDE升级到V6.05才行。
是啊,这玩意儿有新版本后,老版本就启动不了,必须升级,哎。。。
 楼主| xuanhuanzi 发表于 2022-11-14 14:58 | 显示全部楼层
后起之秀,还需要努力,所以不要想跟扛把子抢好用啊。哈哈。
经过这几天我发现,mcc也是会转圈圈,而且只能用melody,不能用classic(也是转圈圈),也经常死机崩溃。 而且melody的配置貌似有bug。哎,心累  发表于 2022-11-15 10:18
退出当前登录 发表于 2022-11-16 09:59 | 显示全部楼层
请问楼主搞定了吗,我也出现这个问题了
