- #include<stdio.h>
- #include<stdlib.h>
- #include<string.h>
- typedef struct
- char data;
- int weight;
- int parent,lchild,rchild;
- }HTNode,*HuffmanTree;
- typedef char **HuffmanCode;
- void Select(HuffmanTree &HT,int m,int &s1,int &s2)//选择两个权值较小的结点,并返回序号
- int i,j,min1,min2;
- min1=min2=1000;
- for(i=1;i<=m;i++)
- if(HT[i].parent==0&&HT[i].weight<min1)
- min1=HT[i].weight;
- s1=i;
- for(j=1;j<=m&&j!=s1;j++)
- if(HT[i].parent==0&&HT[i].weight<min2)
- min2=HT[j].weight;
- s2=j;
- void CreateHuffmanTree(HuffmanTree &HT,int n)//建立哈夫曼树
- if(n<=1) return;
- HT=(HuffmanTree)malloc(sizeof(HTNode)2n);
- int i,j,s1,s2;
- char ch='a';
- for(i=1;i<=(2n-1);++i)
- HT[i].parent=0;
- HT[i].lchild=0;
- HT[i].rchild=0;
- for(j=1;j<=n;++j,ch++)
- if(j==1)
- HT[1].data=' ';
- scanf("%d",&HT[j].weight);
- else
- HT[j].data=ch;
- for(i=n+1;i<=(2n-1);++i)
- Select(HT,i-1,s1,s2);
- HT[s1].parent=i;
- HT[s2].parent=i;
- HT[i].weight=HT[s1].weight+HT[s2].weight;
- HT[i].lchild=s1;
- HT[i].rchild=s2;
- void CreateHuffmanCode(HuffmanTree HT,HuffmanCode &HC,int n)//求哈夫曼编码
- HC=new char*[n+1];
- char *cd;
- cd=(char *)malloc(sizeof(char)*n);
- int i,start,c,f;
- for(i=1;i<=n;++i)
- start=n-1;
- c=i;
- f=HT[i].parent;
- while(f!=0)
- --start;
- if(HT[f].lchild==c) cd[start]='0';//回溯时走左分支为0,右分支为1
- else cd[start]='1';
- c=f;
- f=HT[f].parent;
- HC[i]=(char)malloc(sizeof(char)(n-start));
- strcpy(HC[i],&cd[start]);
- delete(cd);
- void InterpretCode(HuffmanCode HC,char *str)//译码
- int i;
- for(i=0;i<strlen(str);i++)
- if(str[i]==' ') printf("%s",HC[1]);
- else{
- if(str[i]>='A'&&str[i]<='Z') str[i]=str[i]+32;
- if(str[i]>='a'&&str[i]<='z') printf("%s",HC[str[i]-95]);
- int main()
- HuffmanTree HT;
- HuffmanCode HC;
- CreateHuffmanTree(HT,27);
- printf("请输入报文:");
- CreateHuffmanCode(HT,HC,27);
- char s[100];
- gets(s);
- InterpretCode(HC,s);
- return 0;
