我用了ADC1,ADC2,ADC3,DMA1_Stream0,DMA1_Stream1,BDMA_Channel0,ADC1.ADC2.回调函数都是正常工作,就是ADC3.回调函数不能正常工作。有没有遇到这种情况的
芯片是STM32H750.ADC分频得80MHZ
- __HAL_RCC_DMA1_CLK_ENABLE();
- __HAL_RCC_ADC12_CLK_ENABLE();
- hadc1.Instance = ADC1;
- hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV10;
- hadc1.Init.Resolution = ADC_RESOLUTION_16B;
- hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
- hadc1.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
- hadc1.Init.LowPowerAutoWait = DISABLE;
- hadc1.Init.ContinuousConvMode = ENABLE;
- hadc1.Init.NbrOfConversion = 0x04U;
- hadc1.Init.DiscontinuousConvMode = ENABLE;
- hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
- hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
- hadc1.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
- hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
- hadc1.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
- hadc1.Init.OversamplingMode = DISABLE;
- HAL_ADC_Init(&hadc1) ;
- HAL_ADCEx_Calibration_Start(&hadc1, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED);
- /** Configure the ADC multi-mode
- multimode.Mode = ADC_MODE_INDEPENDENT;
- if (HAL_ADCEx_MultiModeConfigChannel(&hadc1, &multimode) != HAL_OK)
- Error_Handler();
- hadc1.Instance = ADC2;
- HAL_ADC_Init(&hadc2) ;
- HAL_ADCEx_Calibration_Start(&hadc2, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED);
- __HAL_RCC_BDMA_CLK_ENABLE();
- __HAL_RCC_ADC3_CLK_ENABLE();
- hadc3.Instance = ADC3;
- hadc3.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV10;
- hadc3.Init.Resolution = ADC_RESOLUTION_16B;
- hadc3.Init.ScanConvMode = ADC_SCAN_ENABLE;
- hadc3.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
- hadc3.Init.LowPowerAutoWait = DISABLE;
- hadc3.Init.ContinuousConvMode = ENABLE;
- hadc3.Init.NbrOfConversion = 0x04U;
- hadc3.Init.DiscontinuousConvMode = ENABLE;
- hadc3.Init.ExternalTrigConv = ADC_SOFTWARE_START;
- hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
- hadc3.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DMA_CIRCULAR;
- hadc3.Init.Overrun = ADC_OVR_DATA_PRESERVED;
- hadc3.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
- hadc3.Init.OversamplingMode = DISABLE;
- HAL_ADC_Init(&hadc3) ;
- HAL_ADCEx_Calibration_Start(&hadc3, ADC_CALIB_OFFSET, ADC_SINGLE_ENDED);
- hdma_adc1.Instance = DMA1_Stream0;
- hdma_adc1.Init.Request = DMA_REQUEST_ADC1;
- hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY;
- hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE;
- hdma_adc1.Init.MemInc = DMA_MINC_ENABLE;
- hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
- hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
- hdma_adc1.Init.Mode = DMA_CIRCULAR;
- hdma_adc1.Init.Priority = DMA_PRIORITY_MEDIUM;
- hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
- HAL_DMA_Init(&hdma_adc1);
- __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc1);
- /* DMA1_Stream0_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(DMA1_Stream0_IRQn, 4, 0);
- HAL_NVIC_EnableIRQ(DMA1_Stream0_IRQn);
- hdma_adc1.Instance = DMA1_Stream1;
- hdma_adc1.Init.Request = DMA_REQUEST_ADC2;
- HAL_DMA_Init(&hdma_adc2);
- __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc2);
- /* DMA1_Stream1_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(DMA1_Stream1_IRQn, 4, 1);
- HAL_NVIC_EnableIRQ(DMA1_Stream1_IRQn);
- hdma_adc3.Instance = BDMA_Channel0;
- hdma_adc3.Init.Request = BDMA_REQUEST_ADC3;
- hdma_adc3.Init.Direction = DMA_PERIPH_TO_MEMORY;
- hdma_adc3.Init.PeriphInc = DMA_PINC_DISABLE;
- hdma_adc3.Init.MemInc = DMA_MINC_ENABLE;
- hdma_adc3.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD;
- hdma_adc3.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD;
- hdma_adc3.Init.Mode = DMA_CIRCULAR;
- hdma_adc3.Init.Priority = DMA_PRIORITY_MEDIUM;
- hdma_adc3.Init.FIFOMode = DMA_FIFOMODE_DISABLE;
- HAL_DMA_Init(&hdma_adc3) ;
- __HAL_LINKDMA(adcHandle,DMA_Handle,hdma_adc3);
- /* DMA interrupt init */
- /* BDMA_Channel0_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(BDMA_Channel0_IRQn, 4, 2);
- HAL_NVIC_EnableIRQ(BDMA_Channel0_IRQn);
- * [url=home.php?mod=space&uid=247401]@brief[/url] Conversion complete callback in non blocking mode
- * [@param](http://www.openedv.com/home.php?mod=space&uid=271674) hadc ADC handle
- * @retval None
- void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
- if(hadc->Instance == ADC1)
- SCB_InvalidateDCache_by_Addr(Adc1Value,ADC_AVERAGE_SIZE);
- printf(" ADC00000: \r\n");
- else if(hadc->Instance == ADC2)
- SCB_InvalidateDCache_by_Addr(Adc2Value,ADC_AVERAGE_SIZE);
- printf(" ADC11111: \r\n");
- else if(hadc->Instance == ADC3)
- SCB_InvalidateDCache_by_Addr(Adc3Value,ADC_AVERAGE_SIZE);
- printf(" ADC22222: \r\n");
- void DMA1_Stream0_IRQHandler(void)
- HAL_DMA_IRQHandler(&hdma_adc1);
- void DMA1_Stream1_IRQHandler(void)
- HAL_DMA_IRQHandler(&hdma_adc2);
- * @brief This function handles BDMA channel0 global interrupt.
- void BDMA_Channel0_IRQHandler(void)
- HAL_DMA_IRQHandler(&hdma_adc3);
