我使用外部中断PC2成功了,但是PC3使用外部中断功能就是不行,我试了下PC3的读取外部输入功能也没错,那PC3是不是有什么特殊配置才能使用外部中断功能呀?这是我的代码,请大家看一看:
链接:https://pan.baidu.com/s/19XWBlQSQPHuDl7fzs9HOcg
提取码:n2bm
/** \file main.c
** \brief This sample demonstrates how to set GPIO as output function.
** - 2018-10-14 1.0 zhangxl first version for Device Driver Library of GPIO.
* Include files
#include "hc32_ddl.h"
#include "led.h"
#include "relay.h"
#include "usart.h"
#define IO1_PORT (PortC)
#define IO1_PIN (Pin02)
#define IO1_ExtiCh (ExtiCh02)
#define IO1_EIR (INT_PORT_EIRQ2)
#define IO2_PORT (PortC)
#define IO2_PIN (Pin03)
#define IO2_ExtiCh (ExtiCh03)
#define IO2_EIR (INT_PORT_EIRQ3)
static uint32_t u32ExtInt03Count = 0ul;
static void ClkInit(void);
void IO1_Callback(void);
void IO1_Init(void);
void IO2_Callback(void);
void IO2_Init(void);
void IO_Init(void);
** \brief ExtInt03 callback function
** \param None
** \retval None
if (Set == EXINT_Irq**Get(IO1_ExtiCh))
//u32ExtInt03Count++;
RLED1_TOGGLE();
Ddl_Delay1ms(3000);
#ifdef __PRINT_TO_TERMINAL
printf("External interrupt 03(SW2) interrupt occurrence: %d\n", u32ExtInt03Count);
#endif
/* clear int request flag */
EXINT_Irq**Clr(IO1_ExtiCh);
if (Set == EXINT_Irq**Get(IO2_ExtiCh))
GLED3_TOGGLE();
Ddl_Delay1ms(3000);
#endif
EXINT_Irq**Clr(IO2_ExtiCh);
** \brief SW2 init function
** \param None
** \retval None
void IO1_Init(void)
/*�ⲿ�ж����ýṹ��*/
stc_exint_config_t stcExtiConfig;
/*irq���ýṹ��*/
stc_irq_regi_conf_t stcIrqRegiConf;
/*GPIO�ܽ����ýṹ��*/
stc_port_init_t stcPortInit;
/* configuration structure initialization */
MEM_ZERO_STRUCT(stcExtiConfig);
MEM_ZERO_STRUCT(stcIrqRegiConf);
MEM_ZERO_STRUCT(stcPortInit);
/*****�ܽų�ʼ��*****/
/*�ⲿ�ж�ʹ��*/
stcPortInit.enExInt = Enable;
PORT_Init(IO1_PORT, IO1_PIN, &stcPortInit);
/*�����ⲿ�жϺ�*/
stcExtiConfig.enExitCh = IO1_ExtiCh;
stcExtiConfig.enFilterEn = Enable;
stcExtiConfig.enFltClk = Pclk3Div8;
/*�͵�ƽ������������ʽ��*/
stcExtiConfig.enExtiLvl = ExIntLowLevel;
EXINT_Init(&stcExtiConfig);
/*****�ⲿ�жϳ�ʼ��*****/
/*ѡ���ⲿ�жϺ�*/
stcIrqRegiConf.enIntSrc = IO1_EIR;
/* ע���жϵ�ַ to Vect.No.001 */
stcIrqRegiConf.enIRQn = Int001_IRQn;
/*�����жϻص�����*/
stcIrqRegiConf.pfnCallback = &IO1_Callback;
enIrqRegistration(&stcIrqRegiConf);
/* Clear pending */
NVIC_ClearPendingIRQ(stcIrqRegiConf.enIRQn);
/*�����ж����ȼ�*/
NVIC_SetPriority(stcIrqRegiConf.enIRQn, DDL_IRQ_PRIORITY_15);
/*ʹ��NVIC*/
NVIC_EnableIRQ(stcIrqRegiConf.enIRQn);
void IO2_Init(void)
/*�ⲿ�ж����ýṹ��*/
/*irq���ýṹ��*/
/*GPIO�ܽ����ýṹ��*/
/*****GPIO�ܽų�ʼ��*****/
/*�ⲿ�ж�ʹ��*/
PORT_Init(IO2_PORT, IO2_PIN, &stcPortInit);
/*�����ⲿ�жϺ�*/
stcExtiConfig.enExitCh = IO2_ExtiCh;
/*�����˲���ʧ��*/
/*�����˲�������ʱ��ѡ��PCLK3/8*/
/*****�ж�ע��*****/
/*ѡ���ⲿ�жϺ�*/
stcIrqRegiConf.enIntSrc = IO2_EIR;
/* ע���ⲿ�жϵ�ַ to Vect.No.000 */
stcIrqRegiConf.enIRQn = Int000_IRQn;
/*�����жϻص�����*/
stcIrqRegiConf.pfnCallback = &IO2_Callback;
/* Clear pending */
/*����NVIC���ȼ�*/
/*ʹ��NVIC*/
** \brief Main function of GPIO output
** \param None
** \retval int32_t Return value, if needed
int32_t main(void)
// ClkInit(); //ϵͳʱ�ӳ�ʼ��
LED_Init(); //LED��ʼ��
// RELAY_Init(); //�̵�����ʼ��
// USART1_init(115200); //���ڳ�ʼ����������Ϊ115200
// IO1_Init();
IO2_Init();
while(1)
YLED2_TOGGLE();
Ddl_Delay1ms(100);
** \brief Initialize Clock.
** \param [in] None
** \retval None
stc_clk_xtal_cfg_t stcXtalCfg;
stc_clk_mpll_cfg_t stcMpllCfg;
en_clk_sys_source_t enSysClkSrc;
stc_clk_sysclk_cfg_t stcSysClkCfg;
MEM_ZERO_STRUCT(enSysClkSrc);
MEM_ZERO_STRUCT(stcSysClkCfg);
MEM_ZERO_STRUCT(stcXtalCfg);
MEM_ZERO_STRUCT(stcMpllCfg);
/* Set bus clk div. */
stcSysClkCfg.enHclkDiv = ClkSysclkDiv1;
stcSysClkCfg.enExclkDiv = ClkSysclkDiv2;
stcSysClkCfg.enPclk0Div = ClkSysclkDiv1;
stcSysClkCfg.enPclk1Div = ClkSysclkDiv2;
stcSysClkCfg.enPclk2Div = ClkSysclkDiv4;
stcSysClkCfg.enPclk3Div = ClkSysclkDiv4;
stcSysClkCfg.enPclk4Div = ClkSysclkDiv2;
CLK_SysClkConfig(&stcSysClkCfg);
/* Switch system clock source to MPLL. */
/* Use Xtal as MPLL source. */
stcXtalCfg.enMode = ClkXtalModeOsc;
stcXtalCfg.enDrv = ClkXtalLowDrv;
stcXtalCfg.enFastStartup = Enable;
CLK_XtalConfig(&stcXtalCfg);
CLK_XtalCmd(Enable);
/* MPLL config. */
stcMpllCfg.pllmDiv = 1u; /* XTAL 8M / 1 */
stcMpllCfg.plln = 50u; /* 8M*50 = 400M */
stcMpllCfg.PllpDiv = 4u; /* MLLP = 100M */
stcMpllCfg.PllqDiv = 4u; /* MLLQ = 100M */
stcMpllCfg.PllrDiv = 4u; /* MLLR = 100M */
CLK_SetPllSource(ClkPllSrcXTAL);
CLK_MpllConfig(&stcMpllCfg);
/* flash read wait cycle setting */
EFM_Unlock();
EFM_SetLatency(EFM_LATENCY_4);
EFM_Lock();
/* Enable MPLL. */
CLK_MpllCmd(Enable);
/* Wait MPLL ready. */
while (Set != CLK_GetFlagStatus(ClkFlagMPLLRdy))
CLK_SetSysClkSource(CLKSysSrcMPLL);
void IO_Init(void)
/*����ģʽ*/
stcPortInit.enPinMode = Pin_Mode_In;
/*�ڲ���������*/
stcPortInit.enPullUp = Enable;
* EOF (not truncated)
