HC32F460 外部中断PC3
796|1
长江一道浪|  楼主 | 2022-7-28 17:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我使用外部中断PC2成功了,但是PC3使用外部中断功能就是不行,我试了下PC3的读取外部输入功能也没错,那PC3是不是有什么特殊配置才能使用外部中断功能呀?这是我的代码,请大家看一看:
链接:https://pan.baidu.com/s/19XWBlQSQPHuDl7fzs9HOcg
提取码:n2bm
/** \file main.c
** \brief This sample demonstrates how to set GPIO as output function.
**   - 2018-10-14  1.0  zhangxl first version for Device Driver Library of GPIO.
* Include files
#include "hc32_ddl.h"
#include "led.h"
#include "relay.h"
#include "usart.h"
#define  IO1_PORT         (PortC)
#define  IO1_PIN          (Pin02)
#define  IO1_ExtiCh             (ExtiCh02)
#define  IO1_EIR                    (INT_PORT_EIRQ2)
#define  IO2_PORT         (PortC)
#define  IO2_PIN          (Pin03)
#define  IO2_ExtiCh             (ExtiCh03)
#define  IO2_EIR                    (INT_PORT_EIRQ3)
static uint32_t u32ExtInt03Count = 0ul;
static void ClkInit(void);
void IO1_Callback(void);
void IO1_Init(void);
void IO2_Callback(void);
void IO2_Init(void);
void IO_Init(void);
** \brief ExtInt03 callback function
** \param  None
** \retval None
    if (Set == EXINT_Irq**Get(IO1_ExtiCh))
        //u32ExtInt03Count++;
        RLED1_TOGGLE();
                Ddl_Delay1ms(3000);
#ifdef  __PRINT_TO_TERMINAL
        printf("External interrupt 03(SW2) interrupt occurrence: %d\n", u32ExtInt03Count);
#endif
        /* clear int request flag */
        EXINT_Irq**Clr(IO1_ExtiCh);
    if (Set == EXINT_Irq**Get(IO2_ExtiCh))
        GLED3_TOGGLE();
                Ddl_Delay1ms(3000);
#endif
        EXINT_Irq**Clr(IO2_ExtiCh);
** \brief SW2 init function
** \param  None
** \retval None
void IO1_Init(void)
        /*�ⲿ�ж����ýṹ��*/
        stc_exint_config_t stcExtiConfig;
        /*irq���ýṹ��*/
        stc_irq_regi_conf_t stcIrqRegiConf;
        /*GPIO�ܽ����ýṹ��*/
        stc_port_init_t stcPortInit;
    /* configuration structure initialization */
    MEM_ZERO_STRUCT(stcExtiConfig);
    MEM_ZERO_STRUCT(stcIrqRegiConf);
    MEM_ZERO_STRUCT(stcPortInit);
        /*****�ܽų�ʼ��*****/
      /*�ⲿ�ж�ʹ��*/
    stcPortInit.enExInt = Enable;
    PORT_Init(IO1_PORT, IO1_PIN, &stcPortInit);
    /*�����ⲿ�жϺ�*/
        stcExtiConfig.enExitCh = IO1_ExtiCh;
    stcExtiConfig.enFilterEn = Enable;
    stcExtiConfig.enFltClk = Pclk3Div8;
    /*�͵�ƽ������������ʽ��*/
    stcExtiConfig.enExtiLvl = ExIntLowLevel;
    EXINT_Init(&stcExtiConfig);
        /*****�ⲿ�жϳ�ʼ��*****/
    /*ѡ���ⲿ�жϺ�*/
    stcIrqRegiConf.enIntSrc = IO1_EIR;
    /* ע���жϵ�ַ to Vect.No.001 */
    stcIrqRegiConf.enIRQn = Int001_IRQn;
    /*�����жϻص�����*/
    stcIrqRegiConf.pfnCallback = &IO1_Callback;
    enIrqRegistration(&stcIrqRegiConf);
    /* Clear pending */
    NVIC_ClearPendingIRQ(stcIrqRegiConf.enIRQn);
    /*�����ж����ȼ�*/
    NVIC_SetPriority(stcIrqRegiConf.enIRQn, DDL_IRQ_PRIORITY_15);
    /*ʹ��NVIC*/
    NVIC_EnableIRQ(stcIrqRegiConf.enIRQn);
void IO2_Init(void)
        /*�ⲿ�ж����ýṹ��*/
        /*irq���ýṹ��*/
        /*GPIO�ܽ����ýṹ��*/
       /*****GPIO�ܽų�ʼ��*****/
        /*�ⲿ�ж�ʹ��*/
    PORT_Init(IO2_PORT, IO2_PIN, &stcPortInit);
    /*�����ⲿ�жϺ�*/
        stcExtiConfig.enExitCh = IO2_ExtiCh;
    /*�����˲���ʧ��*/
        /*�����˲�������ʱ��ѡ��PCLK3/8*/
        /*****�ж�ע��*****/
    /*ѡ���ⲿ�жϺ�*/
    stcIrqRegiConf.enIntSrc = IO2_EIR;
    /* ע���ⲿ�жϵ�ַ to Vect.No.000 */
    stcIrqRegiConf.enIRQn = Int000_IRQn;
    /*�����жϻص�����*/
    stcIrqRegiConf.pfnCallback = &IO2_Callback;
    /* Clear pending */
    /*����NVIC���ȼ�*/
    /*ʹ��NVIC*/
** \brief  Main function of GPIO output
** \param  None
** \retval int32_t Return value, if needed
int32_t main(void)
//  ClkInit();                  //ϵͳʱ�ӳ�ʼ��
        LED_Init();                 //LED��ʼ��
//  RELAY_Init();               //�̵�����ʼ��
//  USART1_init(115200);    //���ڳ�ʼ����������Ϊ115200
//      IO1_Init();
        IO2_Init();
    while(1)
            YLED2_TOGGLE();
      Ddl_Delay1ms(100);
** \brief Initialize Clock.
** \param [in] None
** \retval None
    stc_clk_xtal_cfg_t   stcXtalCfg;
    stc_clk_mpll_cfg_t   stcMpllCfg;
    en_clk_sys_source_t  enSysClkSrc;
    stc_clk_sysclk_cfg_t stcSysClkCfg;
    MEM_ZERO_STRUCT(enSysClkSrc);
    MEM_ZERO_STRUCT(stcSysClkCfg);
    MEM_ZERO_STRUCT(stcXtalCfg);
    MEM_ZERO_STRUCT(stcMpllCfg);
    /* Set bus clk div. */
    stcSysClkCfg.enHclkDiv  = ClkSysclkDiv1;
    stcSysClkCfg.enExclkDiv = ClkSysclkDiv2;
    stcSysClkCfg.enPclk0Div = ClkSysclkDiv1;
    stcSysClkCfg.enPclk1Div = ClkSysclkDiv2;
    stcSysClkCfg.enPclk2Div = ClkSysclkDiv4;
    stcSysClkCfg.enPclk3Div = ClkSysclkDiv4;
    stcSysClkCfg.enPclk4Div = ClkSysclkDiv2;
    CLK_SysClkConfig(&stcSysClkCfg);
    /* Switch system clock source to MPLL. */
    /* Use Xtal as MPLL source. */
    stcXtalCfg.enMode = ClkXtalModeOsc;
    stcXtalCfg.enDrv = ClkXtalLowDrv;
    stcXtalCfg.enFastStartup = Enable;
    CLK_XtalConfig(&stcXtalCfg);
    CLK_XtalCmd(Enable);
    /* MPLL config. */
    stcMpllCfg.pllmDiv = 1u; /* XTAL 8M / 1 */
    stcMpllCfg.plln = 50u;   /* 8M*50 = 400M */
    stcMpllCfg.PllpDiv = 4u; /* MLLP = 100M */
    stcMpllCfg.PllqDiv = 4u; /* MLLQ = 100M */
    stcMpllCfg.PllrDiv = 4u; /* MLLR = 100M */
    CLK_SetPllSource(ClkPllSrcXTAL);
    CLK_MpllConfig(&stcMpllCfg);
    /* flash read wait cycle setting */
    EFM_Unlock();
    EFM_SetLatency(EFM_LATENCY_4);
    EFM_Lock();
    /* Enable MPLL. */
    CLK_MpllCmd(Enable);
    /* Wait MPLL ready. */
    while (Set != CLK_GetFlagStatus(ClkFlagMPLLRdy))
    CLK_SetSysClkSource(CLKSysSrcMPLL);
void IO_Init(void)
        /*����ģʽ*/
    stcPortInit.enPinMode = Pin_Mode_In;
        /*�ڲ���������*/
    stcPortInit.enPullUp = Enable;
* EOF (not truncated)
长江一道浪|  楼主 | 2022-7-29 10:15 | 只看该作者
哪位能否试一下PC3的外部中断呀?
