[WIFI模块] IPQ6010 Qualcomm Atheros/Industrial Wifi Router Wallys/wifi6E/DR6018
 楼主| lilywallys 发表于 2022-11-15 11:48 | 显示全部楼层 |阅读模式
Industrial Wifi Router Wallys/IPQ6010 Qualcomm Atheros wifi6E/DR6018
Qualcomm IPQ6010 processor can provide up to 16560DMIPS computing power,plus eight independent signal amplifiers,to achieve 6600MB 160MHz high bandwidth,with powerful performance.
Today let’s talk about a routerboard based on Qualcomm IPQ6010 processor from Wallys.It’s called DR6018.It’s routerboard support QUECTEL RM500Q-GL and QCN9074 WiFi 6E Card.
The DR6018 routerboard is the perfect solution for high-performance computing (HPC) applications. This routerboard provides dual-band WiFi and Gigabit Ethernet, as well as USB 3.0 host connectivity, to give you a powerful and versatile platform to build your next HPC system on.
The Qualcomm-Atheros IPQ6010 quad-core ARM 64bit A53 @1.8GHz processor provides ample performance for most applications, allowing you to run multiple virtual machines simultaneously without any lag or latency issues. The 1GB DDRL3L system memory provides enough memory for your desktop applications, while the 32MB NOR flash and 256MB NAND flash provide storage space for large datasets that would otherwise take up too much space on the hard drive or RAM.
The DR6018 routerboard supports Dynamic Frequency Selection (DFS), which lets you adjust the CPU frequency according to the workload being performed by each virtual machine. This allows you to optimize power consumption while maintaining high performance levels across all of your virtual machines simultaneously, ensuring that your system will perform at peak efficiency regardless of how many tasks need to be run simultaneously on any one machine in turn!
Click below the link for more information about DR6018
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
If you're looking for a company that can provide reliable and cost-effective routerboards and wireless network cards, you've come to the right place!
Wallys has been in the wireless industry for over 15 years and has designed and manufactured many high-quality products.We have a strong track record of providing customized solutions based on your specifications, so let us know if you have any questions.
If you would like to learn more about our products or contact us directly, please feel free to shoot us a message!
Email:sales1@wallystech.com
Wallys Communications (SuZhou) Co.,Ltd
http://www.wallystech.com
