- #include <stdio.h>
- // 获取结构体成员大小
- #define GET_MEMBER_SIZE(type, member) sizeof(((type*)0)->member)
- // 获取结构体成员偏移量
- #define GET_MEMBER_OFFSET(type, member) ((size_t)(&(((type*)0)->member)))
- typedef struct _test_struct0
- char x;
- char y;
- char z;
- }test_struct0;
- typedef struct _test_struct1
- char a;
- char c;
- short b;
- int d;
- test_struct0 e;
- }test_struct1;
- int main(int arc, char *argv[])
- printf("GET_MEMBER_SIZE(test_struct1, a) = %ld\n", GET_MEMBER_SIZE(test_struct1, a));
- printf("GET_MEMBER_SIZE(test_struct1, c) = %ld\n", GET_MEMBER_SIZE(test_struct1, c));
- printf("GET_MEMBER_SIZE(test_struct1, b) = %ld\n", GET_MEMBER_SIZE(test_struct1, b));
- printf("GET_MEMBER_SIZE(test_struct1, d) = %ld\n", GET_MEMBER_SIZE(test_struct1, d));
- printf("GET_MEMBER_SIZE(test_struct1, e) = %ld\n", GET_MEMBER_SIZE(test_struct1, e));
- printf("test_struct1 size = %ld\n", sizeof(test_struct1));
- printf("GET_MEMBER_OFFSET(a): %ld\n", GET_MEMBER_OFFSET(test_struct1, a));
- printf("GET_MEMBER_OFFSET(c): %ld\n", GET_MEMBER_OFFSET(test_struct1, c));
- printf("GET_MEMBER_OFFSET(b): %ld\n", GET_MEMBER_OFFSET(test_struct1, b));
- printf("GET_MEMBER_OFFSET(d): %ld\n", GET_MEMBER_OFFSET(test_struct1, d));
- printf("GET_MEMBER_OFFSET(e): %ld\n", GET_MEMBER_OFFSET(test_struct1, e));
- return 0;
复制代码
