[STM32F1] F103ZE通过FSMC读AD7606数据
 楼主| 铁血丹心LLLL 发表于 2023-7-27 16:08 | 显示全部楼层 |阅读模式
因为项目需求需要做个高速模拟量采集,然后就买了一套德飞莱的F429开发板,准备降低成本改用F103来做。
改写的F103ZE通过FSMC读AD7606程序,改写到一半项目暂缓了,做个笔记先……
  1. //初始化FSMC相关功能
  2. //初始化FSMC相关功能
  3. void AD7606_FSMC_Init(void)
  4. {
  5.     GPIO_InitTypeDef GPIO_InitStructure;
  6.     FSMC_NORSRAMInitTypeDef  FSMC_NORSRAMInitStructure;
  7.     FSMC_NORSRAMTimingInitTypeDef  readWriteTiming;
  8.     //FSMC_NORSRAMTimingInitTypeDef  writeTiming;
  9.     RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC,ENABLE);        //使能FSMC时钟
  10.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOE,ENABLE);//使能FSMC的数据脚时钟
  11.     //FSMC的数据脚1/2
  12.     //PORTD复用推挽输出
  13.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_14|GPIO_Pin_15;
  14.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  //复用推挽输出
  15.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  16.     GPIO_Init(GPIOD, &GPIO_InitStructure);
  17.     //FSMC的数据脚2/2
  18.     //PORTE复用推挽输出
  19.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  20.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  //复用推挽输出
  21.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  22.     GPIO_Init(GPIOE, &GPIO_InitStructure);
  23.     //NOE读信号线
  24.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  25.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  //复用推挽输出
  26.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.     GPIO_Init(GPIOD, &GPIO_InitStructure);
  28.     //NWE写信号线
  29.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  30.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  //复用推挽输出
  31.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  32.     GPIO_Init(GPIOD, &GPIO_InitStructure);
  33.     //NE4片选信号线
  34.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG,ENABLE);
  35.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  36.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                  //复用推挽输出
  37.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  38.     GPIO_Init(GPIOG, &GPIO_InitStructure);
  39.     //HCLK=72MHz,0为1个周期
  40.     //对于AD7606芯片
  41.     //数据保持时间:RD低电平持续时间,表中T10最小为21ns
  42.     //地址建立时间:RD高电平持续时间,表中T11最小为15ns
  43.     //HCLK的1个脉冲时间长为1/72M=13.88ns
  44.     //A模式下,实际时间(设置值+1)*13.88ns
  45.     readWriteTiming.FSMC_AddressSetupTime = 0x01;                                 //地址建立时间(ADDSET)
  46.     readWriteTiming.FSMC_AddressHoldTime = 0x00;                                 //地址保持时间(ADDHLD)模式A未用到
  47.     readWriteTiming.FSMC_DataSetupTime = 0x01;                                         // 数据保存时间
  48.     readWriteTiming.FSMC_BusTurnAroundDuration = 0x00;        //总线恢复时间,用于NOR-FLASH时间时钟线和地址线复用的情况
  49.     readWriteTiming.FSMC_CLKDivision = 0x00;                                                //控制FSMC_CLK时钟分频
  50.     readWriteTiming.FSMC_DataLatency = 0x00;                                                //数据保持时间,用于同步NOR-FLASH
  51.     readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A;         //模式A
  52.     //0x6C000000-0x6FFFFFFF
  53.     //NE4:PG12
  54.     FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM4;//  这里我们使用NE4 ,也就对应BTCR[6],[7]。
  55.     FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; // 不复用数据地址
  56.     FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM;  //SRAM
  57.     FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit
  58.     FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable;
  59.     FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low;
  60.     FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable;
  61.     FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable;
  62.     FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState;
  63.     FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable;        //  存储器写使能
  64.     FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable;
  65.     FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable;        // FSMC_ExtendedMode_Enable; // 读写使用不同的时序
  66.     FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable;
  67.     FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; //读写时序
  68.     FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming;  //写时序
  69.     FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure);  //初始化FSMC配置
  70.     FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM4, ENABLE);  // 使能BANK1
  71. }
附带引脚连接:
gejigeji521 发表于 2023-7-27 21:48 | 显示全部楼层
挺好,做笔记是好习惯。
地瓜patch 发表于 2023-7-27 22:16 来自手机 | 显示全部楼层
这是个好习惯
怪诞新 发表于 2023-8-29 15:03 | 显示全部楼层
F103,楼主做完能达到多少采样率,反正我测下来很低,几十K都达不到
Stahan 发表于 2023-9-2 23:17 | 显示全部楼层
F1可以满足需求吗?
Jacquetry 发表于 2023-9-4 21:29 | 显示全部楼层
这个采集速度能达到嘛?
