[技术问答] HC32L110单片机GPIO中断搞不定
 楼主| wlm3000 发表于 2023-9-24 19:27 | 显示全部楼层 |阅读模式
* Copyright (C) 2016, Xiaohua Semiconductor Co.,Ltd All rights reserved.
* This software is owned and published by:
* Xiaohua Semiconductor Co.,Ltd ("XHSC").
* BY DOWNLOADING, INSTALLING OR USING THIS SOFTWARE, YOU AGREE TO BE BOUND
* BY ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT.
* This software contains source code for use with XHSC
* components. This software is licensed by XHSC to be adapted only
* for use in systems utilizing XHSC components. XHSC shall not be
* responsible for misuse or illegal use of this software for devices not
* supported herein. XHSC is providing this software "AS IS" and will
* not be responsible for issues arising from incorrect user implementation
* of the software.
* Disclaimer:
* XHSC MAKES NO WARRANTY, EXPRESS OR IMPLIED, ARISING BY LAW OR OTHERWISE,
* REGARDING THE SOFTWARE (INCLUDING ANY ACOOMPANYING WRITTEN MATERIALS),
* ITS PERFORMANCE OR SUITABILITY FOR YOUR INTENDED USE, INCLUDING,
* WITHOUT LIMITATION, THE IMPLIED WARRANTY OF MERCHANTABILITY, THE IMPLIED
* WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE OR USE, AND THE IMPLIED
* WARRANTY OF NONINFRINGEMENT.
* XHSC SHALL HAVE NO LIABILITY (WHETHER IN CONTRACT, WARRANTY, TORT,
* NEGLIGENCE OR OTHERWISE) FOR ANY DAMAGES WHATSOEVER (INCLUDING, WITHOUT
* LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS, BUSINESS INTERRUPTION,
* LOSS OF BUSINESS INFORMATION, OR OTHER PECUNIARY LOSS) ARISING FROM USE OR
* INABILITY TO USE THE SOFTWARE, INCLUDING, WITHOUT LIMITATION, ANY DIRECT,
* INDIRECT, INCIDENTAL, SPECIAL OR CONSEQUENTIAL DAMAGES OR LOSS OF DATA,
* SAVINGS OR PROFITS,
* EVEN IF Disclaimer HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES.
* YOU ASSUME ALL RESPONSIBILITIES FOR SELECTION OF THE SOFTWARE TO ACHIEVE YOUR
* INTENDED RESULTS, AND FOR THE INSTALLATION OF, USE OF, AND RESULTS OBTAINED
* FROM, THE SOFTWARE.
* This software may be replicated in part or whole for the licensed use,
* with the restriction that this Disclaimer and Copyright notice must be
* included with each copy of this software, whether used in part or whole,
* at all times.
/** \file main.c
** A detailed description is available at
** @link Sample Group Some description @endlink
**   - 2016-02-16  1.0  XYZ First version for Device Driver Library of Module.
* Include files
#include "gpio.h"
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
* Local type definitions ('typedef')
typedef struct {
    uint8_t u8Port;
    uint8_t u8Pin;
}stc_gpio_list_t;
* Local function prototypes ('static')
* Local variable definitions ('static')                                      *
const stc_gpio_list_t gGpiolist[] =
    /*{ 0, 0 }, */{ 0, 1 }, { 0, 2 }, /*{ 0, 3 },*/
    { 1, 4 }, { 1, 5 },
    { 2, 3 }, { 2, 4 }, { 2, 5 }, { 2, 6 },
    { 2, 7 },
    { 3, 1 },
    { 3, 2 }, { 3, 3 }, { 3, 4 }, { 3, 5 }, { 3, 6 },
#define TEST_PORT       (1)
#define TEST_PIN        (5)
#define SK_SW2_INIT()       Gpio_InitIO(3, 3, GpioDirIn)
#define SK_SW2_GET()        Gpio_GetIO(3,3)
#define NextStep()          { while (TRUE == Gpio_GetIO(3,3));\
                                delay1ms(200);\
#define SK_LED_INIT()       Gpio_InitIO(1, 5, GpioDirOut)
#define SK_LED_SET(x)       Gpio_SetIO(1,5,(x))
* Function implementation - global ('extern') and local ('static')
* \brief   Gpio_IRQHandler
*          any interrput blinking a led.
* \param   [in]  u8Param            port index
* \retval  void
void Gpio_IRQHandler(uint8_t u8Param)
    *((uint32_t *)((uint32_t)&M0P_GPIO->P3ICLR + u8Param * 0x40)) = 0;
    SK_LED_SET(0);
    delay1ms(500);
    SK_LED_SET(1);
    delay1ms(500);
** \brief  Main function of project
** \return uint32_t return value, if needed
** This sample
int32_t main(void)
    //SW2 控制程序继续运行
    SK_SW2_INIT();
    NextStep();
    //GPIO初始化,配置P15为输出,外接LED
    Gpio_InitIO(TEST_PORT, TEST_PIN, GpioDirOut);
    Gpio_SetIO(TEST_PORT, TEST_PIN, TRUE);
    //初始化外部IO P33
    Gpio_InitIOExt(3, 3, GpioDirIn, TRUE, FALSE, FALSE, 0);
    //开启GPIO中断
    Gpio_ClearIrq(3, 3);
    //Gpio_EnableIrq(3, 3, GpioIrqRising);
          Gpio_EnableIrq(3, 3, GpioIrqFalling);
    EnableNvic(PORT3_IRQn, DDL_IRQ_LEVEL_DEFAULT, TRUE);
    while (1);
* EOF (not truncated)
这个是官方GPIO中断例程,按键触发中断后,会一直不断的进入中断,不知道怎样改,使每次触发中断后,只产生一次中断。
程序中设置的是下降沿中断,照理应该只产生一次中断
 楼主| wlm3000 发表于 2023-9-24 20:31 | 显示全部楼层
现在有一个正在开发的项目,使用的是HC32L110芯片,用IO口检测交流电源50HZ的过零信号去触发可控硅。GPIO中断搞不定,项目没法进行下去了。望各位高手指点!
Q80351951 发表于 2023-9-25 08:36 | 显示全部楼层
一直中断大概率就是中断标志没清掉
wubangmi 发表于 2023-9-25 09:09 | 显示全部楼层
 楼主| wlm3000 发表于 2023-9-25 11:09 | 显示全部楼层
中断口是P3.3阿
xch 发表于 2023-9-25 12:42 | 显示全部楼层
    SK_LED_SET(0);
    delay1ms(500);
    SK_LED_SET(1);
    delay1ms(500);
看起来不像原厂的
wubangmi 发表于 2023-9-25 13:17 | 显示全部楼层
你要透过表象,理解本质。
要么你改成P0CLR,要么去掉后面的u8Param*0x40.二选一,你自己看着办
gaoyang9992006 发表于 2023-9-25 19:27 | 显示全部楼层
这个程序风格,看了头大。
 楼主| wlm3000 发表于 2023-9-26 13:20 | 显示全部楼层
改了后,功能正常了
53372370 发表于 2024-3-14 14:29 | 显示全部楼层
小夏天的大西瓜 发表于 2024-3-26 20:50 | 显示全部楼层
应该还是中断的设置问题
kmnqhaha 发表于 2024-4-30 17:12 | 显示全部楼层
中断标志没清理掉,
han0097 发表于 2025-7-26 23:05 | 显示全部楼层
这个单片机市场用的多吗?
han0097 发表于 2025-7-26 23:06 | 显示全部楼层
你要透过表象,理解本质。
要么你改成P0CLR,要么去掉后面的u8Param*0x40.二选一,你自己看着办 ...
typedef struct {
    uint8_t u8Port;
    uint8_t u8Pin;
}stc_gpio_list_t;
    { 1, 4 }, { 1, 5 },
    { 2, 7 },
    { 3, 1 },
这段好像没用到啊,有啥作用吗?
probedog 发表于 2025-7-31 15:47 | 显示全部楼层
按键抖动?机械按键在按下/释放时会产生毛刺信号,导致多次触发中断。
onlycook 发表于 2025-7-31 15:50 | 显示全部楼层
在中断处理函数中临时禁用中断,处理完成后重新启用。
七毛钱 发表于 2025-7-31 15:51 | 显示全部楼层
每次进入中断时清除标志位。
内政奇才 发表于 2025-7-31 15:51 | 显示全部楼层
启用内部上拉电阻,防止引脚悬空。
classroom 发表于 2025-7-31 16:48 | 显示全部楼层
中断标志未正确清除。
flycamelaaa 发表于 2025-7-31 16:48 | 显示全部楼层
可能是中断配置问题。
