- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 2 $
- * $Date: 14/05/14 6:35p $
- * [url=home.php?mod=space&uid=247401]@brief[/url] MPU9250 project for Nano100 series MCU
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "Nano100Series.h"
- #include "NuEdu-Basic01.h"
- #include "CJMCU116.h"
- #include "MPU9250.h"
- uint8_t BUF[10];
- int16_t T_X, T_Y, T_Z, T_T;
- /* Init System Clock */
- void SYS_Init(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Enable External XTAL (4~24 MHz) */
- //CLK->PWRCTL |= CLK_PWRCTL_HXT_EN_Msk;
- CLK->PWRCTL |= CLK_PWRCTL_HIRC_EN_Msk;
- /* Waiting for 12MHz clock ready */
- //while((CLK->CLKSTATUS & CLK_CLKSTATUS_HXT_STB_Msk) == 0){};
- while ((CLK->CLKSTATUS & CLK_CLKSTATUS_HIRC_STB_Msk) == 0) {};
- /* Switch PLL clock source to XTAL */
- //CLK->PLLCTL &= CLK_PLLCTL_PLL_SRC_HXT;
- CLK->PLLCTL &= CLK_PLLCTL_PLL_SRC_HIRC;
- /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
- CLK->PLLCTL &= CLK_PLLCTL_PD_Msk;
- /* Set PLL frequency 84 MHz */
- CLK->PLLCTL |= 0x0218;
- /* Waiting for clock ready */
- while ((CLK->CLKSTATUS & CLK_CLKSTATUS_PLL_STB_Msk) == 0) {};
- /* Set HCLK_N = 1 */
- CLK->CLKDIV0 = (CLK->CLKDIV0 & ~CLK_CLKDIV0_HCLK_N_Msk) | 0x01;
- /* Switch HCLK clock source to PLL */
- CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_PLL;
- /* Update System Core Clock */
- /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
- SystemCoreClockUpdate();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init UART1 */
- void UART1_Init(void)
- /* Set PC.10 and PC.11 multi-function pins for UART1_RXD, UART1_TXD */
- SYS->PC_H_MFP |= (SYS_PC_H_MFP_PC11_MFP_UART1_TX | SYS_PC_H_MFP_PC10_MFP_UART1_RX);
- /* Enable UART1 IP clock */
- CLK->APBCLK |= CLK_APBCLK_UART1_EN_Msk;
- /* Set UART1 IP clock source */
- CLK->CLKSEL1 |= CLK_CLKSEL1_UART_S_HXT;
- /* Configure UART1 and set UART1 Baudrate */
- UART1->BAUD = UART_BAUD_MODE0 | UART_BAUD_MODE0_DIVIDER(FREQ_12MHZ, 115200);
- UART1->TLCTL = UART_WORD_LEN_8 | UART_PARITY_NONE | UART_STOP_BIT_1;
- // Init MPU9250
- void Init_MPU9250(void)
- I2C0_Write(GYRO_ADDRESS, PWR_MGMT_1, 0x00);
- I2C0_Write(GYRO_ADDRESS, SMPLRT_DIV, 0x07);
- I2C0_Write(GYRO_ADDRESS, CONFIG, 0x06);
- I2C0_Write(GYRO_ADDRESS, GYRO_CONFIG, 0x18);
- I2C0_Write(GYRO_ADDRESS, ACCEL_CONFIG, 0x01);
- * @brief Obtaining Accelerometer values (RAW Data)
- * @param none
- * [url=home.php?mod=space&uid=266161]@return[/url] none
- * [url=home.php?mod=space&uid=1543424]@Details[/url] Obtaining Accelerometer values
- void READ_MPU9250_ACCEL(void)
- BUF[0] = I2C0_Read(ACCEL_ADDRESS, ACCEL_XOUT_L);
- BUF[1] = I2C0_Read(ACCEL_ADDRESS, ACCEL_XOUT_H);
- T_X = (BUF[1] << 8) | BUF[0];
- T_X /= 164;
- BUF[2] = I2C0_Read(ACCEL_ADDRESS, ACCEL_YOUT_L);
- BUF[3] = I2C0_Read(ACCEL_ADDRESS, ACCEL_YOUT_H);
- T_Y = (BUF[3] << 8) | BUF[2];
- T_Y /= 164;
- BUF[4] = I2C0_Read(ACCEL_ADDRESS, ACCEL_ZOUT_L);
- BUF[5] = I2C0_Read(ACCEL_ADDRESS, ACCEL_ZOUT_H);
- T_Z = (BUF[5] << 8) | BUF[4];
- T_Z /= 164;
- * @brief Obtaining gyroscope values (RAW Data)
- * @param none
- * @return none
- * @details Obtaining gyroscope values
- void READ_MPU9250_GYRO(void)
- BUF[0] = I2C0_Read(GYRO_ADDRESS, GYRO_XOUT_L);
- BUF[1] = I2C0_Read(GYRO_ADDRESS, GYRO_XOUT_H);
- T_X /= 16.4;
- BUF[2] = I2C0_Read(GYRO_ADDRESS, GYRO_YOUT_L);
- BUF[3] = I2C0_Read(GYRO_ADDRESS, GYRO_YOUT_H);
- T_Y /= 16.4;
- BUF[4] = I2C0_Read(GYRO_ADDRESS, GYRO_ZOUT_L);
- BUF[5] = I2C0_Read(GYRO_ADDRESS, GYRO_ZOUT_H);
- T_Z /= 16.4;
- * @brief Obtaining Magnetomet values (RAW Data)
- * @param none
- * @return none
- * @details Obtaining Magnetomet values
- void READ_MPU9250_MAG(void)
- I2C0_Write(GYRO_ADDRESS, 0x37, 0x02); //turn on Bypass Mode
- CLK_SysTickDelay(10000);
- I2C0_Write(MAG_ADDRESS, 0x0A, 0x01);
- BUF[0] = I2C0_Read(MAG_ADDRESS, MAG_XOUT_L);
- BUF[1] = I2C0_Read(MAG_ADDRESS, MAG_XOUT_H);
- BUF[2] = I2C0_Read(MAG_ADDRESS, MAG_YOUT_L);
- BUF[3] = I2C0_Read(MAG_ADDRESS, MAG_YOUT_H);
- BUF[4] = I2C0_Read(MAG_ADDRESS, MAG_ZOUT_L);
- BUF[5] = I2C0_Read(MAG_ADDRESS, MAG_ZOUT_H);
- /* MAIN function */
- int main()
- /* Initial system */
- SYS_Init();
- /* Initial UART1 to 115200-8n1 for print message */
- UART1_Init();
- printf("Hello World.\n");
- printf("PLL Clock = %d Hz\n", CLK_GetPLLClockFreq());
- printf("Core Clock = %d Hz\n\n", CLK_GetHCLKFreq());
- printf("+-------------------------------------------------------+\n");
- printf("| Nano100 Series I2C Sample Code with MPU9250 |\n");
- /* Initial I2C */
- I2C0_Init(100);
- Init_MPU9250(); //Initialization MPU9250
- while (1)
- READ_MPU9250_ACCEL(); // Gravity acceleration 0.01g
- printf("ACCEL: X: %4d Y: %4d Z: %4d /0.01 g\n", T_X, T_Y, T_Z);
- READ_MPU9250_GYRO(); //angular velocity 1dps
- printf("GYRO : X: %4d Y: %4d Z: %4d /1 dps\n", T_X, T_Y, T_Z);
- READ_MPU9250_MAG(); //Magnetometer
- printf("MAG : X: %4d Y: %4d Z: %4d /0.6 uT\n\n\n", T_X, T_Y, T_Z);
- CLK_SysTickDelay(300000);
- /*** (C) COPYRIGHT 2014 Nuvoton Technology Corp. ***/
