- #include "oled.h"
- #include "stdlib.h"
- #include "string.h"
- #include "at32f423.h"
- #include "at32f423_board.h"
- #include "oledfont.h"
- #include "i2c_application.h"
- #include "at32f423_conf.h"
- #define I2Cx_ADDRESS 0x78
- #define I2Cx_PORT I2C1
- #define I2Cx_CLK CRM_I2C1_PERIPH_CLOCK
- #define I2Cx_DMA DMA1
- #define I2Cx_DMA_CLK CRM_DMA1_PERIPH_CLOCK
- #define I2Cx_SCL_GPIO_CLK CRM_GPIOB_PERIPH_CLOCK
- #define I2Cx_SCL_GPIO_PIN GPIO_PINS_6
- #define I2Cx_SCL_GPIO_PinsSource GPIO_PINS_SOURCE6
- #define I2Cx_SCL_GPIO_PORT GPIOB
- #define I2Cx_SCL_GPIO_MUX GPIO_MUX_4
- #define I2Cx_SDA_GPIO_CLK CRM_GPIOB_PERIPH_CLOCK
- #define I2Cx_SDA_GPIO_PIN GPIO_PINS_7
- #define I2Cx_SDA_GPIO_PinsSource GPIO_PINS_SOURCE7
- #define I2Cx_SDA_GPIO_PORT GPIOB
- #define I2Cx_SDA_GPIO_MUX GPIO_MUX_4
- #define I2Cx_CLKCTRL 0x10F03C6A
- i2c_handle_type hi2cx;
- static unsigned char OLED_buffer[1024] = {0};
- void OLED_WR_Byte(unsigned char dat,unsigned char cmd) {
- if(cmd) {
- Write_IIC_Data(dat);
- } else {
- Write_IIC_Command(dat);
- void OLED_Set_Pos(unsigned char x, unsigned char y) {
- OLED_WR_Byte(YLevel+y/PAGE_SIZE,OLED_CMD);
- OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
- OLED_WR_Byte((x&0x0f),OLED_CMD);
- void OLED_Display_On(void) {
- OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
- OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
- OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
- void OLED_Display_Off(void) {
- OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
- OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
- void OLED_Set_Pixel(unsigned char x, unsigned char y,unsigned char color) {
- if(color) {
- OLED_buffer[(y/PAGE_SIZE)*WIDTH+x]|= (1<<(y%PAGE_SIZE))&0xff;
- } else {
- OLED_buffer[(y/PAGE_SIZE)*WIDTH+x]&= ~((1<<(y%PAGE_SIZE))&0xff);
- void OLED_Display(void) {
- uint8_t i,n;
- for(i=0;i<(PAGE_SIZE);i++) {
- OLED_WR_Byte (YLevel+i,OLED_CMD); //设置页地址(0~3)
- OLED_WR_Byte (XLevelL,OLED_CMD); //设置显示位置—列低地址
- OLED_WR_Byte (XLevelH,OLED_CMD); //设置显示位置—列高地址
- for(n=0;n<WIDTH;n++) {
- OLED_WR_Byte(OLED_buffer[i*WIDTH+n],OLED_DATA);
- } //更新显示
- void OLED_Clear(void) {
- memset(OLED_buffer,0,sizeof(OLED_buffer));
- OLED_Display();
- void OLED_Init(void) {
- II2CGpioInit();
- delay_ms(200);
- /**************初始化SSD1306*****************/
- // OLED_Display_Off(); //power off
- OLED_WR_Byte(0xAE,OLED_CMD);//--display off
- OLED_WR_Byte(0x20,OLED_CMD);//---set low column address
- OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
- OLED_WR_Byte(0xb0,OLED_CMD);
- OLED_WR_Byte(0xC8,OLED_CMD);//-not offset
- OLED_WR_Byte(0x00,OLED_CMD);// contract control
- OLED_WR_Byte(0x40,OLED_CMD);//--128
- OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register
- OLED_WR_Byte(0xFF,OLED_CMD);
- OLED_WR_Byte(0xA1,OLED_CMD);//set segment remap
- OLED_WR_Byte(0xA6,OLED_CMD);//--normal / reverse
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x3F,OLED_CMD);
- OLED_WR_Byte(0xa4,OLED_CMD);//-set display offset
- OLED_WR_Byte(0xd3,OLED_CMD);
- OLED_WR_Byte(0xD5,OLED_CMD);//set osc division
- OLED_WR_Byte(0xF0,OLED_CMD);
- OLED_WR_Byte(0xD9,OLED_CMD);//Set Pre-Charge Period
- OLED_WR_Byte(0x22,OLED_CMD);
- OLED_WR_Byte(0xDA,OLED_CMD);//set com pin configuartion
- OLED_WR_Byte(0x12,OLED_CMD);
- OLED_WR_Byte(0xDB,OLED_CMD);//set Vcomh
- OLED_WR_Byte(0x8D,OLED_CMD);//set charge pump enable
- OLED_WR_Byte(0x14,OLED_CMD);
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
- void i2c_lowlevel_init(i2c_handle_type* hi2c)
- gpio_init_type gpio_init_structure;
- if(hi2c->i2cx == I2Cx_PORT)
- /* i2c periph clock enable */
- crm_periph_clock_enable(I2Cx_CLK, TRUE);
- crm_periph_clock_enable(I2Cx_SCL_GPIO_CLK, TRUE);
- crm_periph_clock_enable(I2Cx_SDA_GPIO_CLK, TRUE);
- /* gpio configuration */
- gpio_pin_mux_config(I2Cx_SCL_GPIO_PORT, I2Cx_SCL_GPIO_PinsSource, I2Cx_SCL_GPIO_MUX);
- gpio_pin_mux_config(I2Cx_SDA_GPIO_PORT, I2Cx_SDA_GPIO_PinsSource, I2Cx_SDA_GPIO_MUX);
- /* configure i2c pins: scl */
- gpio_init_structure.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
- gpio_init_structure.gpio_mode = GPIO_MODE_MUX;
- gpio_init_structure.gpio_out_type = GPIO_OUTPUT_OPEN_DRAIN;
- gpio_init_structure.gpio_pull = GPIO_PULL_UP;
- gpio_init_structure.gpio_pins = I2Cx_SCL_GPIO_PIN;
- gpio_init(I2Cx_SCL_GPIO_PORT, &gpio_init_structure);
- /* configure i2c pins: sda */
- gpio_init_structure.gpio_pins = I2Cx_SDA_GPIO_PIN;
- gpio_init(I2Cx_SDA_GPIO_PORT, &gpio_init_structure);
- /* config i2c */
- i2c_init(hi2c->i2cx, 0x0F, I2Cx_CLKCTRL);
- i2c_own_address1_set(hi2c->i2cx, I2C_ADDRESS_MODE_7BIT, I2Cx_ADDRESS);
- void II2CGpioInit(void)
- #if 0
- gpio_init_type gpio_init_struct;
- /* enable gpioc periph clock */
- crm_periph_clock_enable(CRM_GPIOC_PERIPH_CLOCK, TRUE);
- gpio_default_para_init(&gpio_init_struct);
- /* gpio output config */
- gpio_bits_write(GPIOC, IO_SCL_PIN | IO_SDA_PIN, TRUE);
- gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_MODERATE;
- gpio_init_struct.gpio_out_type = GPIO_OUTPUT_OPEN_DRAIN;
- gpio_init_struct.gpio_mode = GPIO_MODE_OUTPUT;
- gpio_init_struct.gpio_pins = IO_SCL_PIN | IO_SDA_PIN;
- gpio_init_struct.gpio_pull = GPIO_PULL_UP;
- gpio_init(GPIOC, &gpio_init_struct);
- #else
- hi2cx.i2cx = I2Cx_PORT;
- /* i2c config */
- i2c_config(&hi2cx);
- #endif
- void IIC_Start(void) {
- OLED_SCL_SET();
- OLED_SDA_SET();
- OLED_SDA_CLR();
- OLED_SCL_CLR();
- void IIC_Stop(void) {
- OLED_SCL_SET();
- OLED_SDA_CLR();
- OLED_SDA_SET();
- void IIC_Wait_Ack(void) {
- OLED_SCL_SET();
- OLED_SCL_CLR();
- void Write_IIC_Byte(uint8_t IIC_Byte) {
- i2c_status_type i2c_status;
- #if 0
- uint8_t i;
- uint8_t m,da;
- da=IIC_Byte;
- OLED_SCL_CLR();
- for(i=0;i<8;i++) {
- m=da;
- m=m&0x80;
- if(m==0x80) {
- OLED_SDA_SET();
- } else {
- OLED_SDA_CLR();
- da=da<<1;
- OLED_SCL_SET();
- OLED_SCL_CLR();
- #else
- uint8_t buff[2] = {0};
- buff[0] = IIC_Byte;
- i2c_status = i2c_master_transmit(&hi2cx, I2Cx_ADDRESS, buff, 1, 1000);
- if(i2c_status != I2C_OK)
- printf("erro send %d",i2c_status);
- #endif
- void Write_IIC_Command(uint8_t IIC_Command) {
- #if 0
- IIC_Start();
- Write_IIC_Byte(IIC_SLAVE_ADDR); //Slave address,SA0=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x00); //write command
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Command);
- IIC_Wait_Ack();
- IIC_Stop();
- #else
- buff[0] = 0x00;
- buff[1] = IIC_Command;
- i2c_status = i2c_master_transmit(&hi2cx, I2Cx_ADDRESS, buff, 2, 1000);
- #endif
- void Write_IIC_Data(uint8_t IIC_Data) {
- #if 0
- IIC_Start();
- Write_IIC_Byte(IIC_SLAVE_ADDR); //D/C#=0; R/W#=0
- IIC_Wait_Ack();
- Write_IIC_Byte(0x40); //write data
- IIC_Wait_Ack();
- Write_IIC_Byte(IIC_Data);
- IIC_Wait_Ack();
- IIC_Stop();
- #else
- buff[0] = 0x40;
- buff[1] = IIC_Data;
- #endif
- void GUI_DrawPoint(uint8_t x,uint8_t y,uint8_t color) {
- OLED_Set_Pixel(x,y,color);
- OLED_Display();
- void GUI_Fill(uint8_t sx,uint8_t sy,uint8_t ex,uint8_t ey,uint8_t color) {
- uint8_t i,j;
- uint8_t width=ex-sx+1; //得到填充的宽度
- uint8_t height=ey-sy+1; //高度
- for(i=0;i<height;i++) {
- for(j=0;j<width;j++) {
- OLED_Set_Pixel(sx+j, sy+i,color);
- OLED_Display();
- void GUI_DrawLine(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2,uint8_t color) {
- uint16_t t;
- int xerr=0,yerr=0,delta_x,delta_y,distance;
- int incx,incy,uRow,uCol;
- delta_x=x2-x1; //计算坐标增量
- delta_y=y2-y1;
- uRow=x1;
- uCol=y1;
- if(delta_x>0) {
- incx=1; //设置单步方向
- } else if(delta_x==0) {
- incx=0;//垂直线
- }else {
- incx=-1;
- delta_x=-delta_x;
- if(delta_y>0) {
- incy=1;
- } else if(delta_y==0) {
- incy=0;//水平线
- } else{
- incy=-1;delta_y=-delta_y;
- if (delta_x>delta_y) {
- distance=delta_x; //选取基本增量坐标轴
- } else {
- distance=delta_y;
- //画线输出
- for(t=0;t<=distance+1;t++ ) {
- OLED_Set_Pixel(uRow,uCol,color);
- xerr+=delta_x ;
- yerr+=delta_y ;
- if(xerr>distance) {
- xerr-=distance;
- uRow+=incx;
- if(yerr>distance) {
- yerr-=distance;
- uCol+=incy;
- OLED_Display();
- void GUI_DrawRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2,uint8_t color) {
- GUI_DrawLine(x1,y1,x2,y1,color);
- GUI_DrawLine(x1,y1,x1,y2,color);
- GUI_DrawLine(x1,y2,x2,y2,color);
- GUI_DrawLine(x2,y1,x2,y2,color);
- void GUI_FillRectangle(uint8_t x1, uint8_t y1, uint8_t x2, uint8_t y2,uint8_t color) {
- GUI_Fill(x1,y1,x2,y2,color);
- void GUI_ShowChar(uint8_t x,uint8_t y,uint8_t chr,uint8_t Char_Size,uint8_t mode) {
- unsigned char c=0,i=0,tmp,j=0;
- c=chr-' ';//得到偏移后的值
- if(x>WIDTH-1){x=0;y=y+2;}
- if(Char_Size ==16) {
- for(i=0;i<16;i++) {
- if(mode) {
- tmp = F8X16[c*16+i];
- } else {
- tmp = ~(F8X16[c*16+i]);
- for(j=0;j<8;j++) {
- if(tmp&(0x80>>j)) {
- OLED_Set_Pixel(x+j, y+i,1);
- } else {
- OLED_Set_Pixel(x+j, y+i,0);
- } else if(Char_Size==8) {
- if(mode) {
- tmp = F6x8[c][i];
- } else {
- tmp = ~(F6x8[c][i]);
- } else {
- } else {
- return;
- void GUI_ShowString(uint8_t x,uint8_t y,uint8_t *chr,uint8_t Char_Size,uint8_t mode) {
- unsigned char j=0,csize;
- if(Char_Size == 16) {
- csize = Char_Size/2;
- } else if(Char_Size == 8) {
- csize = Char_Size/2+2;
- } else {
- return;
- while (chr[j]!='\0') {
- GUI_ShowChar(x,y,chr[j],Char_Size,mode);
- x+=csize;
- if(x>120) {
- x=0;
- y+=Char_Size;
- j++;
- OLED_Display();
- static uint32_t mypow(uint8_t m,uint8_t n) {
- uint32_t result=1;
- while(n--)result*=m;
- return result;
- void GUI_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t Size,uint8_t mode) {
- uint8_t t,temp;
- uint8_t enshow=0,csize;
- if(Size == 16) {
- csize = Size/2;
- } else if(Size == 8) {
- csize = Size/2+2;
- } else {
- return;
- for(t=0;t<len;t++) {
- temp=(num/mypow(10,len-t-1))%10;
- if(enshow==0&&t<(len-1)) {
- if(temp==0) {
- GUI_ShowChar(x+csize*t,y,' ',Size,mode);
- continue;
- } else {
- enshow=1;
- GUI_ShowChar(x+csize*t,y,temp+'0',Size,mode);
- OLED_Display();
- void OLED_ShowFNum(u8 x,u8 y,float Fnum,u8 size1,u8 mode)
- unsigned int i,flen;
- unsigned char Data[sizeof(Fnum)]; //数据位数由sizeof(Fnum) 来判断,灵活创建数组大小
- sprintf((char *)Data,"%.3f",Fnum); //保留小数点后3位小数,打印到Data数组中
- flen = sizeof(Data)+1; //判断浮点数长度,方便后期打印输出
- for(i=0;i<flen;i++){ //根据转后字符长度打印输出
- x+=8; //每个字符占8位,向后占位
- GUI_ShowChar(x,y,Data[i],size1,mode); //调用oled字符显示函数,在OLED屏上逐个显示
- void GUI_ShowCHinese(uint8_t x,uint8_t y,uint8_t hsize,uint8_t *str,uint8_t mode) {
- while(*str!='\0') {
- if(hsize == 16) {
- GUI_ShowFont16(x,y,str,mode);
- } else if(hsize == 24) {
- //GUI_ShowFont24(x,y,str,mode);
- } else if(hsize == 32) {
- //GUI_ShowFont32(x,y,str,mode);
- } else if(hsize == 12) {
- GUI_ShowFont12(x,y,str,mode);
- } else {
- return;
- if (hsize==12) {
- x+=16;
- } else {
- x+=hsize;
- if(x>WIDTH-hsize) {
- x=0;
- y+=hsize;
- str+=2;
- OLED_Display();
- void GUI_DrawBMP(uint8_t x,uint8_t y,uint8_t width, uint8_t height, uint8_t BMP[], uint8_t mode) {
- uint8_t i,j,k;
- uint8_t tmp;
- for(j=0;j<(width+7)/8;j++) {
- if(mode) {
- tmp = BMP[i*((width+7)/8)+j];
- } else {
- tmp = ~BMP[i*((width+7)/8)+j];
- for(k=0;k<8;k++) {
- if(tmp&(0x80>>k)) {
- OLED_Set_Pixel(x+j*8+k, y+i,1);
- } else {
- OLED_Set_Pixel(x+j*8+k, y+i,0);
- OLED_Display();
- #ifndef __OLED_H
- #define __OLED_H
- #define PAGE_SIZE 8
- #define XLevelL 0x00
- #define XLevelH 0x10
- #define YLevel 0xB0
- #define Brightness 0xFF
- #define WIDTH 128
- #define HEIGHT 64
- #define OLED_CMD 0 //写命令
- #define OLED_DATA 1 //写数据
- #define IIC_SLAVE_ADDR 0x78
- //IIC操作函数
- void II2CGpioInit(void);
- void IIC_Start(void);
- void IIC_Stop(void);
- void IIC_Wait_Ack(void);
- void Write_IIC_Byte(uint8_t IIC_Byte);
- void Write_IIC_Command(uint8_t IIC_Command);
- void Write_IIC_Data(uint8_t IIC_Data);
- //OLED控制函数
- void OLED_WR_Byte(unsigned char dat,unsigned char cmd);
- void OLED_Display_On(void);
- void OLED_Display_Off(void);
- void OLED_Set_Pos(unsigned char x, unsigned char y);
- void OLED_Init(void);
- void OLED_Set_Pixel(unsigned char x, unsigned char y,unsigned char color);
- void OLED_Display(void);
- void OLED_DisplayBMP(unsigned char *datoid);
- void OLED_Clear(void);
- //void OLED_Clear(unsigned char dat);
- //GUI画图函数
- void GUI_DrawPoint(unsigned char x, unsigned char y, unsigned char color);
- void GUI_Fill(unsigned char sx,unsigned char sy,unsigned char ex,unsigned char ey,unsigned char color);
- void GUI_DrawLine(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2,unsigned char color);
- void GUI_DrawRectangle(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2,unsigned char color);
- void GUI_FillRectangle(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2,unsigned char color);
- void GUI_DrawCircle(unsigned char xc, unsigned char yc, unsigned char color, unsigned char r);
- void GUI_FillCircle(unsigned char xc, unsigned char yc, unsigned char color, unsigned char r);
- void GUI_DrawTriangel(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char x2,unsigned char y2,unsigned char color);
- void GUI_FillTriangel(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char x2,unsigned char y2,unsigned char color);
- void GUI_ShowChar(unsigned char x,unsigned char y,unsigned char chr,unsigned char Char_Size,unsigned char mode);
- void GUI_ShowNum(uint8_t x,uint8_t y,uint32_t num,uint8_t len,uint8_t Size,uint8_t mode);
- void OLED_ShowFNum(u8 x,u8 y,float Fnum,u8 size1,u8 mode);
- void GUI_ShowString(unsigned char x,unsigned char y,unsigned char *chr,unsigned char Char_Size,unsigned char mode);
- void GUI_ShowFont16(unsigned char x,unsigned char y,unsigned char *s,unsigned char mode);
- void GUI_ShowFont24(unsigned char x,unsigned char y,unsigned char *s,unsigned char mode);
- void GUI_ShowFont32(unsigned char x,unsigned char y,unsigned char *s,unsigned char mode);
- void GUI_ShowCHinese(unsigned char x,unsigned char y,unsigned char hsize,unsigned char *str,unsigned char mode);
- void GUI_DrawBMP(unsigned char x,unsigned char y,unsigned char width, unsigned char height, unsigned char BMP[], unsigned char mode);
- #endif
- #include "at32f423_clock.h"
- #include "ds18b20.h"
- #include "oled.h"
- #include "bmp.h"
- int main(void)
- uint8_t i, DS18B20ID[8];
- char str[50];
- __IO char ch,count=0;
- float temperature;
- system_clock_config();
- at32_board_init();
- uart_print_init(115200);
- OLED_Init();
- OLED_Clear();
- while (DS18B20_Init())
- printf("DS18B20 Init Error\r\n");
- delay_ms(1000);
- DS18B20_ReadId(DS18B20ID);
- printf("DS18B20的序列号是: 0x");
- for ( i = 0; i < 8; i ++ )
- printf ( "%.2X", DS18B20ID[i]);
- printf("\n");
- sprintf(str,"DS18B20的序列号是:0x%02X%02X%02X%02X%02X%02X%02X%02X",DS18B20ID[0],DS18B20ID[1],DS18B20ID[2],DS18B20ID[3],DS18B20ID[4],DS18B20ID[5],DS18B20ID[6],DS18B20ID[7]);
- OLED_Clear();
- GUI_ShowCHinese(26,10,16,(unsigned char *)"欢迎使用",0);
- GUI_ShowCHinese(10,28,16,(unsigned char *)"雅特力开发板",0);
- GUI_ShowString(10,46,(uint8_t *)"AT32F423VCT7",16,0);
- delay_ms(1800);
- while(1)
- temperature=DS18B20_GetTemp_MatchRom(DS18B20ID);
- /* 打印通过 DS18B20 序列号获取的温度值 */
- printf("获取该序列号器件的温度:%.1f\n",temperature);
- sprintf(str,"当前温度值为:%0.3f℃",temperature);
- OLED_Clear();
- GUI_ShowCHinese(10,10,16,(unsigned char *)"当前室内温度",0);
- GUI_ShowString(106,10,(uint8_t *)":",16,0);
- OLED_ShowFNum(32,28,temperature,16,0);
- GUI_ShowCHinese(80,28,16,(unsigned char *)"℃",0);
- GUI_ShowString(48,46,(uint8_t *)"2023-12-03",16,0);
- delay_ms(800);
- OLED_Clear();
- GUI_DrawBMP(0,0,128,64,BMP2,0);
- delay_ms(800);
制作的单色位图如下:
使用“PCtoLCD2002”的参数设置如下:
工程编译完成后,下载到开发板,OLED屏显示想关字符与图片,在此期间,将手指握住DS18B20模块,则采集的温度数值会迅速上升;然后将手指挪开,则采集的温度数值会缓慢回降。
https://v.youku.com/v_show/id_XNjIwOTE5Nzk2OA==.html
