- #include <stddef.h>
- #include "gatt.h"
- #include "ble_util/byte_stream.h"
- #include "ble_cms/ble_my_lbs_svc.h"
- // Section: Macros
- /* Little Endian. */
- #define UUID_MY_LBS_PRIMARY_SVC_LE 0xea, 0xce, 0xf4, 0xac, 0x3f, 0x37, 0x11, 0xee, 0xbe, 0x56, 0x02, 0x42, 0xac, 0x08, 0x23, 0x20
- #define UUID_MY_LBS_CHARACTERISTIC_0_LE 0xea, 0xce, 0xf4, 0xbc, 0x3f, 0x37, 0x11, 0xee, 0xbe, 0x56, 0x02, 0x42, 0xac, 0x08, 0x23, 0x20
- #define UUID_MY_LBS_CHARACTERISTIC_1_LE 0xea, 0xce, 0xf4, 0xcc, 0x3f, 0x37, 0x11, 0xee, 0xbe, 0x56, 0x02, 0x42, 0xac, 0x08, 0x23, 0x20
- // Section: Local Variables
- /* Primary Service Declaration */
- static const uint8_t s_my_lbsSvcUuid[] = {UUID_MY_LBS_PRIMARY_SVC_LE};
- static const uint16_t s_my_lbsSvcUuidLen = sizeof(s_my_lbsSvcUuid);
- /* My_lbs Characteristic 0 Characteristic */
- static const uint8_t s_my_lbsChar0[] = {ATT_PROP_READ|ATT_PROP_NOTIFY, UINT16_TO_BYTES(MY_LBS_HDL_CHARVAL_0), UUID_MY_LBS_CHARACTERISTIC_0_LE};
- static const uint16_t s_my_lbsChar0Len = sizeof(s_my_lbsChar0);
- /* My_lbs Characteristic 0 Characteristic Value */
- static const uint8_t s_my_lbsUuidChar0[] = {UUID_MY_LBS_CHARACTERISTIC_0_LE};
- static uint8_t s_my_lbsChar0Val[] = {};
- static uint16_t s_my_lbsChar0ValLen = sizeof(s_my_lbsChar0Val);
- /* My_lbs Characteristic 0 Client Characteristic Configuration Descriptor */
- static uint8_t s_my_lbsCccChar0[] = {UINT16_TO_BYTES(0x0000)};
- static const uint16_t s_my_lbsCccChar0Len = sizeof(s_my_lbsCccChar0);
- /* My_lbs Characteristic 1 Characteristic */
- static const uint8_t s_my_lbsChar1[] = {ATT_PROP_READ|ATT_PROP_WRITE_REQ, UINT16_TO_BYTES(MY_LBS_HDL_CHARVAL_1), UUID_MY_LBS_CHARACTERISTIC_1_LE};
- static const uint16_t s_my_lbsChar1Len = sizeof(s_my_lbsChar1);
- /* My_lbs Characteristic 1 Characteristic Value */
- static const uint8_t s_my_lbsUuidChar1[] = {UUID_MY_LBS_CHARACTERISTIC_1_LE};
- static uint8_t s_my_lbsChar1Val[3] = {0x00, 0xFF, 0x00};
- static uint16_t s_my_lbsChar1ValLen = sizeof(s_my_lbsChar1Val);
- /* Attribute list for My_lbs service */
- static GATTS_Attribute_T s_my_lbsList[] = {
- /* Service Declaration */
- (uint8_t *) g_gattUuidPrimSvc,
- (uint8_t *) s_my_lbsSvcUuid,
- (uint16_t *) & s_my_lbsSvcUuidLen,
- sizeof (s_my_lbsSvcUuid),
- 0,
- PERMISSION_READ
- /* Characteristic 0 Declaration */
- (uint8_t *) g_gattUuidChar,
- (uint8_t *) s_my_lbsChar0,
- (uint16_t *) & s_my_lbsChar0Len,
- sizeof (s_my_lbsChar0),
- 0,
- PERMISSION_READ
- /* Characteristic 0 Value */
- (uint8_t *) s_my_lbsUuidChar0,
- (uint8_t *) s_my_lbsChar0Val,
- (uint16_t *) & s_my_lbsChar0ValLen,
- sizeof(s_my_lbsChar0Val),
- SETTING_MANUAL_READ_RSP|SETTING_UUID_16,
- PERMISSION_READ
- /* Client Characteristic Configuration Descriptor */
- (uint8_t *) g_descUuidCcc,
- (uint8_t *) s_my_lbsCccChar0,
- (uint16_t *) & s_my_lbsCccChar0Len,
- sizeof (s_my_lbsCccChar0),
- SETTING_CCCD,
- PERMISSION_READ|PERMISSION_WRITE
- /* Characteristic 1 Declaration */
- (uint8_t *) s_my_lbsChar1,
- (uint16_t *) & s_my_lbsChar1Len,
- sizeof (s_my_lbsChar1),
- 0,
- PERMISSION_READ
- /* Characteristic 1 Value */
- (uint8_t *) s_my_lbsUuidChar1,
- (uint8_t *) s_my_lbsChar1Val,
- (uint16_t *) & s_my_lbsChar1ValLen,
- sizeof(s_my_lbsChar1Val),
- SETTING_UUID_16,
- static const GATTS_CccdSetting_T s_my_lbsCccdSetting[] =
- {MY_LBS_HDL_CCCD_0, NOTIFICATION},
- /* My_lbs Service structure */
- static GATTS_Service_T s_my_lbsSvc =
- NULL,
- (GATTS_Attribute_T *) s_my_lbsList,
- (GATTS_CccdSetting_T const *)s_my_lbsCccdSetting,
- MY_LBS_START_HDL,
- MY_LBS_END_HDL,
- 1
- // Section: Functions
- uint16_t BLE_MY_LBS_Add()
- return GATTS_AddService(&s_my_lbsSvc, (MY_LBS_END_HDL - MY_LBS_START_HDL + 1));
主函数依旧非常精简:
- int main ( void )
- /* Initialize all modules */
- SYS_Initialize ( NULL );
- //SERCOM0_USART_Write((uint8_t *)"Hello Welcome to WBZ451 World\r\n",strlen("Hello Welcome to WBZ451 World\r\n"));
- uart_**();
- while ( true )
- /* Maintain state machines of all polled MPLAB Harmony modules. */
- SYS_Tasks ( );
- /* Execution should not come here during normal operation */
- return ( EXIT_FAILURE );
特征值写服务:
特征值读服务:
订阅服务测试:
连接断开后重连功能:
- void APP_BleGapEvtHandler(BLE_GAP_Event_T *p_event)
- switch(p_event->eventId)
- case BLE_GAP_EVT_CONNECTED:
- /* TODO: implement your application code.*/
- SERCOM0_USART_Write((uint8_t *)"Great! ^-^ Connect to GAP Center Device\r\n",strlen("Great! ^-^ Connect to GAP Center Device\r\n"));
- ble_gap_connect_state = 1;
- G_ConnHandle = p_event->eventField.evtConnect.connHandle;
- break;
- case BLE_GAP_EVT_DISCONNECTED:
- SERCOM0_USART_Write((uint8_t *)"Ah oh... :( Disconnect to GAP Center Device\r\n",strlen("Ah oh... :( Disconnect to GAP Center Device\r\n"));
- ble_gap_connect_state = 0;
- G_ConnHandle = 0;
- BLE_GAP_SetAdvEnable(0x01, 0x00);
- SERCOM0_USART_Write((uint8_t *)"Let me try to GAP Center Device\r\n",strlen("Let me try to GAP Center Device\r\n"));
加入上期测试的OLED,可以显示BLE的连接状态:
BLE未连接的时候:
BLE连接成功的时候:
连接过程演示:
