[牛人杂谈] CRC-CCITT模式下计算CRC校验值
 楼主| huangcunxiake 发表于 2024-1-21 21:18 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 2 $
  5. * $Date: 20/05/28 4:40p $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Implement CRC in CRC-CCITT mode and get the CRC checksum result.
  7. *
  8. * SPDX-License-Identifier: Apache-2.0
  9. * Copyright (C) 2020 Nuvoton Technology Corp. All rights reserved.
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "NuMicro.h"
  13. void SYS_Init(void)
  14. {
  15.     /* Unlock protected registers */
  16.     SYS_UnlockReg();
  17.     /* Enable HIRC clock */
  18.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  19.     /* Waiting for HIRC clock ready */
  20.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  21.     /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
  22.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  23.     /* Enable UART0 clock */
  24.     CLK_EnableModuleClock(UART0_MODULE);
  25.     /* Switch UART0 clock source to HIRC */
  26.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HIRC, CLK_CLKDIV0_UART0(1));
  27.     /* Enable CRC clock */
  28.     CLK_EnableModuleClock(CRC_MODULE);
  29.     /* Update System Core Clock */
  30.     SystemCoreClockUpdate();
  31.     /* Set PB multi-function pins for UART0 RXD=PB.12 and TXD=PB.13 */
  32.     SYS->GPB_MFPH = (SYS->GPB_MFPH & ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk))
  33.                     |(SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
  34.     /* Lock protected registers */
  35.     SYS_LockReg();
  36. }
  37. void UART0_Init(void)
  38. {
  39.     /*---------------------------------------------------------------------------------------------------------*/
  40.     /* Init UART        */
  41.     /*---------------------------------------------------------------------------------------------------------*/
  42.     /* Reset UART module */
  43.     SYS_ResetModule(UART0_RST);
  44.     /* Configure UART0 and set UART0 Baudrate */
  45.     UART_Open(UART0, 115200);
  46. }
  47. /*---------------------------------------------------------------------------------------------------------*/
  48. /*  MAIN function        */
  49. /*---------------------------------------------------------------------------------------------------------*/
  50. int main(void)
  51. {
  52.     const uint16_t u16CRCSrcPattern[] = {0x3231, 0x3433, 0x3635, 0x3837};
  53.     uint32_t i, u32TargetChecksum = 0xA12B, u32CalChecksum = 0;
  54.     /* Unlock protected registers */
  55.     SYS_UnlockReg();
  56.     /* Init System, peripheral clock and multi-function I/O */
  57.     SYS_Init();
  58.     /* Lock protected registers */
  59.     SYS_LockReg();
  60.     /* Init UART0 for printf */
  61.     UART0_Init();
  62.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
  63.     printf("+---------------------------------------------+\n");
  64.     printf("|    CRC-CCITT Polynomial Mode Sample Code    |\n");
  65.     printf("+---------------------------------------------+\n\n");
  66.     printf("# Calculate [0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38] CRC-CCITT checksum value.\n");
  67.     printf("    - Seed value is 0xFFFF             \n");
  68.     printf("    - CPU write data length is 16-bit \n");
  69.     printf("    - Checksum complement disable    \n");
  70.     printf("    - Checksum reverse disable       \n");
  71.     printf("    - Write data complement disable  \n");
  72.     printf("    - Write data reverse disable     \n");
  73.     printf("    - Checksum should be 0x%X        \n\n", u32TargetChecksum);
  74.     /* Configure CRC controller for CRC-CCITT CPU mode */
  75.     CRC_Open(CRC_CCITT, 0, 0xFFFF, CRC_WDATA_16);
  76.     /* Start to execute CRC-CCITT operation */
  77.     for(i = 0; i < sizeof(u16CRCSrcPattern) / sizeof(u16CRCSrcPattern[0]); i++)
  78.     {
  79.         CRC_WRITE_DATA((u16CRCSrcPattern[i]));
  80.     }
  81.     /* Get CRC-CCITT checksum value */
  82.     u32CalChecksum = CRC_GetChecksum();
  83.     printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
  84.     /* Disable CRC function */
  85.     CLK_DisableModuleClock(CRC_MODULE);
  86.     while(1);
  87. }
  88. /*** (C) COPYRIGHT 2020 Nuvoton Technology Corp. ***/
这段代码是一个用于在CRC-CCITT模式下计算CRC校验值的示例程序。以下是对程序的主要部分的解释:
初始化函数 SYS_Init 和 UART0_Init:
SYS_Init: 用于初始化系统、外设时钟和多功能IO。
UART0_Init: 用于初始化UART0模块,设置波特率为115200。
主函数 main:
系统初始化:
解锁保护寄存器,以允许对一些关键寄存器的写操作。
启用高频内部振荡器(HIRC)作为系统时钟源。
配置时钟源,将HCLK时钟源切换到HIRC,并设置HCLK分频系数为1。
启用UART0模块和CRC模块的时钟。
设置PB12和PB13引脚为UART0的RXD和TXD。
锁定保护寄存器,以防止对关键寄存器的未经授权的写入。
UART0初始化:
复位UART0模块。
打开UART0,设置波特率为115200。
CRC校验操作:
定义一个16位的CRC源模式数组 u16CRCSrcPattern。
定义目标CRC校验值 u32TargetChecksum 和计算得到的CRC校验值 u32CalChecksum。
输出系统时钟频率和CRC-CCITT示例信息。
配置CRC控制器:
使用 CRC_Open 函数配置CRC模块,选择CRC-CCITT模式,初始值为0xFFFF,数据长度为16位。
执行CRC操作:
使用 CRC_WRITE_DATA 将数组中的每个16位数据写入CRC模块。
使用 CRC_GetChecksum 获取计算得到的CRC校验值。
输出结果:
输出计算得到的CRC校验值。
比较计算得到的CRC校验值和目标CRC校验值,输出校验结果。
关闭CRC模块时钟:
使用 CLK_DisableModuleClock 关闭CRC模块时钟。
死循环:
在程序末尾使用 while(1) 进入死循环,保持程序持续运行。
这个程序的主要目的是演示如何使用Nuvoton的MCU平台计算CRC-CCITT校验和。通过修改源模式数组和目标CRC校验值,你可以测试不同的输入数据和期望的校验结果。
OliviaSH 发表于 2024-1-23 16:48 | 显示全部楼层
CRC校验在什么地方用的多啊
埃娃 发表于 2024-1-29 10:41 来自手机 | 显示全部楼层
CRC校验在什么地方用的多啊
验证传输数据是否出错的时候
