单击、双击、长按功能实现驱动代码
KEY.C
#include "key.h"
//代码来源网络 侵权联系删除
| short click |
| ______ ________ |
| | \_______________/ | |
| |shake| < long |shake| |
| double click |
| ______ _____________ ____ |
| | \_______________/ | | \_______________/ | |
| | | | | < max | | | | |
| |shake| < long |shake|dclick |shake| any time |shake| |
| long click |
| ______ ________ |
| | \_______________________________________/ | |
| |shake| > long click |shake| |
#define KEY_STATUS_DOWN_CHECK 0x00
#define KEY_STATUS_DOWN_SHAKE 0x01
#define KEY_STATUS_DOWN_HANDLE 0x02
#define KEY_STATUS_LONG_CHECK 0x03
#define KEY_STATUS_SHORT_UP_SHAKE 0x04
#define KEY_STATUS_DOUBLE_CHECK 0x05
#define KEY_STATUS_SHORT_UP_HANDLE 0x06
#define KEY_STATUS_DOUBLE_DOWN_SHAKE 0x07
#define KEY_STATUS_DOUBLE_UP_CHECK 0x08
#define KEY_STATUS_DOUBLE_UP_SHAKE 0x09
#define KEY_STATUS_DOUBLE_UP_HANDLE 0x0a
#define KEY_STATUS_LONG_HANDLE 0x0b
#define KEY_STATUS_CONTINUE_CHECK 0x0c
#define KEY_STATUS_LONG_UP_SHAKE 0x0d
#define KEY_STATUS_LONG_UP_HANDLE 0x0e
#define KEY_READ_DOWN 0x00 /* key is pressed */
#define KEY_READ_UP 0x01 /* Key isn't pressed */
#define KEY_BUF_SIZE 0x10 /* key value buffer size */
struct
unsigned short value[KEY_BUF_SIZE];
unsigned char rd;
unsigned char wr;
}key_buf;
struct key_dev
unsigned char status; /* state machine status */
unsigned char num; /* number */
unsigned short count_ms; /* ms counter */
unsigned short long_click_ms; /* long click check min time */
unsigned short shake_filter_ms; /* shake filter time */
unsigned short max_dclick_ms; /* double click max interval time */
unsigned short continue_send_ms; /* after long, continue send interval */
unsigned char (*read_key)(void); /* key read pin status function pointer*/
User Interface [START]
unsigned char key0_read(void)
if (HAL_GPIO_ReadPin(KEY_GPIO_Port, KEY_Pin) == GPIO_PIN_RESET)
return KEY_READ_DOWN;
else
return KEY_READ_UP;
struct key_dev key_dev[] = {
KEY_STATUS_DOWN_CHECK,
KEY0_NUM,
0,
1500,
20,
300,
1000,
(unsigned char (*)(void))key0_read,
user add other key
User Interface [END]
static void key_write_value(unsigned short key_val);
static void key_status_down_check(struct key_dev *key_dev);
static void key_status_down_shake(struct key_dev *key_dev);
static void key_status_down_handle(struct key_dev *key_dev);
static void key_status_long_check(struct key_dev *key_dev);
static void key_status_short_up_shake(struct key_dev *key_dev);
static void key_status_double_check(struct key_dev *key_dev);
static void key_status_short_up_handle(struct key_dev *key_dev);
static void key_status_double_down_shake(struct key_dev *key_dev);
static void key_status_double_up_check(struct key_dev *key_dev);
static void key_status_double_up_shake(struct key_dev *key_dev);
static void key_status_double_up_handle(struct key_dev *key_dev);
static void key_status_long_hanle(struct key_dev *key_dev);
static void key_status_continue_check(struct key_dev *key_dev);
static void key_status_long_up_shake(struct key_dev *key_dev);
static void key_status_long_up_handle(struct key_dev *key_dev);
description : write key vaule to buffer
param : key_val - key value , (KEY_EVENT | KEY_NUMBER<<8)
retval : None
author : huohongpeng
data : 2017-03-02
key_buf.value[key_buf.wr++] = key_val;
key_buf.wr %= KEY_BUF_SIZE;
overflow handle
if(key_buf.wr == key_buf.rd)
key_buf.rd++;
key_buf.rd %= KEY_BUF_SIZE;
description : read key vaule from buffer
param : None
retval : key_val - key value , (KEY_EVENT | KEY_NUMBER<<8)
data : 2017-03-02
unsigned short key_read_value(void)
unsigned short key_val;
key_val = KEY_EVENT_NULL;
else
key_val = key_buf.value[key_buf.rd++];
return key_val;
description : check key whether press down
param : key_dev - key device pointer
retval : None
data : 2017-03-02
unsigned char key_read;
key_read = key_dev->read_key();
if(key_read == KEY_READ_DOWN)
key_dev->status = KEY_STATUS_DOWN_SHAKE;
key_dev->count_ms = 0;
description : filter shake after key pressed down
retval : None
data : 2017-03-02
key_dev->count_ms++;
if(key_dev->count_ms < key_dev->shake_filter_ms)
return;
key_dev->status = KEY_STATUS_DOWN_HANDLE;
else
key_dev->status = KEY_STATUS_DOWN_CHECK;
description : key press down handle after pressed down filter shake
retval : None
data : 2017-03-02
unsigned short key_val = key_dev->num<<8 | KEY_EVENT_DOWN;
key_write_value(key_val);
key_dev->status = KEY_STATUS_LONG_CHECK;
description : check key whether long click
retval : None
data : 2017-03-02
if(key_dev->count_ms < key_dev->long_click_ms)
if(key_read == KEY_READ_UP)
key_dev->status = KEY_STATUS_SHORT_UP_SHAKE;
return;
key_dev->status = KEY_STATUS_LONG_HANDLE;
description : short cilck key up filter shake
retval : None
data : 2017-03-02
static unsigned short old = 0xffff;
if(old == 0xffff)
old = key_dev->count_ms;
return;
key_dev->status = KEY_STATUS_DOUBLE_CHECK;
else
key_dev->count_ms += old;
old = 0xffff;
description : double cilck check. we consider double click event if key pressed
down when after short click up and within max double click interval
retval : None
data : 2017-03-02
if(key_dev->count_ms < key_dev->max_dclick_ms)
key_dev->status = KEY_STATUS_DOUBLE_DOWN_SHAKE;
else
key_dev->status = KEY_STATUS_SHORT_UP_HANDLE;
description : short click key up handle
retval : None
data : 2017-03-02
key_val= key_dev->num<<8 | KEY_EVENT_SHORT;
key_val= key_dev->num<<8 | KEY_EVENT_UP_SHORT;
description : double click key down filter shake
retval : None
data : 2017-03-02
if(old == 0xffff)
return;
key_val= key_dev->num<<8 | KEY_EVENT_DOUBLE;
key_dev->status = KEY_STATUS_DOUBLE_UP_CHECK;
else
old = 0xffff;
description : double click key up check
retval : None
data : 2017-03-02
key_dev->status = KEY_STATUS_DOUBLE_UP_SHAKE;
description : double click key up filter shake
retval : None
data : 2017-03-02
return;
key_dev->status = KEY_STATUS_DOUBLE_UP_HANDLE;
else
description : double click key up handle
retval : None
data : 2017-03-02
key_val= key_dev->num<<8 | KEY_EVENT_UP_DOUBLE;
description : long click handle after long click check
retval : None
data : 2017-03-02
key_val= key_dev->num<<8 | KEY_EVENT_LONG;
key_dev->status = KEY_STATUS_CONTINUE_CHECK;
description : continue send short click if long click time overflow
retval : None
data : 2017-03-02
key_dev->status = KEY_STATUS_LONG_UP_SHAKE;
if(key_dev->count_ms < key_dev->continue_send_ms)
return;
if(key_dev->continue_send_ms == 0)
return;
description : long click key up filter shake
retval : None
data : 2017-03-02
if(old == 0xffff)
return;
key_dev->status = KEY_STATUS_LONG_UP_HANDLE;
else
old = 0xffff;
description : long click key up filter handle
retval : None
data : 2017-03-02
key_val= key_dev->num<<8 | KEY_EVENT_UP_LONG;
description : run key state machine once every 1ms
retval : None
data : 2017-03-02
static void key_check_1ms(struct key_dev *key_dev)
switch(key_dev->status)
case KEY_STATUS_DOWN_CHECK :
key_status_down_check(key_dev);
break;
case KEY_STATUS_DOWN_SHAKE :
key_status_down_shake(key_dev);
break;
case KEY_STATUS_DOWN_HANDLE :
key_status_down_handle(key_dev);
break;
case KEY_STATUS_LONG_CHECK :
key_status_long_check(key_dev);
break;
case KEY_STATUS_SHORT_UP_SHAKE :
key_status_short_up_shake(key_dev);
break;
case KEY_STATUS_DOUBLE_CHECK :
key_status_double_check(key_dev);
break;
case KEY_STATUS_SHORT_UP_HANDLE :
key_status_short_up_handle(key_dev);
break;
case KEY_STATUS_DOUBLE_DOWN_SHAKE :
key_status_double_down_shake(key_dev);
break;
case KEY_STATUS_DOUBLE_UP_CHECK :
key_status_double_up_check(key_dev);
break;
case KEY_STATUS_DOUBLE_UP_SHAKE :
key_status_double_up_shake(key_dev);
break;
case KEY_STATUS_DOUBLE_UP_HANDLE :
key_status_double_up_handle(key_dev);
break;
case KEY_STATUS_LONG_HANDLE :
key_status_long_hanle(key_dev);
break;
case KEY_STATUS_CONTINUE_CHECK :
key_status_continue_check(key_dev);
break;
case KEY_STATUS_LONG_UP_SHAKE :
key_status_long_up_shake(key_dev);
break;
case KEY_STATUS_LONG_UP_HANDLE :
key_status_long_up_handle(key_dev);
break;
default:
key_dev->status = key_dev->status;
description : run all key state machine once every 1ms
retval : None
data : 2017-03-02
call :
timer(1ms) interrupt handle
void key_check_all_loop_1ms(void)
unsigned char key_num, i;
key_num = sizeof(key_dev)/sizeof(struct key_dev);
for(i = 0; i < key_num; i++)
key_check_1ms(&key_dev[i]);
