[研电赛技术支持] GD32F350串口0 UART0
 楼主| tpgf 发表于 2024-3-13 08:16 | 显示全部楼层 |阅读模式
#include "uart0.h"
    \brief      cofigure the USART0 GPIO ports
    \param[in]  none
    \param[out] none
    \retval     none
void usart0_gpio_config(void)
    /* enable COM GPIO clock */
    rcu_periph_clock_enable(RCU_GPIOA);
    /* connect port to USARTx_Tx */
    gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_9);
    /* connect port to USARTx_Rx */
    gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_10);
    /* configure USART Tx as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_9);
    /* configure USART Rx as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_10MHZ, GPIO_PIN_10);
    \param[in]  none
    \param[out] none
    \retval     none
void usart0_config(void)
    /* enable USART clock */
    rcu_periph_clock_enable(RCU_USART0);
    /* USART configure */
    usart_deinit(USART0);
    usart_baudrate_set(USART0, 460800U);
    usart_receive_config(USART0, USART_RECEIVE_ENABLE);
    usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
    usart_enable(USART0);
void usart0_int_init(void)
    /* USART interrupt configuration */
    nvic_irq_enable(USART0_IRQn, 0, 1);
    usart_interrupt_enable(USART0, USART_INT_RBNE);
void usart0_init(void)
  usart0_gpio_config();
  usart0_config();
  usart0_int_init();
void usart0_send_ch(uint8_t ch)
    usart_data_transmit(USART0, (uint8_t) ch);
    while(RESET == usart_flag_get(USART0, USART_FLAG_TBE));
void uart0_Send_Array(unsigned char send_array[],unsigned char num)
        //串口发送
        unsigned char i=0;
        for(i=0 ;i< num ; i++)
                usart0_send_ch(send_array);
/* retarget the C library printf function to the USART */
int fputc(int ch, FILE *f)
    return ch;
中断
void USART0_IRQHandler(void)
  uint16_t re = 0;
    if(RESET != usart_interrupt_flag_get(USART0, USART_INT_FLAG_RBNE)){
        /* receive data */
      re = usart_data_receive(USART0);
        if( re == 13)
          usart0_send_ch('\r');
          usart0_send_ch('\n');
        }else
           usart0_send_ch(re);
原文链接:https://blog.csdn.net/liuhfeng21/article/details/135642134
黑心单片机 发表于 2024-3-28 13:48 | 显示全部楼层
这个波特率好奇怪 啊
原来是wjc 发表于 2024-5-31 23:43 | 显示全部楼层
你需要初始化DMA来接收串口数据。
你可能需要代码修改:
在 usart0_int_init 函数中添加DMA配置。
编写DMA中断服务函数来处理接收到的数据。
原来是wjc 发表于 2024-6-1 02:59 | 显示全部楼层
/* DMA接收配置 */
void usart0_dma_config(void)
    /* enable DMA clock */
    rcu_periph_clock_enable(RCU_DMA0);
    /* initialize DMA channel 2 */
    dma_deinit(DMA0, DMA_CH2);
    dma_init_struct.direction = DMA_PERIPHERAL_TO_MEMORY;
    dma_init_struct.memory_addr = (uint32_t)receive_buffer; // 接收缓冲区地址
    dma_init_struct.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
    dma_init_struct.memory_width = DMA_MEMORY_WIDTH_8BIT;
    dma_init_struct.number = 1;
    dma_init_struct.periph_addr = (uint32_t)&USART_DATA(USART0); // USART 数据寄存器地址
    dma_init_struct.periph_width = DMA_PERIPHERAL_WIDTH_8BIT;
    dma_init_struct.priority = DMA_PRIORITY_ULTRA_HIGH;
    dma_channel_enable(DMA0, DMA_CH2);
    /* DMA中断配置 */
    dma_interrupt_enable(DMA0, DMA_CH2, DMA_INT_FTF);
    nvic_irq_enable(DMA0_Channel2_IRQn, 0, 1);
    /* 初始化DMA接收 */
    usart0_dma_config();
/* DMA接收中断服务函数 */
void DMA0_Channel2_IRQHandler(void)
    if(dma_interrupt_flag_get(DMA0, DMA_CH2, DMA_INT_FLAG_FTF)){
        /* DMA传输完成 */
        dma_interrupt_flag_clear(DMA0, DMA_CH2, DMA_INT_FLAG_FTF);
        // 在这里处理接收到的数据
        // 可以从 receive_buffer 中读取数据
假设你有一个名为 receive_buffer 的全局数组来存储接收到的数据,并且你需要在 usart0_int_init 函数中调用 usart0_dma_config 函数来初始化DMA。
FranklinUNK 发表于 2024-6-20 20:07 | 显示全部楼层
这么高的波特率
