C8051F330的PWM频率周期如何方便的调整
 楼主| G21372 发表于 2012-5-17 23:36 | 显示全部楼层 |阅读模式
现在的做法是开中断,然后每次重装 PCA0L 和 PCA0H 才能变更频率(调试我设为16位)?
如果5个固定频率输出,我在中断中还要判断是哪个事件引起的!难道不能自动重装???
 楼主| G21372 发表于 2012-5-17 23:37 | 显示全部楼层
附代码:
#include <c8051f330.h>
unsigned int CEX0_Compare_Value;       // Holds current PCA compare value
void main (void)
   PCA0MD = 0;
    // 系统时钟
    OSCICN    = 0x83;
    CLKSEL    = 0x00;
    XBR0      = 0x00;
    XBR1      = 0x01;
    P0MDIN    = 0x10;
    P0MDOUT   = 0x00;
    P0SKIP    = 0xFF;
    P1MDIN    = 0xFF;
    P1MDOUT   = 0xFF;
    P1SKIP    = 0xFE;
    P0        = 0x00;
    P1        = 0x00;
    XBR1      |= 0x40;
    // PCA0 INIT
    PCA0CN    = 0x00;
    PCA0MD    = 0x08;
    PCA0CPM0  = 0xCB;
    CEX0_Compare_Value = 65536 - (65536 * 0.5);
    PCA0L     = (CEX0_Compare_Value & 0x00FF);
    PCA0H     = (CEX0_Compare_Value & 0xFF00)>>8;
    CEX0_Compare_Value = CEX0_Compare_Value - (CEX0_Compare_Value * 0.08);
    PCA0CPL0 = (CEX0_Compare_Value & 0x00FF);
    PCA0CPH0 = (CEX0_Compare_Value & 0xFF00)>>8;
    EIE1 |= 0x10;
    CR = 1;
    EA = 1;
    while(1)
void PCA0_ISR (void) interrupt 11
    CCF0 = 0;                           // Clear module 0 interrupt flag.
    P1 ^= 0x80;
yangguangaisha 发表于 2012-5-17 23:42 | 显示全部楼层
同问啊
gexingyouxian 发表于 2012-5-17 23:50 | 显示全部楼层
以T0溢出作为PCA时基即可得到连续可变的pwm频率
acer4736 发表于 2012-5-17 23:54 | 显示全部楼层
正解!!!!!
