这是相关代码:
/* 头文件声明区 */
#include <STC89C5xRC.H>//89c52专用头文件
#include <init.h>//初始化底层驱动专用头文件
#include <key.h>//按键底层驱动专用头文件
#include <seg.h>//数码管底层驱动专用头文件
#include <led.h>//Led底层驱动专用头文件
#include <intrins.h>//包含了各种内联函数和宏,用于访问处理器特定的指令和功能的头文件
/* 变量声明区 */
unsigned char Key_Val,Key_Down,Key_Old,Key_Up;//按键专用变量
unsigned char Key_Slow_Down;//按键减速专用变量
unsigned char Seg_Buf[8] = {10,10,10,10,10,10,10,10};//数码管显示数据存放数组
unsigned char Seg_Point[8] = {0,0,0,0,0,0,0,0};//数码管小数点数据存放数组
unsigned char Seg_Pos;//数码管扫描专用变量
unsigned int Seg_Slow_Down;//数码管减速专用变量
unsigned char ucLed[8] = {0,0,0,0,0,0,0,0};//Led显示数据存放数组
unsigned char Seg_Disp_Mode=1;//数码管模式显示变量 0为学号显示 1为按键显示
unsigned char Seg_Student[16]={8,2,0,6,2,2,0,7,2,7,0,0,0,0,0,0};//学号存储数组
/*自定义延迟函数(毫秒)*/
void Delay(unsigned int xms) //@12.000MHz
unsigned char i, j;
while(xms--)
i = 2;
j = 239;
do
while (--j);
} while (--i);
/* 键盘处理函数 */
void Key_Proc()
if(Key_Slow_Down) return;
Key_Slow_Down = 1;//键盘减速程序
Key_Val = Key_Read();//实时读取键码值
Key_Down = Key_Val & (Key_Old ^ Key_Val);//捕捉按键下降沿
Key_Up = ~Key_Val & (Key_Old ^ Key_Val);//捕捉按键上降沿
Key_Old = Key_Val;//辅助扫描变量
switch(Key_Down)
case 16:
if(Seg_Disp_Mode==1)
Seg_Buf[0] =0;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示0 ");
break;
case 1:
Seg_Buf[0] =1;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示1 ");
break;
case 2:
Seg_Buf[0] =2;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示2 ");
break;
case 3:
Seg_Buf[0] =3;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示3 ");
break;
case 4:
Seg_Buf[0] =4;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示4 ");
break;
case 5:
Seg_Buf[0] =5;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示5 ");
break;
case 6:
Seg_Buf[0] =6;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示6 ");
break;
case 7:
Seg_Buf[0] =7;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示7 ");
break;
case 8:
Seg_Buf[0] =8;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示8 ");
break;
case 9:
Seg_Buf[0] =9;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示9 ");
break;
case 10:
Seg_Buf[0] =11;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示A ");
break;
case 11:
Seg_Buf[0] =12;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示b ");
break;
case 12:
Seg_Buf[0] =13;
LcdGotoXY(3,0);
break;
case 13:
Seg_Buf[0] =14;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示d ");
break;
case 14:
Seg_Buf[0] =15;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示E ");
break;
case 15:
Seg_Buf[0] =16;
LcdGotoXY(3,0);
LcdPrintStr("键盘显示F ");
break;
case 17:
Seg_Disp_Mode = 0;
LcdWriteCmd(0xff);
LcdGotoXY(3,0);
LcdPrintStr("学号流水显示");
break;
case 18:
Seg_Disp_Mode = 1;
break;
/* 信息处理函数 */
void Seg_Proc()
unsigned char i,j;//循环变量
if(Seg_Slow_Down) return;
Seg_Slow_Down = 1;//数码管减速程序
if(Seg_Disp_Mode==0)//学号显示界面
Seg_Buf[7] =0;
for(i=0,j=0;i<=5,j<=15;i++,j++)
if(i==6)
i=0;
Seg_Buf =Seg_Student[j];
Delay(500);
else
Delay(500);
if(Seg_Disp_Mode==1)//按键响应界面
Seg_Buf[1] =10;
Seg_Buf[2] =10;
Seg_Buf[3] =10;
Seg_Buf[4] =10;
Seg_Buf[5] =10;
Seg_Buf[6] =10;
Seg_Buf[7] =1;
/* 其他显示函数 */
void Led_Proc()
void Timer0Init(void) //1毫秒@12.000MHz
AUXR &= 0x7F; //定时器时钟12T模式
TMOD &= 0xF0; //设置定时器模式
TL0 = 0x18; //设置定时初始值
TH0 = 0xFC; //设置定时初始值
TF0 = 0; //清除TF0标志
TR0 = 1; //定时器0开始计时
ET0 = 1; //定时器中断0打开
EA = 1; //总中断打开
void Timer0Server() interrupt 1
if(++Key_Slow_Down == 10) Key_Slow_Down = 0;//键盘减速专用
if(++Seg_Slow_Down == 500) Seg_Slow_Down = 0;//数码管减速专用
if(++Seg_Pos == 8) Seg_Pos = 0;//数码管显示专用
Seg_Disp(Seg_Pos,Seg_Buf[Seg_Pos],Seg_Point[Seg_Pos]);
Led_Disp(Seg_Pos,ucLed[Seg_Pos]);
/* Main函数 */
void main()
Timer0Init();
LcdInit(); // LCD12864液晶功能初始化
LcdShowInit();
while (1)
Key_Proc();
Seg_Proc();
Led_Proc();
有些是关于lcd12864的代码我去掉了,与这个模块没关系
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
