- (c) 2018 Microchip Technology Inc. and its subsidiaries.
- Subject to your compliance with these terms, you may use Microchip software and any
- derivatives exclusively with Microchip products. It is your responsibility to comply with third party
- license terms applicable to your use of third party software (including open source software) that
- may accompany Microchip software.
- THIS SOFTWARE IS SUPPLIED BY MICROCHIP "AS IS". NO WARRANTIES, WHETHER
- EXPRESS, IMPLIED OR STATUTORY, APPLY TO THIS SOFTWARE, INCLUDING ANY
- IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY, AND FITNESS
- FOR A PARTICULAR PURPOSE.
- IN NO EVENT WILL MICROCHIP BE LIABLE FOR ANY INDIRECT, SPECIAL, PUNITIVE,
- INCIDENTAL OR CONSEQUENTIAL LOSS, DAMAGE, COST OR EXPENSE OF ANY KIND
- WHATSOEVER RELATED TO THE SOFTWARE, HOWEVER CAUSED, EVEN IF MICROCHIP
- HAS BEEN ADVISED OF THE POSSIBILITY OR THE DAMAGES ARE FORESEEABLE. TO
- THE FULLEST EXTENT ALLOWED BY LAW, MICROCHIP'S TOTAL LIABILITY ON ALL
- CLAIMS IN ANY WAY RELATED TO THIS SOFTWARE WILL NOT EXCEED THE AMOUNT
- OF FEES, IF ANY, THAT YOU HAVE PAID DIRECTLY TO MICROCHIP FOR THIS
- SOFTWARE.
- #include "mcc_generated_files/mcc.h"
- #include <util/delay.h>
- #define BLINK_DELAY 500
- #define RAMP_DELAY 300
- #define DV_START_VALUE 0x03
- #define DV_STOP_VALUE 0xFC
- Main application
- typedef enum {BLINKY, BUTTON, RAMP} programs_t;
- static uint8_t Unblocking_Read(void);
- static void Print_Menu(void);
- static void CLI_Execute_Command(uint8_t);
- static void CLI_Run(void);
- static void DEMO_Run(void);
- static void Blink_LED(void);
- static void Button_LED(void);
- static void Send_DataVisualizer_Ramp(void);
- static void USART_to_CDC(void);
- static programs_t current_program = BLINKY;
- int main (void)
- SYSTEM_Initialize();
- USART_to_CDC();
- Print_Menu();
- while(1)
- CLI_Run();
- DEMO_Run();
- PORTD.DIRSET = PIN4_bm;
- PORTMUX.USARTROUTEA = PORTMUX_USART0_ALT3_gc;
- if(USART0_IsRxReady() != 0)
- return USART0_Read();
- else
- return '\0';
- printf("\n\r");
- printf("********************************************************************************************************\n\r");
- printf("* Out of the box application for AVR64DD32 Curiosity Nano *\n\r");
- printf("* MMMMMMMMMNddhysyyyysyyhdmMMNNNMMMMM *\r\n");
- printf("* MMMMMMmhssssssssssssssssshMNmmMMMMM *\r\n");
- printf("* MMMMdyssssssssssssssssssssyNMMMMMMM *\r\n");
- printf("* MMmyssssso-`.ossssssso-.-osymMMMMMM *\r\n");
- printf("* Mdssssss/` `/sssss: `+ssdMMMMM __ __ _ _ _ *\r\n");
- printf("* mssssss/ -sss- /ssyNMMM | \\/ (_) | | (_) *\r\n");
- printf("* yssssoso- .oso. -ssymMM | \\ / |_ ___ _ __ ___ ___| |__ _ _ __ *\r\n");
- printf("* ysso- -ss/` `/ss- .ossdM | |\\/| | |/ __| '__/ _ \\ / __| '_ \\| | '_ \\ *\r\n");
- printf("* ys+` .os+` :ss/` `/ssh | | | | | (__| | | (_) | (__| | | | | |_) | *\r\n");
- printf("* y: `+so- .os+` :sh |_| |_|_|\\___|_| \\___/ \\___|_| |_|_| .__/ *\r\n");
- printf("* m` -osss/ -sso- /M | | *\r\n");
- printf("* Mh` `/ssssss+` :sssss/ -NM |_| *\r\n");
- printf("* MMm: -osssssssso-`.+sssssss+` +NMM *\r\n");
- printf("* MMMMhysssssssssssssssssssssso+mMMMM *\r\n");
- printf("* MMMMMMNdysssssssssssssssssydNMMMMMM *\r\n");
- printf("* MMMMMMMMMNmdhyyysssyyhhdmMMMMMMMMMM *\r\n");
- printf("* *\n\r");
- printf("* -Press a key corresponding to a program: *\n\r");
- printf("* '1' - Default program; Blinking LED *\n\r");
- printf("* '2' - LED turns on while button is pressed *\n\r");
- printf("* '3' - An ascending ramp visible in MPLAB Data Visualizer sent through USART while button is pressed *\n\r");
- printf("* -Press any other key to view the menu again. *\n\r");
- static void CLI_Execute_Command(uint8_t command)
- switch(command)
- case '1':
- current_program = BLINKY;
- printf("Program changed to blink LED\r\n");
- break;
- case '2':
- LED_SetHigh();
- current_program = BUTTON;
- printf("Program changed to press button to turn on LED\r\n");
- break;
- case '3':
- LED_SetHigh();
- current_program = RAMP;
- printf("Program changed to press button to send a ramp through USART\r\n");
- break;
- default:
- Print_Menu();
- break;
- uint8_t ch = 0;
- ch = Unblocking_Read();
- if((ch != '\n') && (ch != '\r') && (ch != '\0'))
- CLI_Execute_Command(ch);
- if(current_program == BLINKY)
- Blink_LED();
- else if(current_program == BUTTON)
- Button_LED();
- else if(current_program == RAMP)
- Send_DataVisualizer_Ramp();
- LED_Toggle();
- _delay_ms(BLINK_DELAY);
- if(Button_GetValue())
- LED_SetHigh();
- else
- LED_SetLow();
- static uint8_t counter = 0;
- if(!Button_GetValue())
- USART0_Write(DV_START_VALUE);
- USART0_Write(counter++);
- USART0_Write(DV_STOP_VALUE);
- _delay_ms(RAMP_DELAY);
- End of File
