17V输入,最大2A输出电流,3.5uA 低静态功耗同步降压芯片-ZCC3624替代LTC3624
 楼主| HPT-Lt 发表于 2024-4-24 15:10 | 显示全部楼层 |阅读模式
FEATURES
*Wide ViN Range: 2.7V to 17V
*Wide VouT Range: 0.6V to VIN
*95% Max Efficiency
*Lowl0 :3.5pA, Zero-Current Shutdown
*Constant Frequency (1MHz/2.25MHz)
*Fixed VouT Options Available
*Low Dropout Operation (100% Duty Cycle) with Ultralow IQ
*2A Rated Output Current
*+1% 0utput Voltage Accuracy
*Current Mode Operation for Excellent Line and LoadTransient Response
*Synchronizable to External Clock
*Pulse-Skipping, Forced Continuous, Burst Mode® Operation
*Internal Compensation and Soft-Start
*Overtemperature Protection
*Compact 8-Lead DFN (3mm x 3mm) Package
DESCRIPTION
The ZCC3624/ZCC3624-2 is a high efficiency 17V, 2A synchronous monolithic step-down regulator The switch-ing frequency is fixed to 1MHz(ZCC3624)or 2.25MHz(ZCC3624-2)with a ±40% synchronization range. The regulator features ultralow quiescent current and high efficiency over a wide VouT range.
The step-down regulator operates from an input voltage range of 2.7V to 17V and provides an adjustable output range from 0.6Vto ViN while delivering up to 2A ofoutput current. A user-selectable mode input is provided to allow the user to trade off ripple noise for light load efficiency; Burst Mode operation provides the highest efficiency at lightloads,while pulse-skipping mode providestheowest voltage ripple. The MODE pin can also be used to sync the switching frequency to an external clock.
APPLICATIONS
*Battery Powered Equipment
*Portable Instrumentation
*Emergency Radios
*General Purpose Step-Down Supplies
合作洽谈:402572194(QQ)
