[AT32F405] 【AT-START-F405测评】QPI-FLASH 操作测试
 楼主| aple0807 发表于 2024-5-12 10:43 | 显示全部楼层 |阅读模式
        AT32F405支持QPI外设,挂载FLASH可以方便存储设备日志和历史数据。
        今天测试一下QPI操作FLASH的速度,板载16MB SPI-FLASH。
        测试代码如下:
  1. if (1 == nortst.check_req)
  2.         {
  3.                 uint32_t amount = nortst.amount;
  4.                 uint32_t ticks;
  5.                 // 写入数据
  6.                 uint32_t dats = nortst.dat = nortst.dat_first;
  7.                 flash_dbg_print("nor flash check : start : R/W : %dMB\n", amount / (1024 * 1024));
  8.                 ticks = app_tick_get();
  9.                 for (nortst.addr = nortst.addr_start; nortst.addr < amount + nortst.addr_start; nortst.addr += SPI_NOR_PAGE_SIZE)
  10.                 {
  11.                         if (nortst.addr % SPI_NOR_SECTOR_SIZE == 0)
  12.                         {
  13.                                 bsp_snor_sector_erase(nortst.addr);
  14.                         }
  15.                         for (int index = 0; index < SPI_NOR_PAGE_SIZE / 4; index++)
  16.                         {
  17.                                 nortst.buff[index].uVal = nortst.dat++;
  18.                         }
  19.                         // 写入一页数据
  20.                         bsp_snor_write(nortst.addr, SPI_NOR_PAGE_SIZE, nortst.buff[0].v);
  21.                         if (0 == (nortst.addr & 0x03FFFF))
  22.                         {
  23.                                 flash_dbg_print("nor flash check write data: %d %% \n", (nortst.addr - nortst.addr_start) * 100 / amount);
  24.                         }
  25.
  26.                         if (!nortst.check_req)
  27.                                 break;
  28.                 }
  29.                 flash_dbg_print("nor flash write end: time : %d ms \n", app_tick_get() - ticks);
  30.                 // 读回校验
  31.                 ticks = app_tick_get();
  32.                 nortst.dat = dats;
  33.                 for (nortst.addr = nortst.addr_start; nortst.addr < amount + nortst.addr_start; nortst.addr += SPI_NOR_PAGE_SIZE)
  34.                 {
  35.                         if (nortst.addr % SPI_NOR_SECTOR_SIZE == 0)
  36.                         {
  37.                                 // 读取一扇区数据
  38.                                 bsp_snor_read(nortst.addr, SPI_NOR_SECTOR_SIZE, nortst.buff[0].v);
  39.                                 for (int index = 0; index < SPI_NOR_SECTOR_SIZE / 4; index++)
  40.                                 {
  41.                                         if (nortst.buff[index].uVal != nortst.dat)
  42.                                         {
  43.                                                 nortst.err++;
  44.                                         }
  45.                                         nortst.dat++;
  46.                                 }
  47.                                 if (nortst.err)
  48.                                 {
  49.                                         flash_dbg_print("nor flash check err: %d [url=home.php?mod=space&uid=72445]@[/url] %x \n", nortst.err, nortst.addr);
  50.                                         nortst.err = 0;
  51.                                 }
  52.                         }
  53.
  54.                         if (!nortst.check_req)
  55.                                 break;
  56.                 }
  57.                 nortst.check_req = 0;
  58.                 flash_dbg_print("nor flash read and check end : time : %d ms\n", app_tick_get() - ticks);
  59.                 set_u32(nortst.buff, 0, 4096 / 4);
  60.                 nortst.chk_cnt++;
  61.                 if (nortst.err)
  62.                         nortst.chk_err_cnt++;
  63.         }
其主要功能是根据指定地址和数量写入数据,然后读取并验证数据是否损坏。
        测试结果如下:
        QPI时钟频率配置为54MHz。
        控制台输入 nor check 4
        测试4MB数据读写,写入耗时35s,大约100+KB/s。
        读取并验证耗时:239ms,换算速度约16.7MB/s,这个速度相当可观。
        下面附上测试代码:
AT32F405_EVAL.rar (8.51 MB, 下载次数: 8)
gouguoccc 发表于 2024-5-12 11:14 来自手机 | 显示全部楼层
些数据这个时间不对吧?这么长?
 楼主| aple0807 发表于 2024-5-12 11:28 | 显示全部楼层
些数据这个时间不对吧?这么长?
时间很长吗?外部FLASH,读取并验证4MB数据,239ms
gyh974 发表于 2024-5-13 09:48 | 显示全部楼层
QPI是什么意思?有原理图?怎么和MCU连接才是快速接口?
呐咯密密 发表于 2024-5-13 13:19 | 显示全部楼层
挺不错的测试,后面也要做QSPI,有个借鉴
 楼主| aple0807 发表于 2024-5-13 17:13 | 显示全部楼层
QPI 和 SPI信号时序一样,区别是QPI有4条数据线,工作在半双工模式。
