[其它产品/技术] Infineon launches new NFC I2C bridge tag for contactless authentication and secured configuration of IoT devices
 楼主| IFX-JimmyHuang 发表于 2024-5-24 13:44 | 显示全部楼层 |阅读模式
https://www.infineon.com/cms/en/about-infineon/press/market-news/2024/INFCSS202405-104.html
IFX-LilyWang 发表于 2024-5-24 14:38 | 显示全部楼层
Good news! Can you share some typical use cases NBT used? thanks!
 楼主| IFX-JimmyHuang 发表于 2024-5-24 16:07 | 显示全部楼层
请参考下面链接
https://bbs.21ic.com/icview-3373334-1-1.html
IFX-Wanmin 发表于 2024-5-27 16:22 | 显示全部楼层
应用场景:需要配件认证的应用
