- #include "HT66F0185.h"
- #define uint8 unsigned char
- #define uint16 unsigned int
- #define CLK_0 _pd1=0
- #define CLK_1 _pd1=1
- #define LOAD_0 _pd0=0
- #define LOAD_1 _pd0=1
- #define DIN_0 _pa1=0
- #define DIN_1 _pa1=1
- #define NoOp 0x00 //??2ù×÷??'??÷
- #define Digit0 0x01 // êy??1ü1??'??÷
- #define Digit1 0x02 // êy??1ü2??'??÷
- #define Digit2 0x03 // êy??1ü3??'??÷
- #define Digit3 0x04 // êy??1ü4??'??÷
- #define Digit4 0x05 // êy??1ü5??'??÷
- #define Digit5 0x06 // êy??1ü6??'??÷
- #define Digit6 0x07 // êy??1ü7??'??÷
- #define Digit7 0x08 // êy??1ü8??'??÷
- #define DecodeMode 0x09 // ò?????ê???'??÷
- #define Intensity 0x0a // áá?è??'??÷
- #define ScanLimit 0x0b // é¨?è??êy??'??÷
- #define ShutDown 0x0c // μí1|o???ê???'??÷
- #define DisplayTest 0x0f // ??ê?2aê???'??÷
- #define ShutdownMode 0x00 // μí1|o?·?ê?
- #define NormalOperation 0x01 // ?y3?2ù×÷·?ê?
- #define ScanDigit 0x07 // é¨?è??êyéè??????ê?8??êy??1ü
- #define DecodeDigit 0xff // ò???éè????8???ù?aBCD??
- #define IntensityGrade 0x0a // áá?è??±eéè??
- #define TestMode 0x01 // ??ê?2aê???ê?
- #define TextEnd 0x00 // ??ê?2aê??áê??????'?y3?1¤×÷??ê?
- * Function implementation - global ('extern') and local ('static')
- uint8 DisBuffer[8]={0,0,0,0,0,0,0,0}; // ??ê??o'???
- //******************?óê±toá??**************************************
- void delay(uint16 t)
- uint16 i;
- while(t--)
- /* ??óú12Mê±?ó?????óê±1ms */
- for (i=0;i<36;i++)
- //*************?òMAX7219D'è?×??ú?¨8????********************
- void SendChar (uint8 ch)
- uint8 i,temp;
- delay(1);
- for (i=0;i<8;i++)
- temp=ch&0x80;
- ch=ch<<1;
- if(temp)
- DIN_1;
- delay(1);
- CLK_0;
- delay(1);
- CLK_1;
- delay(1);
- else
- DIN_0;
- delay(1);
- CLK_0;
- delay(1);
- CLK_1;
- delay(1);
- //**************?òMAX7219D'è?×??¨16????*****************************
- void WriteWord (uint8 addr,uint8 num)
- LOAD_0;
- delay(1);
- SendChar(addr);
- delay(1);
- SendChar(num);
- delay(1);
- LOAD_1; // ??'????àó|??'??÷
- //*********************** MAX72193?ê??¯ ******************
- void InitDisplay (void)
- WriteWord (ScanLimit,ScanDigit);// éè??é¨?è???T
- WriteWord (DecodeMode,DecodeDigit);// éè??ò?????ê?
- WriteWord (Intensity,IntensityGrade); // éè??áá?è
- WriteWord (ShutDown,NormalOperation); // éè???a?y3?1¤×÷??ê?
- void delay_ms(uint16 ms)
- //1ms
- GCC_DELAY(2000);
- void main()
- _wdtc=0xa8;
- _pdc=0;
- _pac=0;
- InitDisplay (); // MAX7219???
- WriteWord(DisplayTest,TestMode);// ??????,????LED
- delay(1500); // ???1.5s
- WriteWord (DisplayTest,TextEnd);// ????????
- WriteWord (Digit0,0);
- WriteWord (Digit1,1);
- WriteWord (Digit2,2);
- WriteWord (Digit3,3);
- while(1)
- delay(150); // ???1.5s
复制代码
效果图
不知道怎么回事,仿真调试可以,去掉仿真器,给板子通电就不行了。
