- void ADC_Init(void)
- GPIO_Config_T gpioConfig;
- ADC_Config_T adcConfig;
- ADC_CommonConfig_T adcCommonConfig;
- /* Enable GPIOA clock */
- RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_GPIOA);
- /* ADC channel 0 configuration */
- GPIO_ConfigStructInit(&gpioConfig);
- gpioConfig.mode = GPIO_MODE_AN;
- gpioConfig.pupd = GPIO_PUPD_NOPULL;
- gpioConfig.pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3;
- GPIO_Config(GPIOA, &gpioConfig);
- /* Enable ADC clock */
- RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_ADC1);
- /* ADC configuration */
- ADC_Reset();
- adcConfig.resolution = ADC_RESOLUTION_12BIT;
- adcConfig.scanConvMode = DISABLE;
- adcConfig.continuousConvMode = DISABLE;
- adcConfig.extTrigEdge = ADC_EXT_TRIG_EDGE_NONE;
- adcConfig.extTrigConv = ADC_EXT_TRIG_CONV_TMR1_CC1;
- adcConfig.dataAlign = ADC_DATA_ALIGN_RIGHT;
- adcConfig.nbrOfChannel = 4;
- ADC_Config(ADC1, &adcConfig);
- ADC_CommonConfigStructInit(&adcCommonConfig);
- /*Set ADC Clock Prescaler. ADC_Clock = APB2_Clock/4, 84/4=21MHz*/
- adcCommonConfig.prescaler = ADC_PRESCALER_DIV4;
- ADC_CommonConfig(&adcCommonConfig);
- /* ADC channel 0-3 Convert configuration */
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_0, 1, ADC_SAMPLETIME_112CYCLES);
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_1, 2, ADC_SAMPLETIME_112CYCLES);
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_2, 3, ADC_SAMPLETIME_112CYCLES);
- ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_3, 4, ADC_SAMPLETIME_112CYCLES);
- /* Enable complete conversion interupt */
- ADC_EnableInterrupt(ADC1, ADC_INT_EOC);
- /* NVIC configuration */
- NVIC_EnableIRQRequest(ADC_IRQn, 1, 1);
- /* Enable ADC */
- ADC_Enable(ADC1);
中断函数:
- uint16_t adcData[4] = {0};
- uint16_t adcIndex = 0;
- void ADC_IRQHandler(void)
- if (ADC_ReadStatusFlag(ADC1, ADC_FLAG_EOC))
- ADC_ClearStatusFlag(ADC1, ADC_FLAG_EOC);
- adcData[adcIndex++] = ADC_ReadConversionValue(ADC1);
- if(adcIndex == 4)
- // adcIndex = 0;
- }else{
- ADC_SoftwareStartConv(ADC1);
在使用规则通道采样时要注意:多路采样时如果不用DMA方式读取数据的话,不要使用连续扫描模式。因为规则采样在采集多路ADC时只有一个转换完成标志。而且数据寄存器也只有1个。
这里我使用的是触发一次采样一次。没有使用连续扫描模式。
测试代码:
- #include "nr_micro_shell.h"
- void adc_read(char argc, char *argv)
- ADC_SoftwareStartConv(ADC1); //ADC_EnableSoftwareStartInjectedConv();
- printf("ADC:\r\n");
- while(adcIndex < 4);
- adcIndex = 0;
- printf("1=%X\r\n",adcData[0]);
- printf("2=%X\r\n",adcData[1]);
- printf("3=%X\r\n",adcData[2]);
- printf("4=%X\r\n",adcData[3]);
- NR_SHELL_CMD_EXPORT(adc, adc_read, "adc data");
通过串口查看ADC采样值:
ADC注入序列采样模式:
接下来试试注入序列采样模式。
初始化如下:
- ADC_Reset();
- adcConfig.scanConvMode = ENABLE; //DISABLE;
- // /* ADC channel 0-3 Convert configuration */
- // ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_0, 1, ADC_SAMPLETIME_112CYCLES);
- // ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_1, 2, ADC_SAMPLETIME_112CYCLES);
- // ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_2, 3, ADC_SAMPLETIME_112CYCLES);
- // ADC_ConfigRegularChannel(ADC1, ADC_CHANNEL_3, 4, ADC_SAMPLETIME_112CYCLES);
- // /* Enable complete conversion interupt */
- // ADC_EnableInterrupt(ADC1, ADC_INT_EOC);
- ADC_ConfigInjectedSequencerLength(ADC1, 4);
- ADC_ConfigInjectedChannel(ADC1, ADC_CHANNEL_0, 1, ADC_SAMPLETIME_112CYCLES);
- ADC_ConfigInjectedChannel(ADC1, ADC_CHANNEL_1, 2, ADC_SAMPLETIME_112CYCLES);
- ADC_ConfigInjectedChannel(ADC1, ADC_CHANNEL_2, 3, ADC_SAMPLETIME_112CYCLES);
- ADC_ConfigInjectedChannel(ADC1, ADC_CHANNEL_3, 4, ADC_SAMPLETIME_112CYCLES);
- ADC_EnableInterrupt(ADC1, ADC_INT_INJEOC);
- /* Enable ADC */
- ADC_Enable(ADC1);
中断读取数据:
- // if (ADC_ReadStatusFlag(ADC1, ADC_FLAG_EOC))
- // ADC_ClearStatusFlag(ADC1, ADC_FLAG_EOC);
- // adcData[adcIndex++] = ADC_ReadConversionValue(ADC1);
- // if(adcIndex == 4)
- // }else{
- // ADC_SoftwareStartConv(ADC1);
- if (ADC_ReadStatusFlag(ADC1, ADC_FLAG_INJEOC))
- ADC_ClearStatusFlag(ADC1, ADC_FLAG_INJEOC);
- adcData[0] = ADC_ReadInjectedConversionValue(ADC1,1);
- adcData[1] = ADC_ReadInjectedConversionValue(ADC1,2);
- adcData[2] = ADC_ReadInjectedConversionValue(ADC1,3);
- adcData[3] = ADC_ReadInjectedConversionValue(ADC1,4);
- adcIndex = 4;
测试代码:
- void adcin_read(char argc, char *argv)
- ADC_EnableSoftwareStartInjectedConv(ADC1);
- printf("ADC1 Inject:\r\n");
- adcIndex = 0;
- NR_SHELL_CMD_EXPORT(adc, adcin_read, "adc data");
最终串口打印数据:
