- #include "n76e003.h"
- #include "stdio.h"
- #define uint32 unsigned int
- //typedef unsigned int uint32;
- void delay_us(int n) {
- int m;
- for (m=0;m
- void delay_ms(int j) {
- int k;
- for (k=0;k
- delay_us(1000);
- void P0_P1_Mode(void) {
- P0M1=0x3A; P0M2=0x3B; //设置P0
- P1M1=0xA0; P1M2=0xBF; //设置P1
- sbit s1 = P0^0;
- sbit s2 = P1^0;
- sbit s3 = P1^1;
- sbit s4 = P1^2;
- sbit s5 = P1^3;
- sbit s6 = P1^4;
- void UART0_Init(uint32 Baud) //设置串口0 {
- P0_P1_Mode();
- ES=1; //使能所有中断
- ES=1; //串口0中断使能
- ET1=0; //关闭定时器1中断
- SCON = 0x52; //串口0选择模式1 SM0=0 SM1=1 REN=1 TI=1
- T3CON|=0x00; //选择定时器1 BRCK=0
- PCON |=0x80; //定时器1的波特率加倍 SMOD=1
- CKCON|=0x10; //定时器1的时钟源为系统时钟 T1M=1
- TMOD |=0x20; //定时器1选择模式2 8位计数器,数值从TH1自动重装载入TL1 M1=1 M0=0 2^8=256
- #ifdef FOSC_160000
- TH1 = 256 - (1000000/Baud+1);
- /*16 MHz */
- #endif
- TCON |=0x40; //定时器1启动 TR1=1
- void Send_Data_UART0(int a) {
- TI=0;
- SBUF=a; //串口0数据缓存寄存器
- while(TI==0);
- int main() {
- s1=1;
- s2=1;
- s3=1;
- s4=1;
- s5=1;
- s6=1;
- UART0_Init(9600);
- while(1) {
- if(s1=0) {
- Send_Data_UART0(1);
- delay_ms(10);
- if(s2=0) {
- Send_Data_UART0(2);
- delay_ms(10);
- if(s3=0) {
- Send_Data_UART0(3);
- delay_ms(10);
- if(s4=0) {
- Send_Data_UART0(4);
- delay_ms(10);
- if(s5=0) {
- Send_Data_UART0(5);
- delay_ms(10);
- if(s6=0) {
- Send_Data_UART0(6);
- delay_ms(10);
